Stall on start and even just driving - JeepForum.com
 1Likes
  • 1 Post By ColdCase
post #1 of 12 Old 05-10-2019, 08:54 AM Thread Starter
racin8
2012 WK
I have had the recall done for the fuel pump relay. Within 20 minutes of getting the Jeep back it stalled. That was two years ago, it continues to stall on start and even driving in a straight line or turning a corner. I learned to drive like I'm 99 years old at a corner or traffic light, leaving plenty of gap between traffic during a turn and have an exit strategy in case it stalls in traffic.
I've got the restart down to 3 seconds, wave my arm for behind traffic to see, hard brake, throw into park, press the button to get out of run, foot on brake, press button to restart, slam into drive and stand on it
So frustrated with this defect, I've tried all sorts of start up procedures for a start up sequence nothing has worked, still randomly stalls, multiple times a month
HELP anyone!
I've thought about putting on the recalled external relay an led showing 12V power in and an led showing 12V power out to fuel pump. The idea is at a stall if I can go open the hood and see if either side of the relay is not showing power. Anyone know the wiring for the relay?
Another thought is to jumper out the shifter needing to be in park to re start, scared to do that for obvious reasons. But would allow me to quickly get run mode off and restart it
racin8 is offline
post #2 of 12 Old 05-10-2019, 09:49 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Sounds like the dealer may have not installed the relay quite right and there is a loose connection somewhere.
There are a few stalling threads, and I think sometimes the alternator or bad grounding... when I get a chance I'll try to find one. Some suffered with stalling for years. You probably have read all of them by now.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 12 Old 05-10-2019, 11:40 AM Thread Starter
racin8
2012 WK
ColdCase, you are so right, read so much I gave up for awhile. Came back in to see if there was any fresh info after a close call at an intersection with a gravel truck. Anyone have a detailed wiring diagram of the "fix" with the external relay Jeep put out?
racin8 is offline
post #4 of 12 Old 05-10-2019, 01:56 PM
ColdCase
ColdCase's Avatar
2011 WK
I downloaded this years ago....
BigTizzie likes this.
post #5 of 12 Old 05-10-2019, 02:59 PM Thread Starter
racin8
2012 WK
Perfect, thank you ColdCase!
racin8 is offline
post #6 of 12 Old 05-13-2019, 06:33 AM
Steeven
I did not suffered a stall and I suffered a not start.
Fuel relay has been done in the past.
HOWEVER, the Chrysler mechanic told my mechanic that it MIGHT fix the problem, but he could not be 100% sure.
We did change 4 relays on my Jeep. I can't remember what they were.
The jeep have started everyday since then....
Steeven is offline
post #7 of 12 Old 05-13-2019, 07:03 AM
ColdCase
ColdCase's Avatar
2011 WK
Yeah the relay they put in as part of the recall is not the best, there are better replacement, I think the no-start haunted relay threads mention it. The stalling while driving is usually something else. But replacing the relay is cheap, may work.
post #8 of 12 Old 05-13-2019, 11:31 AM
BigTizzie
BigTizzie's Avatar
2011 WK
Have to figure out if it's the relay or the pump.
I did the relay last fall and so far so good. Got a spare relay also.
Or connections where they hack into the TIPM module.
BigTizzie is offline
post #9 of 12 Old 05-17-2019, 02:57 PM Thread Starter
racin8
2012 WK
Update, ordered a relay and try that next week
racin8 is offline
post #10 of 12 Old 05-20-2019, 02:16 PM Thread Starter
racin8
2012 WK
While waiting for the relay to come I decided to try super premium since I was on empty, stalled on start four times in three days. Relay came today and have installed, had two successful starts so far, YEAH
racin8 is offline
post #11 of 12 Old 05-23-2019, 12:21 PM Thread Starter
racin8
2012 WK
Relay in and same OEM Omron part number that dealer put in for recall. Jeep started 3 times without stalling, then yesterday and today stalled on start four times. So not the relay, wiring, or fuel octane, anyone got anything else to try?
racin8 is offline
post #12 of 12 Old 05-23-2019, 12:27 PM
ColdCase
ColdCase's Avatar
2011 WK
There is another recent thread here where the throttle body and spark plugs were replaced and solved the stalling issue.
How do you know its not the wiring?
