Random cold air coming out vents ?? - JeepForum.com
 3Likes
  • 1 Post By Etced
  • 1 Post By IDoMy0wnRacing
  • 1 Post By Homer1
post #1 of 14 Old 07-04-2021, 05:49 AM Thread Starter
yzf125
yzf125's Avatar
2018 WK
Hey guys, I have an issue where cold air will randomly come out the vents. I would have the outside airflow coming through the vents, Then out of nowhere, I feel this cold air come out as if I turned the AC on !! Anyone ever have this issue ??
yzf125 is offline
post #2 of 14 Old 07-04-2021, 11:48 AM
Etced
I have a 2021 GC that does the same thing. With the ac off it will blow ice cold air out the vents randomly.
yzf125 likes this.
Etced is offline
post #3 of 14 Old 07-04-2021, 12:23 PM Thread Starter
yzf125
yzf125's Avatar
2018 WK
I wonder what causes this ?? Its very annoying !!!
yzf125 is offline
post #4 of 14 Old 07-04-2021, 08:17 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Perhaps it the fresh air thing, every once in awhile the HVAC brings more fresh air in. Been a few discussions. Seems quite a bit of variability between Jeeps. Mostly is a complaint about warm/hot air, however.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 14 Old 07-04-2021, 10:15 PM
diverscale
mine does the same with hot air during summer. Out of nowhere it's like the A/C turns off, and humid summer air gets in and recycle is off. Then after 10 seconds, cold normal.
Coldcase said it was some fresh air ''philosophy'' by jeep, and it's on a 2020. I just analysed that behavior as being something programed in the ECU, for whatever reason (preventing mold and odor in the a/c conduits maybe.)
diverscale is offline
post #6 of 14 Old 07-05-2021, 04:52 AM
Comanche_88
1988 MJ Comanche
My 2018 does the same thing and has since new. I like to use just the vent in the spring and fall and find it annoying when my Jeep makes the decision to run the AC. I have found I can combat this somewhat by adjusting the temperature slightly when using the vent.
Comanche_88 is offline
post #7 of 14 Old 07-05-2021, 07:22 AM
Etced
On any other vehicle that I ever owned, when the AC button is off the AC never ran unless it was in defrost mode. They try to save a small amount of fuel with the auto start stop system, but what about the wasted fuel running the AC when not needed.
Etced is offline
post #8 of 14 Old 09-12-2021, 05:20 PM
AlumaDoo
Im late to the topic, but posted this same issue. Beyond annoying to have the vehicle to run the A/C when IT wants to. If anyone has found a solution yet, Id love to hear about it. Nice 65* day today, would love to just have some fresh air without the A/C on or the windows down.
AlumaDoo is offline
post #9 of 14 Old 09-12-2021, 06:29 PM
ColdCase
ColdCase's Avatar
2011 WK
Did you try the steps posted in your thread https://www.jeepforum.com/forum/f309...vents-4442267/
ColdCase is offline
post #10 of 14 Old 09-12-2021, 07:54 PM
IDoMy0wnRacing
IDoMy0wnRacing's Avatar
2020 WK
Using the humidity sensor mounted on the windshield (little box mounted next to the rear view mirror); the HVAC system will kick on the A/C at times to prevent "misting" by removing moisture from the air.
Homer1 likes this.
Very Respectfully
Ed
Going fast is only half the fun... You get to build it first.
IDoMy0wnRacing is offline
post #11 of 14 Old 09-17-2021, 07:56 PM
Nydamon
Nydamon's Avatar
It’s the only annoying thing I’ve found on my Jeep. It’s not quite blasting cold when the AC is on and it’s 95F out but there’s that retarded cold cycling when the AC is off and it’s 60F outside.
2020 GC Limited 3.6L White/Lt Frost: Luxury Group II, Tow Group, ProTech II, Lighting Group
Nydamon is offline
post #12 of 14 Old 09-18-2021, 08:13 AM
Homer1
Homer1's Avatar
This sounds right....i've noticed on certain days condensation would start to form inside bottom of windshield, then would disappear for a bit, then return, then disappear over and over...
IDoMy0wnRacing likes this.
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
1997 GC Limited Beach Buggy (Deceased....RIP)
Homer1 is offline
post #13 of 14 Old 09-18-2021, 10:19 AM
Nydamon
Nydamon's Avatar
Makes sense so I’ll quit whining about it. I love my GC, especially the butt coolers!
Nydamon is offline
post #14 of 14 Old 09-18-2021, 12:49 PM
Homer1
Homer1's Avatar
Ha! My wife doesn't need it...her side of the water bed is frozen! (Rodney Dangerfield)
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
Homer1 is offline
