Serviceable driveshaft? - JeepForum.com
post #1 of 36 Old 05-01-2019, 11:21 PM Thread Starter
simmons1183
2011 5.7 4x4.
Pics are not the best, but my rear driveshaft is throwing grease and I am getting vibration off and on in the seats as well as an occasional clunk.
I finally found a 52123514AD drive shaft online.. but rather than fork over $500, has anyone had luck replacing the joints in the drive shaft? I would hate to shell out that dough just because of a leaky joint.
5BC05B69-679A-472D-899D-2D58AC735F55_1556774419871.jpg   3635CF04-AE04-47A7-BEF4-40923971DB91_1556774459910.jpg
simmons1183 is offline
post #2 of 36 Old 05-02-2019, 01:18 AM
Kolak
Vendor
Kolak's Avatar
I've never seen any repair parts for the rear shaft unfortunately. You'll see kits online that say "rear" but what they actually mean is the rear joint on the front shaft.
If I can assist with a replacement Mopar driveshaft please PM me here on the forum or email me at [email protected]
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 36 Old 05-02-2019, 06:25 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah, haven't heard of anything here other than replacing the flex coupler near the diff. Sometimes you can find Mercedes parts that fit but you are on your own. https://www.jeepforum.com/forum/f309...shaft-4334749/
Do not mistake temptation for opportunity
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 36 Old 05-02-2019, 11:39 AM
BigTizzie
BigTizzie's Avatar
2011 WK
Just checked mine yesterday, luckily it's in fine shape.
That other thread where the coupler kept exploding, what a nightmare.
BigTizzie is offline
post #5 of 36 Old 05-12-2019, 11:32 PM Thread Starter
simmons1183
Welp. Ended up replacing the rear driveshaft myself. $600 later, it’s done.
NOT an easy job if you don’t want to remove the exhaust assembly first, but it was manageable with a few cuss words and 4 hours on my back.
Unfortunately I am still getting drive line vibration, so it was in vain anyway.
I am going to do the front shaft next. Nothing visibly wrong with it, but I am running out of things that be causing the drone/vibration.
Only getting vibration/droning starting at 45mph, and only when the vehicles is cold.
*Acceleration makes it go away*
Shifting into neutral, manually changing gears up/down, just coasting, etc doesn’t make any difference, only acceleration makes it go away.
Once I’ve been driving for 5-10 minutes it goes away on its own and doesn’t happen again til the vehicle has sat for a long while.
I am also positive that it’s not the tires or wheels, it doesn’t feel the same as that type of vibration. This shakes the seats and windows with the drone and shudder. Though just to rule it out, I even swapped sets to make sure.
post #6 of 36 Old 05-13-2019, 06:54 AM
ColdCase
ColdCase's Avatar
2011 WK
Vibrations on these WK2s can be a bear to sort out, one reason I suggest driving them cold before buying.
I think the V6 transmission torque converted used to cause this kind of thing as the lockup modulates and can drone. Not sure about the V8 transmission. You may want to change transmission fluids if you haven't already. I would think all that shifting would have isolated that however.
Otherwise I think droning in the driveline would be worse when warm and well used, not after its been set for awhile. Unless perhaps the C/V joint grease settles in a worn joint, throwing it out of alignment, and it takes awhile to loosen up. If its worn, acceleration may squish the grease around and clicks the joint back into alignment. Dunno. There are plenty here with vibrations when new that were never sorted out.
The engine twisting motion on acceleration may stretch a mount that settled while parked.
ColdCase is offline
post #7 of 36 Old 05-13-2019, 12:36 PM Thread Starter
simmons1183
Yeah, I’ve never had such a vibration sensitive vehicle since my last BMW. But considering the chassis of the WK2 is all Mercedes engineering, I guess that makes sense.
Oddly enough today on my first drive of the day I had no vibration issues at all, it’s like it should be. Who knows...
I will report back after the front shaft has been replaced. I see that one of the front CV boots is leaking so I might replace that too. Seems like that may really only affect 4WD, but still.
post #8 of 36 Old 05-13-2019, 01:46 PM
ColdCase
ColdCase's Avatar
2011 WK
The entire drivetrain is always in motion, so its not necessarily a 4WD thing.
