Oil Filter Housing - JeepForum.com
 6Likes
  • 1 Post By ColdCase
  • 1 Post By JeepCares
  • 1 Post By 0f02r
  • 2 Post By ColdCase
post #1 of 14 Old 10-12-2019, 07:25 AM Thread Starter
DerekWildstar
Oil Filter Housing
Ugh. Count my 2014 JGC Limited as another victim of the plastic oil filter housing problem. We noticed oil spots on the floor of our garage about a week ago. I figured it was from my 2012 Accord thatís got over 140,000 miles on it... but a trip to the Honda dealer confirmed that no, that engine is bone-dry on the outside. We turned our attention to the Jeep, and it turns out that the oil filter housing is cracked. From what Iíve read, the part before 2014 was metal, but was redesigned to plastic in our model year. The replacement part ($800 later) will also be plastic, and I wonder if this problem will simply recur once again?
Iíve never had a car leak oil with only 40,000 miles on it. Sigh...
2014 Jeep Grand Cherokee Limited
2012 Honda Accord EX-L V6 coupe
DerekWildstar is offline
post #2 of 14 Old 10-12-2019, 07:50 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I think they were plastic in all years, earlier models had bypass valve problems. Its fairly common to crack them by over tightening. If you or your grease monkey don't abuse it, it should last. The part was revised for 2014 but it also seem to be a bad year for these cracks, until they revised the part again.
DerekWildstar likes this.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 14 Old 10-14-2019, 12:08 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hello! I just responded to your private message. Please take a look.
Kaitlin
Jeep Cares
JeepCares is online now
post #4 of 14 Old 10-15-2019, 07:41 AM Thread Starter
DerekWildstar
Kaitlin
Jeep Cares
Thanks for the outreach! I PM-ed you back!
post #5 of 14 Old 10-15-2019, 12:18 PM
Jurassic_Jeep
2014 WK
I get all my service and maintenance done at the dealer, and one time they also cracked my oil filter housing. Saw droplets of oil on my garage floor (over the course of days), and they replaced the broken part and shampooed my engine.
2014 Jeep Grand Cherokee Summit 4x4 3.6L V6.
Jurassic_Jeep is offline
post #6 of 14 Old 10-16-2019, 04:07 PM
0f02r
After reading of the possibility of a cracked housing...I bought one...just in case I cracked the one I have (I change my own oil). I believe having a back up greatly reduces the odds of cracking your housing...maybe reverse Karma...donít know but I have seen this relationship before...
0f02r is offline
post #7 of 14 Old 10-16-2019, 05:11 PM
ColdCase
ColdCase's Avatar
2011 WK
Thats good insurance, I have a garage full of just in case parts, some for Jeeps long gone To replace a cracked filter housing by the book, the intake manifolds needs to be removed. That is a relatively big job on this V6. Its not so much the $100 part, its the hours of labor.
ColdCase is offline
post #8 of 14 Old 10-17-2019, 09:18 AM
2017jgc
Junior Member
2017 WK
WHAT is part that cracked? The Item 1. - 68308741AB adapter housing or the Item 2. -68191350AA cap?
For 3.6L V6 engine:
https://www.moparpartsgiant.com/part...agram=i2355931
Alfisto Steve
2004 JGC Overland WJ and 2017 JGC Limited WK2
Gone but not forgotten 1996 JGC Laredo
2017jgc is offline
post #9 of 14 Old 10-17-2019, 10:52 AM Thread Starter
DerekWildstar
For 3.6L V6 engine:
It was the adapter housing (741AB).
post #10 of 14 Old 10-17-2019, 08:04 PM
09JeepCommander
2015 WK
So, how hard is this to fix?
2015 GC Laredo
"I've got an appetite for destruction, and I scrape the plate."
09JeepCommander is offline
post #11 of 14 Old 10-17-2019, 09:22 PM
ColdCase
ColdCase's Avatar
2011 WK
Its tedious sometimes challenging as the intake manifolds need to come off and there are plenty of things connected to them. Once the manifolds are off its pretty straight forward. You also have to remove the manifolds to change spark plugs, and there are a few threads that discus it. How hard it is depends on if you are a tech or a backyard DIYer. Once you've done a couple, its not bad. But there are a couple bolts that require some skill and dexterity to loosen. The right tools help a lot.
emacca and DerekWildstar like this.
ColdCase is offline
post #12 of 14 Old 10-18-2019, 02:30 PM
2017jgc
Junior Member
2017 WK
I see that I am gonna have to learn this new to me 3.6L 24v V6 PUG engine and the body attached to it. I have been mainly maintaining Alfa Romeo 164 3.0L 12v engines and the attached car bodies since 1991.
Those Busso designed engines as something else and came out in the 1970s. I have maintained my 1991 ones for over 29+ years and I have done pretty well.
I have learned a lot about our 04 WJ overland V8 and the attached body but have not had to go into the deep end of the pool very often yet.
Alfisto Steve
2017jgc is offline
post #13 of 14 Old 10-19-2019, 02:15 PM
Rich Z
2019 WK
This is one of the reasons I purchased the lifetime warranty on my Wrangler. Of course, since I change my own oil and filter and torque everything to spec, even if the base cracks due to degradation, they will likely claim that I caused the failure and not cover the repair.
2019 Jeep Grand Cherokee Trailhawk
5.7l Hemi
White exterior, black interior
Rich Z is offline
post #14 of 14 Old 10-20-2019, 02:43 PM
GregK340
2017 WK
I had to look into this a few years ago, when that part broke on my daughters vehicle. replacement was kind of a PIA, but easily done in an afternoon. The problem on the earlier (2013 and older) was the oil by-pass valve would break off. and some people got these covered by the powertrain warranty. But a cracked housing might be harder to get under warranty. (unless the dealer did it.)
GregK340 is offline
