Oil leak - JeepForum.com
post #1 of 3 Old 01-24-2020, 06:34 PM Thread Starter
Stochmal52
Stochmal52's Avatar
Oil leak
2012 Laredo with 150k on the odometer. It’s wet from the oil pan back to the transfer case. I wiped it down and started it up and let it run for a good 20-30 minutes. No inclination on the origin in the leak. Loses about a quart every thousand or so. What’s a common failure at this point on these vehicles, seal wise?
Stochmal52 is offline
post #2 of 3 Old 01-24-2020, 10:32 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There have been quite a few reports of the oil fill/filter housing cracking and leaking. Not a pleasant job to replace.
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 01-25-2020, 01:09 PM Thread Starter
Stochmal52
Stochmal52's Avatar
The cartridge filter housing? All plastic I assume? My buddy did do the previous oil change on the Jeep because I was deployed. Maybe he over tightened it.
It does seem like it’s coming from the top side. The bell housing is wet as far up as I can see from underneath.
