SERV 4WD Light - JeepForum.com
post #1 of 19 Old 05-02-2021, 10:23 PM Thread Starter
magik235
magik235's Avatar
1971 CJ5
SERV 4WD Light
I got the SERV 4WD light warning yesterday. I disconnected the control module to check connections. They were good. I disconnected the battery for 20 minutes. I used AlphaOBD to get the error code C2221 - Failure warning lamp 'ON' : Not requested. How does a warning lamp go on without a request?
1971 Jeep CJ5 - 2010 Jeep JK Wrangler Unlimited - 2011 Jeep Overland 5.7 Hemi
magik235 is offline
post #2 of 19 Old 05-03-2021, 06:44 AM
yzf125
yzf125's Avatar
2018 WK
Could it be a service feature reminder and not an actual issue ?
yzf125 is offline
post #3 of 19 Old 05-03-2021, 07:17 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
C2221 is a ELSD error, the ApphaOBD lookup data base may be in error, or thats what happens when a CAN message get garbled or a faulty module.
Description:
When the Drivetrain Control Module (DTCM) detects an incorrect Controller Area Network (CAN) message from the Electronic Limited Slip Differential (ELSD) Module.
Cause:
ELECTRONIC LIMITED SLIP DIFFERENTIAL (ELSD) MODULE DTCS
DRIVETRAIN CONTROL MODULE (DTCM)
So you may want to check the connection at the ELSD module. The module is underneath the left side of the rear seat. You may have to remove the seat to get at it.
AlfaOBD should be able to read ELSD module codes, does it see it?
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 19 Old 05-03-2021, 10:06 PM Thread Starter
magik235
magik235's Avatar
1971 CJ5
Is there a diagram showing the location of the various control modules?
magik235 is offline
post #5 of 19 Old 05-04-2021, 07:37 AM
ColdCase
ColdCase's Avatar
2011 WK
I don't recall seeing a good one that has all of them. The service manual would have locations of the individual modules. The online parts breakouts can provide clues.
post #6 of 19 Old 05-04-2021, 11:19 AM Thread Starter
magik235
magik235's Avatar
1971 CJ5
I could not find the ESLD module under the left rear seat. Could it be in the compartment under the driverís seat? I donít know what it looks like.
magik235 is offline
post #7 of 19 Old 05-04-2021, 11:27 AM
ColdCase
ColdCase's Avatar
2011 WK
Here is where it is suppose to be, under the rear seat on the driver's side. I have not physically checked, however.
post #8 of 19 Old 05-04-2021, 07:41 PM Thread Starter
magik235
magik235's Avatar
1971 CJ5
I can not find the module anywhere in the passenger compartment. I have the passenger side rear seat removed for a dog ramp so I have a good view of the underside of the driver's side rear seat. There is no module there. I felt around and it doesn't appear to be under the carpet. I have 3 modules in the compartment under the driver's seat but none of them look like your picture. I searched the web and can't find a picture, video or how to article.
magik235 is offline
post #9 of 19 Old 05-04-2021, 09:32 PM
ColdCase
ColdCase's Avatar
2011 WK
Hmm, You do have a 2011 USA Overland 4WD with the V8, right? What was the build date, I think QuadraDrive/ELSD was late availability. When you first get in to push the start, is it displaying QuadraDrive in the EVIC (between the speedo and tach)?
Just checking
post #10 of 19 Old 05-04-2021, 09:42 PM
ColdCase
ColdCase's Avatar
2011 WK
Did you check under the carpet?
post #11 of 19 Old 05-04-2021, 10:25 PM Thread Starter
magik235
magik235's Avatar
1971 CJ5
It is a 2011 USA Overland 4WD with the 5.7 V8. I don't know the build date. It displays Quadra-Drive II in the EVIC. I could not feel anything under the carpet or see any wires running in or out of the area.
magik235 is offline
post #12 of 19 Old 05-04-2021, 11:52 PM
ColdCase
ColdCase's Avatar
2011 WK
I took a look at mine, there seems to be a formed carpet bulge there where the module should be located. There's a small wire there through the carpet for the heated seats I think, but the three cables to the module run directly through the floor via a grommet. All located under the carpet.
post #13 of 19 Old 05-05-2021, 12:08 AM Thread Starter
magik235
magik235's Avatar
1971 CJ5
Thank you for your assistance. I appreciate it. I will have to remove the seat and check it this weekend.
magik235 is offline
post #14 of 19 Old 05-05-2021, 08:34 AM
ColdCase
ColdCase's Avatar
2011 WK
I think you may just have to unbolt the front four bolts and flip the bottom cushion up.
Screen Shot 2021-05-05 at 10.32.57 AM.jpg   Screen Shot 2021-05-05 at 10.34.59 AM.jpg
post #15 of 19 Old 05-07-2021, 05:48 PM Thread Starter
magik235
magik235's Avatar
1971 CJ5
I took my 2011 Jeep Overland 5.7 in to the dealership for my fuel pump relay recall. I asked them to check the 4WD system because of the warning light issue. It cost me $79.95. This is what was listed on my bill.
Service 4WD Light Is On
Light was not on when drove vehicle into shop
Checked codes - All stored codes - Activated 4WD through all modes and it shifted into all modes and set no codes
Working properly at this time
The counter person told me I didn't have to worry about the light as long as it didn't stay on. I told her when it goes on it stays on until I turn the Jeep off. She said as long as it doesn't stay on all the time it is OK.
I don't like lights that periodically go on because you never know if there is an important code being issued.
magik235 is offline
