No power to head unit/stereo after install? - JeepForum.com
 3Likes
  • 1 Post By ColdCase
  • 1 Post By LittleLebowski
post #1 of 15 Old 07-04-2020, 04:43 PM Thread Starter
LittleLebowski
I installed my second aftermarket head unit on my WK2 (2015 V6 limited) today, everything was working great, and after putting it back in the dash, Iíve got no power whatsoever to the head unit. I reworked my yellow, black, and red cables to the head unit multiple times, and checked every fuse I could think of, still no dice. Right now, Iíve got the negative battery cable pulled and Iím letting it sit until I can find a new idea to try. I believe that this might be a common problem. I would appreciate what advice/ideas the forum might offer.
LittleLebowski is offline
post #2 of 15 Old 07-04-2020, 04:49 PM Thread Starter
LittleLebowski
Iíve only found the fuse box under the hood, is there another internal fusebox?
post #3 of 15 Old 07-04-2020, 08:10 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Is that a base or premium radio?
There is a separate 20A radio fuse in 2014, dunno about 2015. Runs from the battery jumper post I think. Off hand I don't recall where to find it. F71 is a 30 amp that powers the amp.
B+ is pin 44 of connector C1, the wire is red
Yellow is a CAN C bus in C1 pin 11. The other wire of the CAN bus pair is gray.
Black on pin 43 oc C1 is ground.
LittleLebowski likes this.
Some people think I'm stupid and I totally disagree. But my biggest fear is that me thinking I'm smart proves them right.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 15 Old 07-05-2020, 10:35 AM Thread Starter
LittleLebowski
Mucho thanks!
Itís a base radio, no amp. So, I need to get into the battery compartment? Iím trying to understand what you wrote regarding C1.
post #5 of 15 Old 07-05-2020, 01:12 PM Thread Starter
LittleLebowski
I didnít find a fuse under the jumper post.
post #6 of 15 Old 07-05-2020, 03:21 PM
ColdCase
ColdCase's Avatar
2011 WK
Its not under the post, somewhere in the engine compartment hanging in line near the firewall I think. There was a post about finding it here awhile ago. Just don't remember the details. Sorry.
ColdCase is offline
post #7 of 15 Old 07-06-2020, 12:58 PM Thread Starter
LittleLebowski
Iím certain itís a blown fuse after using a multimeter to find that the yellow wire to the head unit has 2mV only, I just canít find a single blown fuse anywhere, including on the harness.
post #8 of 15 Old 07-06-2020, 01:19 PM
ColdCase
ColdCase's Avatar
2011 WK
The yellow wire at the radio is the CAN bus, you shouldn't see much of anything there unless you throw a scope or network analyzer on it. The red wire is B+. Perhaps this?
ColdCase is offline
post #9 of 15 Old 07-06-2020, 01:33 PM Thread Starter
LittleLebowski
@ColdCase I really appreciate your help so far, but I admit I donít know what I am looking at/to look for. Check the red wire?
post #10 of 15 Old 07-06-2020, 02:05 PM Thread Starter
LittleLebowski
@ColdCase you were onto something with the lone weirdo fuse! Found this bugger in the battery compartment under the passenger seat and sure as hell, itís blown. I gave up on searching for 2015 WK2 fuses and started searching Dodge Durango fuse locations. Oh man, I owe you. Thank you so much. Of course, I donít have a spare one of these anywhere, so itís off to autozone in the wifeís MILF rocket.
post #11 of 15 Old 07-06-2020, 04:18 PM
ColdCase
ColdCase's Avatar
2011 WK
Let us know how it goes. I recalled that there was a separate fuse somewhere only on some model years and folks had difficulty finding it. I didn't recall where they found it, unfortunately. Dunno why Jeep isn't clear about the location, they must not want us amateurs messing with it.
ColdCase is offline
post #12 of 15 Old 07-06-2020, 05:17 PM Thread Starter
LittleLebowski
Itís all together and working perfectly
WK2Overland4X4 likes this.
post #13 of 15 Old 07-07-2020, 06:36 AM
WK2Overland4X4
2012 WK
Is that directly to the amp?
WK2Overland4X4 is offline
post #14 of 15 Old 07-07-2020, 10:52 AM
ColdCase
ColdCase's Avatar
2011 WK
From reading the 2014 circuit diagrams, the amp gets power from the fuse in the fuse box, the radio is on this separate fuse. There have been changes through models years, early models fuses were in the fuse box for example. Some model years had no radio fuse, you'd have to disconnect the battery. So your mileage will vary.
ColdCase is offline
post #15 of 15 Old 07-07-2020, 12:37 PM Thread Starter
LittleLebowski
Anyone remember which cable is the factory antenna? I missed that somehow, just need to hook it up. Everything else is great, just no reception.