ColdCase is offline
post #9 of 36 Old 05-13-2019, 11:04 PM Thread Starter
simmons1183
Well, went to grab the part number off the front driveshaft this evening and found a few surprises. For one, my sway bar bushings are shot. Not sure how that even happens.
secondly, I have what looks to be a coolant leak.
Coming from the passenger side. I tried to find anywhere it could be coming from but all hoses and lines are dry. The leak is towards the back part of the engine area, so not a WP/thermostat issue. The reservoir tank doesn’t appear to have any cracks and the overflow hose is dirty inside so nothing has come out of it recently.
I really am starting to wonder why I gave Chrysler a second chance..
8E7DBC19-8141-4C0D-9CE8-FC898490BC6B_1557810251285.jpg   69CDE79B-22C7-4359-8BD4-286D142AAAC1_1557810271010.jpg
post #10 of 36 Old 05-14-2019, 06:08 AM
ColdCase
ColdCase's Avatar
2011 WK
There have been a few bad sway bar bushings reported here, usually you get a squeak or clunk over bumps. They are molded to the bar, so the book says to replace the bar. There is a alternative fix indexed in the maintenance sticky that replaces the bushings. Not an easy job but doable.
There are some heater hoses that run back to the firewall. I don't recall off hand where the drain hose for the cabin air intake/wipers and the HVAC housing (A/C condensed water) comes out. It may be in that area.
ColdCase is offline
post #11 of 36 Old 05-14-2019, 09:55 AM
ColdCase
ColdCase's Avatar
2011 WK
I don't think anyone mentioned the V8 MDS. Mine will vibrate a bit more when it kicks in cold, not so much when warmed up. Perhaps thats what you are feeling?
ColdCase is offline
post #12 of 36 Old 05-15-2019, 08:59 AM Thread Starter
simmons1183
While I do feel the MDS kick in as well, this is a different vibration. It is severe enough it rattles the windows and sunglasses in the console.
It is vehicle speed related, once I get up to highway speed, the vibration feels less severe, but has increased in revolutions. I would swear it was a tire/wheel if I didn’t swap them out already to check. Since acceleration makes it go away, only to return when letting off the gas, I am hoping it is just the front shaft. I also noted some light clunking this morning too.
I ordered the front shaft yesterday so hopefully it takes care of it. At least it’ll be an easier job than the rear shaft!
post #13 of 36 Old 05-16-2019, 07:03 AM Thread Starter
simmons1183
I noticed a few drops of dirty coolant on the ground again today. I could only trace it up to the passenger motor mount. I see zero trace of anything above it, but it’s being dropped on from somewhere above. I traced all lines and hoses coming off the radiator and all are dry. I guess I’ll have to start dissembling things to get to the source. Very odd.
post #14 of 36 Old 05-16-2019, 07:12 AM
ColdCase
ColdCase's Avatar
2011 WK
There is a UV die you can add to the coolant to make a leak easier to find. The motor mounts are filled with fluid, dunno if it resembles dirty coolant.
ColdCase is offline
post #15 of 36 Old 05-16-2019, 08:18 AM
LouC
2007 WK
If you have a V8 and the WK-II thermostat housing and stat is the same as on the WK-I what can happen is that the integral gasket of the stat, starts to leak a bit. There is no gasket between the thermostat neck and the water pump housing, it is part of the stat itself. I had this on mine and it was an easy fix once I got that gigantic air intake plenum out of the way. So you just replace the stat. Hope yours is that simple.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
Various Driveshaft Yokes/Flanges superheady Drivetrain 2 01-18-2019 03:14 PM
92 YJ 3rd driveshaft loss TReese1097 YJ Wrangler Technical Forum 11 10-10-2018 07:14 PM
Can I drive my Compass without the driveshaft? Sperron Jeep MK Compass & Patriot Forum 0 08-28-2018 10:25 AM
What is a CV shaft and why do I want one? Unlimited04 TJ Wrangler Technical Forum 175 02-23-2018 10:17 PM
Chasing rear driveshaft vibes ottomatic834 TJ Wrangler Technical Forum 1 12-09-2017 12:55 PM
