What mode should I put the air suspension in to have my tires rotated? - JeepForum.com
post #1 of 7 Old 05-14-2019, 06:52 PM Thread Starter
andyo5
2018 WK
I'm thinking I should use the same mode as for wheel alignment. What do you think?
andyo5 is offline
post #2 of 7 Old 05-14-2019, 07:02 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It doesn’t matter, QL will disable itself, but there is a tire change/disable mode you can select.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 7 Old 05-14-2019, 07:09 PM
Roadijeff
Roadijeff's Avatar
My guess would be Tire/Jack mode.
Roadijeff is offline
post #4 of 7 Old 05-14-2019, 07:38 PM
ColdCase
ColdCase's Avatar
2011 WK
Yeah thats the mode they call it on the newer models.....
ColdCase is offline
post #5 of 7 Old 05-15-2019, 08:11 PM Thread Starter
andyo5
2018 WK
My manual warns that if you do not put it in the right mode, the QL system could somehow damage itself when the Jeep is lifted off the ground. That's why I am asking.
andyo5 is offline
post #6 of 7 Old 05-17-2019, 06:21 AM
jtpeters
FWIW:2014 SM states:
NOTE:
The air suspension system will auto-disable when lifted on a frame hoist, or when jacking one corner
of the vehicle. The air suspension may attempt to change height slightly prior to switching to
auto-disable. A manual disable is also available by pressing the "Up" and "Down" switches of the
terrain select switch simultaneously for more that 5 seconds. The air suspension system will return to
normal operation when the vehicle speed reaches 25 kph (15 mph).
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
post #7 of 7 Old 05-17-2019, 12:03 PM Thread Starter
andyo5
2018 WK
NOTE:
Good to know this. I will try it. The manual for my 2018 Limited says nothing about automatic disable. It says you must select one of the disable modes or else damage might occur. There are no real guidelines as to which mode to select other than the name (tire jack, wheel balance, etc) and they all seem to do the exact same thing.
andyo5 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
The Modified Superlift Thread USN_BlackWK WK Grand Cherokee & XK Commander Forum 93 01-20-2019 07:10 AM
Tollerances of QDII for different size tires? onebluemcm WK2 Grand Cherokee Forum 7 06-07-2018 09:56 AM
Alignment Check with Air Suspension Jurassic_Jeep WK2 Grand Cherokee Forum 5 03-28-2018 05:18 AM
Teraflex S/T3 and Falcon shock review gonzobreath JK Wrangler Technical Forum 5 03-06-2018 05:59 AM
