WK2+QD2+QLift add mud=wtf??? - JeepForum.com
post #1 of 53 Old 09-30-2015, 10:28 PM Thread Starter
LINEOFDEFENSE
2012 WK
okay I've had 2 WJ Overland Grand Cherokees and by no means am an off-road expert. But I know how to rock a car/truck/etc and get out of snow and mud. I upgraded and bought this wk2 and made sure to get a vehicle that had the Quadra Drive on it because I wanted the limited slip...Afterall, no one ever really uses the gc to its limit but JUST IN CASE, I wanted the best offroad package available. That way once shes all pimped out w/afmkt cosmetic dohickys, rims, k&n cai; etc i wont have to replace her because I didnt get the "best" offroad options. Afterall, these things get stuck from a lack of upgrades, not because of driver error right?
Anyway, 1st fail...was sitting in my brothers flat yard after a HEAVY rain (like step on wet grass and h20 halfway up my nikes). Go to pull out slowly (to save my bros yard) all four tires spinning and I'm not moving? Thinking must be stock tires or some hidden traction control??? Tail between legs as I get pulled out by a utv with a MOTORCYCLE STRAP!!!
2nd fail...spent alot of time and $ getn BFG AT KO tires and some sweet dropstars to ride on. Crossing a "creek" 2ft wide, 2ft deep...ql in offroad 2 and nothing touching the ground....passenger rear wheel only thing left in the creek/rut and im stuck!!! Tried putting it in snow/mud setting, snow setting, turning off esc (sport mode); then even tried 4 wheel low....nothing! So, get pulled out by my brother in his chevy pickup.
3rd fail...same spot, same creek,18 hours later in daylight. After reading how the elsd works i go back in crawling slow trying to "feel" if everythings working...1st wheel that drops into the rut stops me flat. At this point im still not touching the ground or high centered and only ONE WHEEL is stuck. And then after spending 5 minutes spinning and waiting for it to act like my wj overland (aka grind in the rear then walk me out) i get pissed and try to "rock" it out. 10 minutes later front air dam laying on mud in front of me, both front tires are in 3ft graves, rears have barely sunk down (by comparison) and im getting towed out by my brother....again.
WTF am I doing wrong? Pics to follow when i get to my pc.
20150930_190601_1443673620820.jpg   20150930_190608_1443673672590.jpg   20150930_191139_1443673696167.jpg
LINEOFDEFENSE is offline
post #2 of 53 Old 09-30-2015, 10:38 PM Thread Starter
LINEOFDEFENSE
2012 WK
And to save time...i KNOW i could hop right over it going faster! The point was to go slower and feel the 4x4 Quadradriveliftselecrap do its thing...which is apparently nothing? For the record I have a 2012 Overland Summit with 5.7L hemi, qd2, and qlift....and I had just crossed the same creek/rut farther up in the last photo...by my bros truck...where there is very little mud. And I didnt bottom out there either in offr2 setting.
PS: Where can I buy that 2fr wide black plastic piece that attaches lower air dam to the bumper (i guess)? My airdam looks fine after being wripped off by the creek...along with my pride and my jeeps reputation (i hate facebook-and my brother). Before I was even out...everyone knew.
post #3 of 53 Old 09-30-2015, 10:45 PM Thread Starter
LINEOFDEFENSE
2012 WK
And I do not currently piss excellence...
post #4 of 53 Old 09-30-2015, 10:52 PM
MurdaJs
You need some real tires
MurdaJs is offline
post #5 of 53 Old 09-30-2015, 10:58 PM Thread Starter
LINEOFDEFENSE
2012 WK
only tires that make block white letters for my size...block white letters are OG Pimp...stuck in the mud
post #6 of 53 Old 09-30-2015, 11:08 PM
xrunndonex
1994 ZJ
You can buy letters that can be applied to tires
xrunndonex is offline
post #7 of 53 Old 10-01-2015, 02:04 AM
Tyler-98-W68
2016 KL Cherokee
It appears the system is functioning correctly, all tires spinning, if they can't get traction you aren't going anywhere plain and simple. The only thing that "might" have helped in the above pictures is some very aggressive MT tires, otherwise it looks like a lot of other vehicles would be stuck too.
