Question on 2019 JGC Heater Operation - JeepForum.com
post #1 of 4 Old 02-25-2019, 07:57 AM Thread Starter
yamon
2019 WK
Hi Forum
I am curious about the correct heater operation on my new 2019 JGC HA and would appreciate some input.
When the heat is set to manual (not auto) say at 72degress with the outside temp at 30 degrees, with the vent direction set to blow towards your feet. After the car warms up it will intermittently blow cool (much cooler than 72 degrees) air through the dash vents (vents pointed at the driver and passenger). It will do this every10 minutes or so for 3-4 minutes.
This chills both the driver and passenger and does not seem to make any sense. If the heat were on auto this could happen but I do not think it should on manual. The Jeep has 2,000 miles on it and I just started noticing this phenomenon recently.
Does your JGC do this?
Thanks in advance for your input.
yamon is offline
post #2 of 4 Old 02-27-2019, 08:11 AM
Fast55
Fast55's Avatar
2017 WK
I can't imagine it would be different for any of the newer models and my '17 doesn't do that. I will say I don't think the HVAC system is very accurate and seems to put out a lot of heat as it approaches the temp setting you select and tends to overshoot your set point before settling down and controlling to temperature. Just the fact that it decides to blow air through the dash when you've manually selected floor only leads me to believe you have a problem. I'd see your dealer about it.
2017 Trailhawk
Active Safety, Luxury group, Blind spot detection
Hemi
Rock Rails, Chief Products
Fast55 is online now
post #3 of 4 Old 02-27-2019, 10:10 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Originally Posted by yamon View Post
Hi Forum
Hi yamon,
We are sorry that you are experiencing this. We suggest making an appointment with your dealer so that your Jeep can be diagnosed. If you would like any additional assistance during this process, feel free to send us a private message.
Alex
Jeep Social Care Specialist
JeepCares is online now
post #4 of 4 Old 02-28-2019, 07:43 AM Thread Starter
yamon
2019 WK
Thanks to you both - I will have the dealer check it
yamon is offline
heater core and blend door replacement question terrible WK Grand Cherokee & XK Commander Forum 1 01-19-2019 05:46 AM
2019 Cherokee Uconnect question spinxt KL Cherokee 2014 & up 7 11-19-2018 07:06 AM
Heater control cable question cdt540 Jeep CJ Forum 3 03-07-2018 12:49 PM
Just did a heater core in my 98 - question about thermostats 8v-of-fury ZJ Grand Cherokee Forum 16 01-04-2018 01:48 PM
Heater core hose replacement question. thekooties WJ Grand Cherokee Forum 6 11-29-2017 11:45 PM
