Odd brake lights on while running and no dummy lights problem. - JeepForum.com
post #1 of 9 Old 01-25-2020, 01:18 AM Thread Starter
haschebrown
haschebrown's Avatar
My wife's 2012 grand has the brake lights continuously on but only when running. The key fob will work in all ways except when trying to remote start it. It gets the signal but won't start it. The battery reads 12.6 volts. When in the car It will go thru the accessory then run sequence with no brake pedal depressed but when you hit the push button to go to off setting it will start with no brake pedal being pressed. The traction control light with momentarily come on randomly in non slipping conditions and had the throttle pedal sensor light flash a time or two. I have a fixd ob2 plug in scanner that syncs to the phone but it only show a low battery fob light that immediately turns back on even tho both fobs have brand new batteries. The code says it could cause damage and fail emissions???!!! Just from a fob code? I'm lost here and would greatly appreciate any help and thank you!
Sent from my SM-S327VL using Tapatalk
haschebrown is offline
post #2 of 9 Old 01-25-2020, 07:44 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
A bad brake switch could cause a bunch of your symptoms. What is the code number?
Does battery read 12.6 all the time, including when the engine is running?
Never Argue With An idiot. They'll Lower You To Their Level And Then Beat You With Experience!
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 9 Old 01-25-2020, 08:14 AM
jtec
jtec's Avatar
2014 JK Wrangler
And the codes you retrieved are...... ?
jtec is offline
post #4 of 9 Old 01-25-2020, 01:20 PM Thread Starter
haschebrown
it's 14.6 when running so alternator is good. Here's a pic of the code.
post #5 of 9 Old 01-25-2020, 01:22 PM Thread Starter
haschebrown
After clicking on it.
post #6 of 9 Old 01-25-2020, 05:51 PM Thread Starter
haschebrown
It is fixed! You were right ColdCase. It was a bad brake switch. I was deterred from thinking that was the problem cause all others that had that issue said they got a check engine light with a brake system error code. I had no engine light and no code anywhere near that. So it may have failed internally in an odd way. I'm gonna take it apart just for the fun of it. Lol thank you for guiding me in that direction!
post #7 of 9 Old 01-25-2020, 07:27 PM
ColdCase
ColdCase's Avatar
2011 WK
There are three switches in the switch housing, one to the TIPM brake circuit, one to the PCM brake circuit, and one to the PCM speed control circuit. Depending on the state of the three, you can get different symptoms.
B1A11 is indeed a low FOB battery, but it doesn't effect emissions. You may have reduced range for remote starting, locking and unlocking type functions, but otherwise the WK2 will work fine. You don't even need a battery in the FOB to start and drive the Jeep.
ColdCase is offline
post #8 of 9 Old 01-25-2020, 08:50 PM Thread Starter
haschebrown
I have brand new batteries in both fobs and after switch replacement it has no issue at any range..... very odd. Maybe my cpu is on the spectrum. Lol
post #9 of 9 Old 01-26-2020, 07:43 PM
ceb1
ceb1's Avatar
Just as an aside, FIXD is a very basic, consumer grade diagnostic tool that has a reputation for giving wrong information.
There are a multitude of more reliable tools available, but some of the more advanced ones will only give you the code and you have that code up yourself.
ceb1 is offline
