Problems at the pump? - JeepForum.com
 6Likes
post #1 of 64 Old 12-18-2018, 11:39 AM Thread Starter
foreWard
foreWard's Avatar
2018 WK
OK. I have had my 2018 GC Trailhawk for a week now and have only filled up half a tank. My problem is it was a PITA to fill it because the auto fill kept cutting it off, I had to manually hold it at 60% speed for it work. I am about to head over and fill it up for the second time. Am I going to have this headache for the entire time I have this car? This is my first experience with the capless fuel tank and I am worried. Any one have this issue, or did I (hopefully) catch a bad pump at the station.....
Thanks!
4th Jeep : 2018 WK2 Trailhawk - black/black - SRT Reps - 275/55/20 Falken at3ws - leveled
foreWard is offline
post #2 of 64 Old 12-18-2018, 12:18 PM
kabjeep
2018 WK
Ive had this problem occasionally, Rotate the pump 180 degrees so the handle is pointing upwards, that seems to make it not cut off.
kabjeep is offline
post #3 of 64 Old 12-18-2018, 12:44 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There has been a lot of discussion on the topic, you are far from being alone. Seems that it varies from pump to pump. As mention, turning the nozzle upside down can help, but I think there may be a fix/tip arround here somewhere.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 64 Old 12-18-2018, 03:16 PM
andyo5
2018 WK
I have a 2018 Limited. I have not had this problem.
andyo5 is offline
post #5 of 64 Old 12-18-2018, 03:58 PM
oldmac1
2018 WK
I try to use the pumps that have worked well for me. Some of those auto fills do exactly the same as yours if I use them. Plus I have to make sure my gas nozzle is fully pushed in snug for it to work on most pumps. Good luck to you.
Oldmac1
18 High Altitude
12 Liberty
15 Rubicon Unlimited
oldmac1 is offline
post #6 of 64 Old 12-18-2018, 04:30 PM
Hihocarp
Does the GC have 2 flaps in the filler hose like my 16 Ram Diesel with the capless setup? I know that the pump nozzle has to be all the way in for it not to keep shutting off.
Hihocarp is offline
post #7 of 64 Old 12-18-2018, 07:49 PM
lexrid
2017 WK
I have the same problem occasionally with my 2017 Overland. It only seems to happen at two of the nearly 20 pumps at the gas station I frequent. It would seem like I would remember which pumps to avoid but inevitably it seems like I end up at one of those pumps once a month...
lexrid is offline
post #8 of 64 Old 12-18-2018, 09:56 PM
Raptor
For your fueling issues try flipping the pump nozzle upside down while you fill your tank. The capless gas tank EVAP fuel flap spring mechanisms needs to be "broken in" that's why the fuel flow keeps stopping. Inserting the nozzle upside down will extend the capless EVAP fuel flap mechanism springs further allowing fuel to flow freely. As these springs stretch with use that issue should go away.
Raptor is offline
post #9 of 64 Old 12-19-2018, 05:50 AM Thread Starter
foreWard
foreWard's Avatar
2018 WK
Thanks everyone. Filled up at a different pump yesterday, no issues. I will try the upside down thing if I ever have the problem again. But at least I know it wonít happen every time!
foreWard is offline
post #10 of 64 Old 12-22-2018, 07:25 AM
Rsimionas
I had this problem and took it to the dealer. They replaced a part at the top of the tank, forgot what is called and never had the problem again. It’s a common issue with the grand Cherokee I was told.
Rsimionas is offline
post #11 of 64 Old 12-22-2018, 09:01 AM
jacko15
2014 WK
Must be fixable, I've never encountered this problem. I've filled my tank all around the Great Lakes, New England, Canada, and never had an issue with the pump shutting off before my tank filled.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #12 of 64 Old 12-22-2018, 03:12 PM
JM887
2018 WK
My 2018 with capless fill does the same at about half the pumps I try. Like others have said if flip the nozzle upside down it will work. I just don’t like the strange look I get from some people when I do it.
JM887 is offline
post #13 of 64 Old 01-01-2019, 08:53 AM
345hemi
2018 WK
Originally Posted by Rsimionas View Post
I had this problem and took it to the dealer. They replaced a part at the top of the tank, forgot what is called and never had the problem again. Itís a common issue with the grand Cherokee I was told.
Was it done as a no cost warranty repair?
345hemi is offline
post #14 of 64 Old 01-01-2019, 04:42 PM
dhasselbacher
2015 WK
My 2015 Summit has done this several times but usually only at select Costco gas pumps at the location we shop at regularly here in Redwood City, CA. I've fueled up at many other gas stations and even other Costco stores and no problems.
I've noticed usually the Costco pumps I've had issues with work better if I pull up to the pumps that are on the opposite side of the fuel filler door, and stretch the hose across the back of the vehicle. The pumps on the same side as the fuel door are where I've had issues, but again, only at select pumps at our favorite Costco store.
I didn't realize there is a possible fix for this so maybe I'll ask the service advisor at my next appointment.
dhasselbacher is offline
post #15 of 64 Old 01-22-2019, 05:38 PM
345hemi
2018 WK
I have this problem also. I took it to the dealer and was informed Jeep had issued a bulletin about the problem. They replaced the gas tank on warranty. Two fillips since the tank was replaced and still have the problem. I am to take it back when I get low on gas again.
345hemi is offline
