01' WJ engine trouble - JeepForum.com
post #1 of 30 Old 03-21-2019, 07:20 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
My jeep is a quadradrive WJ, straight 6, 4.0. It idles smooth, and runs fantastic under load, but at higher speeds (35mph and above) it starts to run rough, only when the accelerator is released.
I have recently replaced the spark plugs, and the heads were rebuilt last year.
If anyone can point me towards the right diagnosis I would greatly appreciate it.
Cjdemoines is offline
post #2 of 30 Old 03-21-2019, 08:40 AM
jtec
jtec's Avatar
2014 JK Wrangler
try a scan* - let us know .
A fuel pressure test, leak down, and vacuum gauge might help find issue.
Jeep is STOCK engine wise - no mods?
*SCAN not key on off.
jtec is offline
post #3 of 30 Old 03-21-2019, 09:05 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
Yes the engine is completely stock, I will scan the onboard today and see if it's throwing any codes.
post #4 of 30 Old 03-21-2019, 12:47 PM
jtec
jtec's Avatar
2014 JK Wrangler
you will need to use a SCANNER - not the key on off .
Scans are free at many auto parts stores.
jtec is offline
post #5 of 30 Old 03-21-2019, 03:25 PM
Mattyjm
Mattyjm's Avatar
What spark plugs did you put in?
2002 Laredo. Baloo.
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #6 of 30 Old 03-21-2019, 04:05 PM
JGCJeep
My guess is an air problem. Intake or exhaust.
Simple stuff like pcv and air filter good?
JGCJeep is offline
post #7 of 30 Old 03-22-2019, 06:05 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
I used autolite platinums, I don't remember the exact part number offhand.
post #8 of 30 Old 03-22-2019, 06:19 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
I also changed the air filter about 300 miles ago, but I will take a look at the pic fittings and make sure they are up to snuff.
post #9 of 30 Old 03-22-2019, 06:43 AM
JGCJeep
Do these vehicles have an EGR valve?
JGCJeep is offline
post #10 of 30 Old 03-22-2019, 06:58 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
It does in fact have the egr valve, I am planning to completely replace it shortly.
post #11 of 30 Old 03-22-2019, 07:13 AM
JGCJeep
Another possible culprit. Good luck.
JGCJeep is offline
post #12 of 30 Old 03-22-2019, 07:19 AM Thread Starter
Cjdemoines
Cjdemoines's Avatar
Now I've got a nice long list of possible repairs, I'm gonna run with this for a while and see if I can resolve the issue. Thanks to everyone for helping me out and I will post here any updates or changes.
post #13 of 30 Old 03-22-2019, 07:54 AM
jtec
jtec's Avatar
2014 JK Wrangler
I would suggest you SCAN for codes - as suggested above.
Put correct plugs on the shopping list,
Let us know if there is a schraider valve on fuel rail, we want to do some tests..
And not worry to much about the EGR or PIC fittings?
jtec is offline
post #14 of 30 Old 03-22-2019, 08:10 AM
JGCJeep
What’s a PIC fitting?
JGCJeep is offline
post #15 of 30 Old 03-22-2019, 08:11 AM
JGCJeep
Was the problem happening before you replaced the spark plugs?
JGCJeep is offline
Welcome, Using the WK2 Forum, and Basic WK2 Information LuckRider WK2 Grand Cherokee Forum 11 09-27-2019 06:59 AM
Help, my wife put gas in our CRD by mistake Zroe89 WK Grand Cherokee & XK Commander Forum 26 11-09-2018 04:34 PM
How to test TPS bigalpha XJ Cherokee Technical Forum 32 10-11-2018 02:31 PM
Interesting engine install issue mtmuley WJ Grand Cherokee Forum 5 07-01-2018 02:07 PM
2009 Jeep Liberty new (to me) engine problem NancyLou KK Liberty Forum 4 03-09-2018 04:22 PM
