01 Grand Cherokee lock issues - JeepForum.com
post #1 of 6 Old 07-18-2019, 10:17 PM Thread Starter
Notapadawan
Our GC has a tendency to unlock itselfwhile in the driveway (lights flash and all). Recently I started hearing the locks going crazy while driving down the road. Anyone know how to fix this issue without doing the hit-and-miss replacement (replace this part then that part then another part until you finally find the right part that was wrong)? This damn thing is driving my wife nuts.
Notapadawan is offline
post #2 of 6 Old 07-18-2019, 11:43 PM
2oldjeeps
mine once flashed lights. i messed with the left side switch stalk. it never repeated.
wild guess,unhook batt overnight...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 6 Old 07-19-2019, 07:55 AM
LuthWJ77
LuthWJ77's Avatar
Might check the door boot wiring also just to be sure. Can't recall this particular symptom being diagnosed from the broken wires but never know.
LuthWJ77 is offline
post #4 of 6 Old 07-19-2019, 08:26 AM
DesertRata
DesertRata's Avatar
X2 on wires running through the door post and the door. I've been into that wiring mess three times on my wife's 04 JGC fixing loose and broken wires.
Desert Rata
DesertRata is offline
post #5 of 6 Old 07-19-2019, 09:18 AM
2oldjeeps
usually broken wires mean things DONT work, not do work.my 04 ,no locks,no windows, was wires.
if things 'happen",something is telling them to. computer temp brain phart.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #6 of 6 Old 07-19-2019, 02:41 PM
Mattyjm
Mattyjm's Avatar
Your passenger door module controls all locks in the vehicle. I'd start there. I'd probably try to get a good one from a junk yard. You'll also need to get the keyfob from that same WJ in order to unlock and lock your doors.
Keyfobs are married to the PDM of each vehicle. The PDM is the module with the unlock and window switch in it. I hope this helps you, buddy.
2002 Laredo. Baloo.
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
