Wk2 diesel HD Brakes time for replacement. - JeepForum.com
post #1 of 3 Old 06-18-2019, 10:08 AM Thread Starter
CHULOGORDO82
CHULOGORDO82's Avatar
2015 WK
Good Morning All.
For those with the Ecodiesel, and hd brakes, what are you using to replace the rotors and pads. I was thinking about the stoptech kit on autoanything.com, but not sure if the drilled and slotted with solid rear rotor is what I have.
Thanks in advance.
Fabian
Sent from my SM-G892A using Tapatalk
CHULOGORDO82 is offline
post #2 of 3 Old 06-18-2019, 11:48 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
HD brakes have vented rotor in the rear. A solid rear rotor is SD. The vented rotors are quit a bit thicker than solid. In 2015, there is no difference between the Diesel HD brakes and the Gas HD brakes.
If you are towing heavy in hilly terrain or racing, the drilled/slotted rotor on the WK2 HD brake may or may not be of some benefit in reducing fade. There are disadvantages on a WK2, but its your coin. They are stylish, however.
My brake guy, who likes happy customers, uses mid range Autozone rotors and pads and never has had a complaint.... well... they do have a tendency to provide the wrong rotors, their parts book was wrong at one time .
I have reached the age where all compliments will be followed by for your age.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 06-19-2019, 07:42 PM Thread Starter
CHULOGORDO82
2015 WK
Cool so we have a vented rear rotor. I was just looking at options. I may go the Autozone route since I've used them before without any issues. Thanks
