Sunroof Drain Tubes - JeepForum.com
 1Likes
post #1 of 31 Old 06-04-2015, 06:45 AM Thread Starter
Kduniverse
2011 WK
Sunroof Drain Tubes
Does anyone know where the rear tubes exit to? I cannot find where they come out. It's nearly impossible to see where they start at the sunroof, but I thought for sure I'd be able to find the other end near the wheel well somewhere. Any ideas?
Kduniverse is offline
post #2 of 31 Old 06-04-2015, 09:19 AM
dcorn
dcorn's Avatar
Pour water in and look for dripping? Or are they clogged and you can't find the openings?
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 31 Old 06-04-2015, 10:03 AM Thread Starter
Kduniverse
2011 WK
Judging by the amount of water pouring out of the headliner after a good rain, I'm guess they're that clogged. I can't even see the opening on the sunroof side.
post #4 of 31 Old 06-04-2015, 11:44 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
These diagrams are from the 2011 parts book, there may be better ones on line.
Looks like two tubes maybe on the drivers side, one exits near the top of the rear wheel well, the other probably the front wheel well.. but hard to tell. You may have to remove the felt liner to see the outlets.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 31 Old 06-04-2015, 01:14 PM
2kg4u
2014 WK
The drain tubes exit to grommets in the front and rear wheel well openings. You can't see them because they are behind the felt fender liner (just like Cold Case stated). If you want to see where they exit, park the vehicle on dry pavement, and one corner at a time pour water into the corners of the sunroof trough, with the sunroof open. Observe where the water drains. If you have a plugged drain don't use compressed air to clear it out ... you might blow the hose connector off the sunroof, which will cause the water to drain on your headliner.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #6 of 31 Old 06-04-2015, 01:22 PM Thread Starter
Kduniverse
2011 WK
Thanks for the replies. I did see grommets when I pulled back the wheel well liner. But I also saw a hole that appears to show some spray insulation. So behind the grommet should be the end of the tube? Awesome, thank you.
The fronts are a bit easier to see. I wasn't able to pull apart the cowl and drain troughs, but with a little maneuvering, I can see the hoses coming through the firewall.
Thanks again,
post #7 of 31 Old 06-04-2015, 02:20 PM Thread Starter
Kduniverse
2011 WK
Popped off the grommet in the front side of the rear wheel well, more insulation behind it. Would it be possible if the drain was just covered with insulation? Or am I still in the wrong location?
19GCTrailhawk likes this.
post #8 of 31 Old 06-04-2015, 02:47 PM
ColdCase
ColdCase's Avatar
2011 WK
There should be a hole in the drain tube grommet. When you pop it off. the tube will come with it as its attached. The rear may be at the very top of the wheel well. I'm not sure I'd be popping grommets. Dunno how much slack there is in that tube.
ColdCase is offline
post #9 of 31 Old 06-04-2015, 03:30 PM Thread Starter
Kduniverse
2011 WK
I didn't see any other grommets on the driver side rear wheel well. I looked under the car, behind etc, cannot find this thing. I did find the leak detection pump filter flopping around. At least I got to reconnect that. Wouldn't this grommet have some sort of opening in it to allow the water out?
post #10 of 31 Old 06-08-2015, 07:06 AM
2kg4u
2014 WK
The sunroof drain tubes exit at the rear of the front wheel housings, and the top of the rear wheel housings. If you are having a hard time finding them, remove the fender liners and pour water onto the four corners of the sunroof tub with the sunroof open. Look for where the water comes out.
Yes, the grommet will have a hole in it.
Roy
2kg4u is offline
post #11 of 31 Old 06-08-2015, 11:45 PM
n666z
whats the best way to clean them if you aren't supposed to use compressed air?
n666z is offline
post #12 of 31 Old 06-09-2015, 05:22 AM
wyat72
2011 WK
X2. I keep mine parked out 24/7. Would like to keep them clean before they get clogged.
2011 Grand Cherokee Laredo X, Pentastar, Qudra Trac I.
wyat72 is offline
post #13 of 31 Old 06-09-2015, 06:06 AM Thread Starter
Kduniverse
2011 WK
My front tubes drain through the firewall, a few inches below the cowl cover. The rears, I did not notice at the top, front or rear of the rear wheel well. Although I only checked the driver side... Any images or illustrations?
post #14 of 31 Old 06-09-2015, 07:33 AM
ColdCase
ColdCase's Avatar
2011 WK
You carefully fish a cleaning wire through the tube if blocked (or take the interior apart), otherwise flush with water.
ColdCase is offline
post #15 of 31 Old 06-09-2015, 12:41 PM
2kg4u
2014 WK
They usually (from the ones I have worked on, not on a JGC) plug up at the bottom where they exit at the grommet. Sometimes a piece of pipe cleaner is sufficient to clear the blockage.
Roy
2kg4u is offline
