OEM Tow Hook Hardware, Anyone Fab Front Mounting Spacers? - JeepForum.com
post #1 of 6 Old 03-01-2021, 02:01 PM Thread Starter
Mr. Hotwheels
I have everything else. Doesn't look like Mopar sells the front spacer mounting hardware. Has anyone fabricated spacer blocks for this application?
Thanks!
Mr. Hotwheels is offline
post #2 of 6 Old 03-01-2021, 02:47 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You would think that in the 7-8 years that this has been a problem that Rough Country would have picked up on this. It looks like a couple pieces of bent metal and a spacer. Doesn't seem to have much load bearing.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 6 Old 03-02-2021, 03:22 PM
Steve936
Steve936's Avatar
I was about to but then I saw people using a washer stack. So thatís what I did.
02 TJ stretched, 37ís
96 XJ locked 33ís
94 YJ Buggy, tons 39reds
16 WK2 32ís
Steve936 is offline
post #4 of 6 Old 03-02-2021, 04:26 PM
ColdCase
ColdCase's Avatar
2011 WK
I was thinking the plates were for reinforcing the thin metal in that area, so you may want to keep an eye on it when you put a lot of stress on the hooks.
ColdCase is offline
post #5 of 6 Old 03-11-2021, 05:13 PM
ColdCase
ColdCase's Avatar
2011 WK
Chief has recovery hooks that look like the real deal.
https://usa.chiefproducts.com.au/pro...-recovery-hook
https://cdn.shopify.com/s/files/1/02...90695766199241
ColdCase is offline
post #6 of 6 Old 03-16-2021, 05:15 PM
Steve936
Steve936's Avatar
Iíve seen those mounts in person. Theyíre so thin and only tack welded on. They seem to act as a spacer only, working to keep the hooks level. I had a few people familiar with fab work and loads and they were ok with the washer stack as long as I used enough to keep the hooks level as if that thin spacer was there.
If you look at the components, you can see the bigger brackets that actually hold the hook, are much more beefy and heavy duty. And the bolts designed to hold the hooks on that bracket are larger and beefier. Thatís where your stress from using the hooks would be placed.
96 XJ locked 33ís
16 WK2 32ís
Steve936 is offline
