Silence The Annoying Beep - JeepForum.com
 8Likes
post #1 of 25 Old 05-13-2021, 02:04 PM Thread Starter
phlyx
phlyx's Avatar
2020 WK
Question Silence The Annoying Beep
Pulled into a drive up pharmacy in my 2020 Grand Cherokee Trailhawk and was close to the wall, have to close to reach. A warning beep started up telling me I was too close. Duh. It chimed a few times then stopped. Then a short bit later started chiming again then stopped. Trying to carry on a conversation through a tin can audio system at the drive through with myself and the tech wearing masks.... all with the DING-DING-DING-DING going on and off. I'm new to this vehicle, actually 3 days with it, and I really want to know how to turn this off. Started reading the user manual and 470 pages??? Seriously???
If anyone has a way to silence this in a situation like this, please let me know. And now that I type this I'm thinking if I put it in Park it probably would have stopped. Someone can reply and confirm my ignorance if that's the case but would really like to know if you can silence this on the touchscreen. But even still, if I was the 4th car back I really wouldn't want to keep shifting into park every time I stopped.
phlyx is offline
post #2 of 25 Old 05-13-2021, 02:40 PM
JKM
2018 WK
assuming this is the back-up sensors for cross path, you should be able to turn them off. Button will be beside the Start-Stop button on the lower center console
Gypsy1 likes this.
2005 Laredo 4x4 3.7L (SOLD)
2018 Limited 4x4 3.6L
JKM is offline
post #3 of 25 Old 05-13-2021, 03:23 PM
TXTrailhawk
Editing slightly because you your Trailhawk likely has front and back sensors - What he said ^^
2021 Diamond Black GC Trailhawk
TXTrailhawk is offline
post #4 of 25 Old 05-13-2021, 03:26 PM Thread Starter
phlyx
phlyx's Avatar
2020 WK
I can tell how to turn off the lane assist but not sure what would turn off the back-up cross path sensor.
Sorry for the newbie questions but the manual doesn't help much.
phlyx is offline
post #5 of 25 Old 05-13-2021, 03:37 PM
TXTrailhawk
Second button from the left, at the bottom
Cheers
Gypsy1 likes this.
post #6 of 25 Old 05-13-2021, 05:23 PM
Roadijeff
Roadijeff's Avatar
It's in the Starting and Operating section of the manual. No need to read all 400+ pages. The previous reply tells which button it is.
Roadijeff is offline
post #7 of 25 Old 05-13-2021, 10:33 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Just to be a little more complete, there are acoustic sensors for detecting nearby objects as you are parking, so you don't run into them. That P alarm button turns that system off. The system has also confused a few late model drivers here by slamming on the brakes while you move in reverse. Makes it hard to back up a trailer.
The optional cross path system uses radar for longer range and more accurate detection. That sounds a beep if you have the turn signals on, or are in reverse, and it detects something in your blind spot. You can adjust those setting in one of the radio menus.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #8 of 25 Old 05-14-2021, 05:10 AM Thread Starter
phlyx
phlyx's Avatar
2020 WK
Thanks for all the great feedback. I'll read that section but even thought I am a mechanical engineer, it reads like it was written by an engineer and not a tech writer. My last vehicle was a '13 Subaru Forester 2.5X and only tech it had was being able to Bluetooth connect my phone. Long story but had a couple Grand Cherokees before that and never lost the itch to have a Jeep again. We have a '12 Liberty in house, too, and when I'd drive that I smiled a lot.
Thanks again!
phlyx is offline
post #9 of 25 Old 05-14-2021, 05:26 AM
Delta0
Turn your engine off?
Delta0 is online now
post #10 of 25 Old 05-14-2021, 06:40 AM Thread Starter
phlyx
phlyx's Avatar
2020 WK
Inching forward in a long line of cars that would wear out my index finger and probably not so good for my starter, too.
phlyx is offline
post #11 of 25 Old 05-14-2021, 10:57 AM
Delta0
Very true phlyx.
I had in mind turning your engine off only while you were conversing with that annoying intercom.
post #12 of 25 Old 05-14-2021, 12:13 PM
TulsaVic
2011 WK
How about putting it in neutral?
TulsaVic is offline
post #13 of 25 Old 05-14-2021, 02:07 PM Thread Starter
phlyx
phlyx's Avatar
2020 WK
Would have to figure out does Park or Neutral disable the sensors. Does anyone know that? Can test but if someone knows.
phlyx is offline
post #14 of 25 Old 05-15-2021, 03:08 PM
2008OverlandCRD
2017 WK
Park turns off the beeping. Not sure if neutral does.
2017 Jeep Grand Cherokee Summit 4x4, 5.7 Hemi & 2017 SRT 6.4L & 2020 Trackhawk 6.2L Supercharged
2008OverlandCRD is offline
post #15 of 25 Old 05-15-2021, 03:34 PM
ColdCase
ColdCase's Avatar
2011 WK
If I recalled correctly, my early model stopped beeping when I was stopped with foot on brake. I disabled it years ago as it was annoying when it warned me that I was going to hit the door jam as I backed out of the garage. I had at least 6 inches clearance.
ColdCase is offline
