What' included in a tune-up? - JeepForum.com
 1Likes
  • 1 Post By ceb1
post #1 of 9 Old 03-05-2020, 01:27 PM Thread Starter
93zjer
On a 2014 Hemi with 129,741 miles. No past record of service, what should a tune-up consist of?
93zjer is offline
post #2 of 9 Old 03-05-2020, 03:02 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
If you have a owners manual, browsing through may give you a good idea. I thinks its basically plugs, ignition wires, filters, PCV valve, oil change. Perhaps coolant change. Perhaps serpentine belt replace. Check alignment, put air in the tires
Never Argue With An idiot. They'll Lower You To Their Level And Then Beat You With Experience!
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 9 Old 03-05-2020, 03:39 PM
ceb1
ceb1's Avatar
"tune ups" went away in the 80's and were replaced by scheduled maintenance. If you don't know what was done, then you'll want to do everything required up to 130k miles - so all fluids and lubricants, plugs, filters and so forth.
ceb1 is offline
post #4 of 9 Old 03-05-2020, 04:46 PM Thread Starter
93zjer
You know what I didn't even think of that. Thank you.
93zjer is offline
post #5 of 9 Old 03-05-2020, 04:47 PM Thread Starter
93zjer
I knew this but when the dealership service guy uses the term, I guess it can make you second guess yourself.
93zjer is offline
post #6 of 9 Old 03-05-2020, 05:30 PM
ceb1
ceb1's Avatar
Yep, the same way people (and dealers) use the term "that'll void your warranty" when they really mean "that will cause the manufacturer to deny warranty coverage on that particular failure".
Like ColdCase said, the manual tells you what maintenance is required. Just do everything up to 130k miles and you'll be fine.
Oh, and you probably want to find a good local indy to do the service. The dealer will nickel and dime you to death.
Homer1 likes this.
ceb1 is offline
post #7 of 9 Old 03-06-2020, 11:59 AM
Bilko
You should also check you brakes. It is possible the you are still running the original pads. I changed my disks and pads at 115k miles because I was experiencing a slight judder when they got warm on long descents. What surprised me was the pads were only half worn at the most, however the front disks were only 0.5mm from the minimum thickness.
You should at least check the pad wear and that both pads are making full contact with both sides of the disks. The brakes use a sliding caliper and sometimes the pads wedge or the slider pins corrode resulting in one pad wearing faster than the other. This is more common if you use your car in wet or cold regions where they salt the roads.
You may also consider refreshing the brake fluid. I have not heard of an specific issues with Jeeps but I have seen ABS modulator failures on other vehicles as a result of contaminated brake fluid. The replacement is very costly especially considering the cost of a fluid refresh.
Bilko is offline
post #8 of 9 Old 03-06-2020, 12:18 PM
ceb1
ceb1's Avatar
A brake flush is a "must" not a "consider".
ceb1 is offline
post #9 of 9 Old 03-07-2020, 07:43 AM
Homer1
Homer1's Avatar
I couldn't agree more, on each point!
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
1997 GC Limited Beach Buggy (Deceased....RIP)
Homer1 is offline
