Summit Suspension/Drive Options - JeepForum.com
post #1 of 8 Old 12-06-2019, 08:58 AM Thread Starter
stevenriz
2017 WK
Hi everyone. Curious to know what my 2017 Summit has for suspension. I know we have the Quadra-Lift but how do we know what we have for Quadra-Drive if so? I don't see anything on the window sticker. Just curious...
stevenriz is offline
post #2 of 8 Old 12-06-2019, 09:13 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You can get an option sheet for your VIN via the customer portal at jeep.com Look for AWB or DSF
Summit V8s and diesels had QD standard, don't think it was available on a V6. If you look under and see a motor hanging off the rear dif, you have QD. Dunno about lat models, but early models displayed Quadra Drive in the EVIC on startup.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 8 Old 12-06-2019, 11:23 AM Thread Starter
stevenriz
2017 WK
this is in the standard set of options in the My Vehicle Equipment section... so that answers my questions I guess. I will also look for the motor on the rear diff.
Quadra-Trac II (R) 4WD System
Thanks!
post #4 of 8 Old 12-06-2019, 12:26 PM
ColdCase
ColdCase's Avatar
2011 WK
They will all (limited and above) list Quadra-Trac II as thats the transfercase. Those with QD will also list a limited slip diff (DSF) and/or Quadra-Drive (AWB).
post #5 of 8 Old 12-06-2019, 12:50 PM Thread Starter
stevenriz
2017 WK
ahhhh so many quadra things! I probably don't have it Mopar side isn't showing options codes. Is there an option sticker somewhere possibly under the hood or in the spare tire area?
post #6 of 8 Old 12-06-2019, 06:57 PM
mudbear
2019 WK
Try entering your VIN in the attached build sheet link:
https://fcacommunity.force.com/RAM/s/equipment-listing
I would imagine all 5.7 Summits come with the QDII - just re-read & saw that CC already posted this!
19 WK2 5.7 High Altitude current, gone:
16 WK2 3.6 Limited
03 WJ 4.7 HO Limited
94 ZJ 5.2 Laredo
mudbear is offline
post #7 of 8 Old 12-11-2019, 06:02 PM
paullee01
paullee01's Avatar
WK
Real simple! Go to off road page in U Connect screen / Vehicle Dynamics.....Put in neutral, push low range button on console. (You wanna be in 4 Low) If it's shows two locks on the screen you have QD. If it's just showing the one transfer case lock you have QTII. (See photo below) I have QTII.
I'm trying to remember but I don't think the 17 Summit came with QD I believe it's on the 19 models. Let me know I'm curious?
https://www.jeepforum.com/forum/memb...untitled-1.jpg
paullee01 is offline
post #8 of 8 Old 12-11-2019, 07:50 PM
ColdCase
ColdCase's Avatar
2011 WK
Unless it was changed for 2020, all V8 or Diesel Summits have QD as standard equipment.
