Push Start Stalling Out - JeepForum.com
post #1 of 15 Old 08-19-2019, 04:14 PM Thread Starter
muzicman82
2011 WK
Hi all, my 2011 Laredo has stalled out immediately after starting about 1/5 times immediately after starting it, probably since I got the thing. It will always start right up on the 2nd try.. And I'm sure it isn't a battery thing. What else should I be looking at? It does it the most when it is cold.
Sent from my SM-G950U using Tapatalk
2011 Jeep Grand Cherokee Laredo - 3.6L V6
158,000 (10/2018)
1996 Jeep Grand Cherokee Limited - 5.2L V8
366,700 miles (4/21/12) (Laid to rest, but worked)
muzicman82 is offline
post #2 of 15 Old 08-19-2019, 05:27 PM
Bilko
It sounds like the same problem i had on my 2012 Is your check engine light on?
https://www.jeepforum.com/forum/f309...p0572-4332905/
Bilko is offline
post #3 of 15 Old 08-21-2019, 07:53 PM Thread Starter
muzicman82
2011 WK
No it isn't on.. and I have a ScanTool and no codes are there. I've had the vehicle for 6+ years and it has always done it from time to time. I did replace the battery a couple years ago and it did it on that brand new.
158,000 (10/2018)
post #4 of 15 Old 08-21-2019, 10:41 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Check/replace the brake switch. It usually doesn't throw a code, or at least one you can read with the typical OBD scanner.
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #5 of 15 Old 08-22-2019, 06:19 PM Thread Starter
muzicman82
2011 WK
Wouldn't I have other issues if this was the issue? Like brake lights and the vehicle not starting at all?
158,000 (10/2018)
post #6 of 15 Old 08-22-2019, 06:57 PM
ColdCase
ColdCase's Avatar
2011 WK
Its a multi contact switch, one contact feeds the brake lights, another contact feed the cruise control and start.
No guarantees, but its a inexpensive fix thats worked for some.
post #7 of 15 Old 08-23-2019, 08:59 AM
Jlow28
You checked the fuel pump relay? After the recall on my 13, I had to order a new external relay recently after a start / stall. Interesting information on the brake stop switch.
Sent from my iPhone using Tapatalk Pro
Jlow28 is offline
post #8 of 15 Old 08-26-2019, 01:14 PM
madmaxwell87
2012 WK
I replaced this to try to solve this issue for my 12 Overland Hemi and it is still doing it. If you only use the remote start it is never an issue. I have heard it could be the TPIM which is a big and expensive job. Hadn't heard about the brake light switch so I'll look into that too.
12 WK2 Overland 5.7L. 18x9 Procomp Rockwell, 265/65/18 BFG AT, Chief tow point, RC light bar
madmaxwell87 is offline
post #9 of 15 Old 08-26-2019, 05:23 PM
Bilko
if its the brake light switch you may also find you can start the engine without pressing the break pedal
Bilko is offline
post #10 of 15 Old 08-27-2019, 09:53 AM Thread Starter
muzicman82
2011 WK
I don't have remote start and I have never been able to start it without pressing the brake pedal.
158,000 (10/2018)
post #11 of 15 Old 08-28-2019, 11:40 AM
Bilko
Have you had the fuel pump relay recall done? It was recall P54. If so it's worth changing the relay, they are only a few dollars and easy to do.
Bilko is offline
post #12 of 15 Old 08-31-2019, 05:33 PM Thread Starter
muzicman82
2011 WK
As far as I know, all recalls were taken care of about a year ago with the dealer.
158,000 (10/2018)
post #13 of 15 Old 08-31-2019, 07:00 PM
ColdCase
ColdCase's Avatar
2011 WK
The relay they install via the recall doesn’t seem to be durable. Its easy and cheap to replace, may solve your issue. There is a thread around here somewhere with relay suggestions.
post #14 of 15 Old 09-02-2019, 05:43 AM
GPV1
GPV1's Avatar
2012 WK
Having the same issue on my 2012. It's very intermittent and usually on a warm restart, it will fire just fine then start running very rough and stall after a few seconds. Restarting solves the issue. I picked up a new fuel pump relay and will try that, my dealer replaced the brake switch about 15,000 miles ago while troubleshooting an unrelated issue so I'm ruling that out for now.
GPV1 is offline
post #15 of 15 Old 09-04-2019, 12:06 PM
=KZ=
I have the same problem with push start, but no problems at all using the key. Are you supposed to have to put your foot on the brake to start with the key? Mine starts with the key without touching the brake.
=KZ= is offline
