QL Leveling/Lift Options - JeepForum.com
 4Likes
post #1 of 16 Old 08-16-2016, 08:58 PM Thread Starter
LostChord
Hello all - first time poster. Have been reading up on the WK2s as we're seriously considering one for my wife. She has been in 3 different suburbans for nearly 20 years and now that we're past that stage, she's ready to be in something smaller and the GC is currently at the top of the list.
Can someone explain (or point me to threads that explain) what options are available for leveling and/or lifting a WK2 with QL. I have searched, but so far found that kits like RRO do not work with QL. (The two GCs we have our eyes on both have QL.)
Leveling and/or lifting the Jeep is not a deal breaker one way or the other, just trying to understand as much as I can before we pull the trigger on a particular model.
Many thanks!
Sent from my iPad using Tapatalk
LostChord is offline
post #2 of 16 Old 08-16-2016, 09:41 PM
carleycr
2014 WK
For leveling QL you can either replace the small links in the front or rear, depending which direction you want to level. Raise the front, or lower the rear. There are some posts on this forum discussing this. The other, more expensive, option is a small module called Llams kit. Google it. Should be first link. It runs around $350. Comes from a down unda! You can email the guy that makes them from the website for more details. Not sure if they'll work for 2017, but do work for 2016. Good luck on the hunt.
2016 JGC Overland EcoDiesel - Loaded
Slow transition to black on white theme
carleycr is offline
post #3 of 16 Old 08-16-2016, 10:39 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah, the only way to lift the QL is to trick it via its height sensing either via adjustable links or the Liams box which simulates the hight sensors. Basically the QL control is integrated with traction control and PCM modules and no one has figured out how to hack it without fault codes. The amount of safe and practical adjustments is relatively small, but certainly enough to level, if you like that look. Lifting in this manner will make the ride stiff, perhaps uncomfortable. I don't know of anyone making spacer kits for QL air bags.
If you try to make significant adjustments, you could easily burn out the compressor as the system tries to fight through the bump stops. There are certainly female gear heads that would understand, but I wouldn't trust my spouse with it if set to more than a half inch or so. These adjustment devices work much better lowering than lifting.
If you want full time lift, its best to start with a steel sprung model. At least a couple here have replaced the steel springs with air springs and added a compressor and controller that provides a significant amount of problem free adjustment capability.... if you want to go that route. A characteristic you should consider, these "airbag" type adjustable suspensions change ride height by stiffening the spring rate, so in the lifted position it will ride rough. These are really useful in the lowering application, however.
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 16 Old 08-17-2016, 07:27 AM Thread Starter
LostChord
Thank you both! Generally, I gathered that it was not a straightforward approach, but thought I'd check here the experts. Thanks again!
On with the hunt.
Sent from my iPhone using Tapatalk
post #5 of 16 Old 08-17-2016, 11:01 AM
The GrooGrux King
Unfortunately, there is not a way to properly life the WK2 with QL. When purchasing our WK2 last year, we ended up ordering a Limited with the Overland interior options so we could have non-QL.
Here's a pic with the 2.5" RRO and SpiderTrax 1.75" wheel spacers on 33x12.50x20s.
The GrooGrux King is offline
post #6 of 16 Old 08-17-2016, 01:53 PM Thread Starter
LostChord
Wow! - that looks great!
The GrooGrux King likes this.
post #7 of 16 Old 08-17-2016, 02:24 PM
The GrooGrux King
Thanks man!
post #8 of 16 Old 08-18-2016, 12:55 PM
Billscarnage
^ Pretty much this.
It seems like Jeep is really pushing QL on models with QTII or higher (QD) or any "off-roading" capability.
2015 GC | Lux II | Trailer Tow Group | ORAI | Uconnect 8.4N
Billscarnage is offline
post #9 of 16 Old 08-18-2016, 01:22 PM
jim_in_PA
2012 WK
Jeep's premise is that QL provides the most flexibility for the "majority" of buyers. It's not ideal, however, for folks who want to do things like lifted builds, etc.
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #10 of 16 Old 08-18-2016, 10:08 PM
2001WJv8
2015 WK
that's exactly why i bought QL - i put it places most wrangler owners never bother to go, but in reality the vast majority of miles are interstate, so having a vehicle that lowers for mpg's, or raises for offroad, by the push of a button is perfect.
i like the way they look lifted, but I love the way they drive stock ... took me over 2 decades to decide which one was better
jeradyjerin likes this.
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #11 of 16 Old 08-19-2016, 05:04 PM
jim_in_PA
2012 WK
I love my QL for the same reasons, 2001', but I'm also loving it lowered about an inch with alternative sensor links because of some physical issues I've developed. It makes getting in and out a lot easier for me...in Park level, it seems lower than my better-half's Outback for "step-in".
post #12 of 16 Old 08-19-2016, 06:30 PM
2001WJv8
2015 WK
i hear you, my mom has major back issues among other things - she loves her suby forester for the reason that she can just turn and sit down. Like I said, love the wk2's lifted - totally badass - but i'm finally at a point where comfort > coolness I guess. not a fan of the banging noises in orII max height, but once you realize you aren't destroying your jeep, all is good again - and damn if it can't get over some good stuff in that setting. I took it about a month after I got it on a trail that I wouldn't have taken my wj at 4" (terfaflex s4w lift) or even the cj7 (mostly b/c I wasn't sure what would break ... but it could've made it) . anyway, wk2, no damage at all - didn't even scrape my RR's and that was a big surprise.
again, I'm not talking crazy rock crawling JK stuff - but way beyond what most of these or wranglers will ever see. i think it's a pretty cool system so far, and the ride on the superslab at 90mph is astounding. that is why I love the QL. maybe I'll get a JK someday for my replacement lifted/badass rig (yeah, I probably will...)
2001WJv8 is offline
post #13 of 16 Old 08-19-2016, 07:38 PM
jim_in_PA
2012 WK
The best way to leverage the OR-II height off-road is to stay in OR-I unless and until you need to clear an obstacle that requires that extra inch or so to negotiate. There's no way to get around the fact that there's almost no suspension travel left at that height and even at the >25mph speed restriction, things can get uncomfortable when you hit a bump. Nature of the beast. Since the suspension is adjustable on the fly, one can use that to alleviate hitting the stops a good part of the time.
post #14 of 16 Old 08-20-2016, 10:47 AM Thread Starter
LostChord
Thanks guys - appreciate all the different perspectives. Good stuff!
post #15 of 16 Old 08-20-2016, 02:04 PM
2001WJv8
2015 WK
anytime - basically if you want to lift it (or might want to someday), stay with a steel sprung jeep
if you don't want to lift it, but want to off road yet maintain a high quality ride then I'd definitely suggest quadralift.
or if money is no object ... see thread re: white rhino holy xxxx that is a badxxx jeep!
Z-Thad likes this.
2001WJv8 is offline
