Rough Idle at Start Up for two minutes - Then OK WK2 2012 CRD 3.0 - JeepForum.com
post #1 of 3 Old 07-31-2021, 05:35 AM Thread Starter
JerryGreene
JerryGreene's Avatar
Can't seemed to get to the bottom of this ? On warm days [26 c] alls fine but on days when say 18 c the idle is rough and if you drive off without waiting around 2 minutes hear a clamping sound? Now I loaded OBD Fusion app, and noticed at start up the Intake air temperature was recoding 52 c when the ambient temperature is 19 c. This cannot be .... This reading settles down after ten minutes to 24 c when at 19 c Ambient. I changed the MAYmade no difference ...... So what are your thoughts please on this one.
JerryGreene is offline
post #2 of 3 Old 07-31-2021, 06:59 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There are two intake temperature sensors, one in the Mass Air Flow Sensor and one in the Boost Pressure Sensor. Did you check/change both?
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 07-31-2021, 11:03 AM Thread Starter
JerryGreene
Thanks, did not know of the the Boost Pressure Sensor - Will investigate and update here.
