Rough Country Strut replacement lift kit owners... - JeepForum.com
post #1 of 12 Old 06-14-2021, 11:45 PM Thread Starter
camaroboi13
2017 WK
I'm looking for input on these for anyone who's successfully installed these or had them installed. There was a time when I was an ASE certified mechanic, so I'm no dummy when it comes to working on vehicles.
I purchased the $599 kit that replaces the whole strut assembly in the front, and comes with new shocks and springs in the rear. I started on the driver's side front. Tore everything apart, and replaced the strut. One of the new struts has an L on it, and the other has an R, any normal person would assume left and right. I attempted to install the one with an L on the driver's side, but nothing was lining up the way it should. The strut was laying right on top of the axle, and the Rough Country branded decal on the shock was facing inward towards the engine. Seems like a manufacturer would want to show off their brand by putting the decal facing outward towards the wheels. So I removed the strut and replaced it with the one that says R on it.
The strut lined up much better and allowed for more movement. I do notice however that the cv boot is slightly up against the clevis of the strut, and over time this will likely wear out and dump grease all over the place, prematurely destroying my axle. I MAY be able to get in there and move the boot just a hair to prevent this from happening, hard to tell just yet.
So on to the passenger side. I had a good idea what I was doing after many failed attempts on the driver's side. The passenger side took me 28 minutes to completely disassemble, and with the help of a ratcheting strap to bring the upper control arm to the steering knuckle, I was in and out in roughly two hours. Lastly, the sway bar...
I left the sway bar unbolted on both sides because I figured I'd do that last. The sway bar was so out of place that it would not allow the end links to be installed. I loosened the sway bar bushings to the point of being finger tight. The sway bar should be able to move very freely at this point. Not the case. Even with me on one side and my buddy on the other side, we could not pull hard enough to get the sway bar to drop or even budge for that matter. I literally had to pull my wife's Jeep to the bottom of the driveway and put her winch on the bar just to get it to move down. I finally got it low enough to put the links back on, but now they're in really funky angles. Bad enough to the point of binding on the tie rod ends from time to time. I know this can't be right, but I'm at a loss as to how to solve the problem. I'll post up pics tomorrow of what I'm looking at. Maybe someone here has run into this issue and can advise me of what I may be doing wrong.
camaroboi13 is offline
post #2 of 12 Old 06-15-2021, 05:18 AM
emacca
Sounds like you have the wrong kit, can you google the part numbers on the packaging and check
Or even photos may help
emacca is offline
post #3 of 12 Old 06-15-2021, 06:59 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There may be a couple threads in the modification or build stickies that could help. They moved the sway bar attachment point in 2016, I think. It does sound like you got the wrong parts.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 12 Old 06-15-2021, 07:02 AM
222Doc
222Doc's Avatar
china made....................
222Doc is offline
post #5 of 12 Old 06-15-2021, 11:36 AM Thread Starter
camaroboi13
2017 WK
Kit number 91430, the system won't let me post images just yet but I'll get those up later today.
post #6 of 12 Old 06-15-2021, 11:38 AM Thread Starter
camaroboi13
2017 WK
The parts I have are the correct ones. The struts I removed from the vehicle had ears with mounting holes for the sway bar end links. The struts I replaced them with have ears with mounting holes for the sway bar end links. The wrong parts would not have these ears on them.
post #7 of 12 Old 06-15-2021, 11:39 AM Thread Starter
camaroboi13
2017 WK
Not everyone is willing to pay a fortune for "american made" either.
post #8 of 12 Old 06-15-2021, 12:53 PM
ColdCase
ColdCase's Avatar
2011 WK
The bushings are molded to the sway bar, the bar won't spin in the bushing unless they are broken.
Most choose OME as, well, it seems you get what you pay for in this case. I've seen dozens of reports of RR struts leaking at 10,000 miles. But you can always replace them with Bilstein or other aftermarket units..
post #9 of 12 Old 06-15-2021, 03:54 PM
emacca
Sorry but if the parts are the correct ones as you state then why are you posting you have a problem.
Either they are the wrong parts or they have been incorrectly fitted.
As noted, and there is a “sticky” on the topic, there were difference in the front struts around 2015, or 2016 ( I’m not sure )
My thoughts would have been to lay each strut out alongside the original before installing and by so doing confirm it is the right side.
As an example I had bilstein struts for a Mazda that were clearly marked left and right, but on inspection they fitted the oppersite to marked sides
emacca is offline
post #10 of 12 Old 06-15-2021, 10:06 PM Thread Starter
camaroboi13
2017 WK
Thumbs down
It's 2016+ and mine is a 2017. The parts are correct, there's only two struts available from RC. Struts without ears with holes for sway bar end links, and struts with ears for sway bar end links.
I started with the driver's side first, unbolted the original strut, and put the strut with the L back on the driver's side. It did not fit right, so I swapped it out with the strut that said R. This strut actually went in place like it should. So both struts were fitted to the driver's side. One did not fit at all, and the other one has funky angles on the end link.
Why am I posting that I have a problem? Because I have a problem. That's why I'm looking for people who have installed these struts correctly in order to see what I am missing. Sometimes all it takes is just looking at another vehicle to figure out where I went wrong in my installation.
Apologies for not getting photos up, it was 109 degrees today and my garage was probably close to 120. A little rough trying to get out there and work on getting pictures. It's supposed to be 112 degrees tomorrow. I'm not winning in the automotive world this week
post #11 of 12 Old 06-15-2021, 10:07 PM Thread Starter
camaroboi13
2017 WK
Thank you for clearing that up, never seen bushings molded to a sway bar before. So in this case, if you rip a bushing, you replace the whole sway bar?
post #12 of 12 Old 06-16-2021, 07:23 AM
ColdCase
ColdCase's Avatar
2011 WK
Thats the official way, and the way a shop would do it. But if it isn't noisy you may well leave it be. If it squeaks, there is a thread indexed in the maintenance sticky where someone pried apart the mount and replaced noisy bushings.