2016 Trailhawk 3.2L | Player3 Tuned Via HP Tuners
Tyler-98-W68 is offline
post #8 of 53 Old 10-01-2015, 05:55 AM
BeerMonkeY
your tires are not for mud at all. sometimes mud requires a little momentum
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #9 of 53 Old 10-01-2015, 06:55 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
KOs are not that great in mud as mud doesn't get extracted from the tread well. The WK2 tires are also a bit wide for mud (there is a lot of mud to push out of the way). What kind of tires were you running on the WJ? Even if not high centered, if you were dug in a bit it takes a surprising amount of power/traction to push through the mud.
I know you were playing, but once you stop dead in mud its tuff, even with narrow MT tires. So don't play like that . Use mud mode (which locks the rear dif) and maintain momentum.
You can go to forum sponsor http://moparonlineparts.com/mop-parts/#parts and look up front bumper parts. There will be a diagram, like the one below, showing what items are available and prices. Not sure what part you are talking about. The baffle #15 is like $65.
Do not mistake temptation for opportunity
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #10 of 53 Old 10-01-2015, 07:16 AM
Nonstop
You need more stickers. Without a trail rated badge it's just not going to happen.
2000 WJ 5.2 V8
2011 WK2 V6
Nonstop is offline
post #11 of 53 Old 10-01-2015, 07:19 AM
MartyA
2012 WK
Also, don't discount that the WK2 is heavy. I don't have stats for how it compares to a WJ but when you drop the front tires into the mud like that the weight doesn't help you - it just makes sure you dig in harder. I'd agree with the other comments here that this isn't a 'fair' test of the 4wd system. Lafayette is a little South for this, but another 'setup to fail' test would be all four wheels on glare ice. They're all going to spin, you'll be 'stuck', but the vehicle is doing everything it can to help you.
But don't feel bad. Back in the day I dropped my new-to-me F250 into a mud hole on the first day I bought it and couldn't get it out ;-( Had to get tugged out by a lowrider!
MartyA is offline
post #12 of 53 Old 10-01-2015, 10:17 AM Thread Starter
LINEOFDEFENSE
2012 WK
I should of taken before pics of the creek, there was no holes then. I just thought it funny how much more the front dug in than the rear. And my WJ has the exact same tires. I don't like change I guess. Ya, well anyway, I'm down two towouts for my brother. So, I have to show up at 200am when he's been drinking and stuck in the river with his utv.
+1 on the stickers...I thought that was the problem.
2003 WJ Overland "Kolak Lift", BFG AT KO 265/70/17
2004 WJ Overland
1991 Wrangler
2012 T4R Ltd
2000 BMW M
"Boy Ive got vision and the rest of the world is wearing bifocals" -B. Cassidy
post #13 of 53 Old 10-01-2015, 10:20 AM Thread Starter
LINEOFDEFENSE
2012 WK
The exwife met the new wife....
2004 WJ Overland
1991 Wrangler
2012 T4R Ltd
2000 BMW M
post #14 of 53 Old 10-01-2015, 10:55 AM
ColdCase
ColdCase's Avatar
2011 WK
Those are nice vehicles... I suspect the WJ's tires are narrower. I am always surprised just how much effect the WK2 tire width on slippery snow/mud surfaces has over my WJ.
Your WJ had QD limited slip both front and rear right? Jeep says the front doesn't make much difference, but I think it does in situations like this. Perhaps the front axle BTC dug into the soft mud more than a locked diff would... but then I'm just guessing.
ColdCase is offline
post #15 of 53 Old 10-01-2015, 12:17 PM
xrunndonex
1994 ZJ
Your ex might kill you just saying
