My cb antenna mount - JeepForum.com
 2Likes
  • 1 Post By metalhead
post #1 of 13 Old 07-25-2020, 02:43 PM Thread Starter
metalhead
2011 WK
My cb antenna mount
Installed my cb antenna mount today. I picked one up from amazon and modified it so I could attach it to metal. I made a small bracket and attached it to the mount. It just clears the hatch. Going to put a 3 foot firestik on it.
1994 YJ (Gone)
2000 Grand Cherokee WJ (Gone)
2011 Grand Cherokee WK2
2012 Wrangler Unlimited JK
metalhead is online now
post #2 of 13 Old 07-25-2020, 03:11 PM
ravenworks
ravenworks's Avatar
Make sure you have a good ground
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 13 Old 07-26-2020, 02:19 PM
rjlindblom
rjlindblom's Avatar
2018 WK
How are you routing the coax?
Ryan
2018 WK2, Limited. Purchased 12-27-2019
2016 Compass. Traded 12-27-2019
KE0LXT
rjlindblom is offline
post #4 of 13 Old 07-26-2020, 04:04 PM Thread Starter
metalhead
2011 WK
I am either going to run it through the hatch if I can do it without pinching the wire too bad or I may sneak it in behind the tailight and down under the jeep to a rubber grommet that is under the hatch sill plate and then up the passenger side behind the panels. I got an 18 foot long cable so hope it will reach if I run it behind the tailight.
1994 YJ (Gone)
post #5 of 13 Old 07-26-2020, 04:46 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Perhaps a couple ideas in here:
https://www.jeepforum.com/forum/f309...4-wk2-2794258/
https://www.jeepforum.com/forum/f309...lease-1683609/
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #6 of 13 Old 07-28-2020, 09:39 AM
Dr. Internet
Coax (coaxial cable) is not the same as speaker or power wires. It is an engineered linear distribution of inductance, resistance, and capacitance designed for a particular function at particular frequencies. One of the characteristics of coax is its impedance (think resistance as a function of frequency). The value of impedance is determined by the radius of the inner conductor, the radius of the outer conductor (shield) and the dialecteric constant of the material between the inner and outer conductors. When you pinch (or exceed minimum bending radius) of coax, you change the impedance. When you change the impedance, you get reflections and a reduction of transmitted signal power.
In short, find a way to get the cable to the antenna without pinching it at all. You should be able to drill a hole somewhere, put in a rubber grommet, run the cable, then use silicon sealant to leak proof the hole.
Good luck, and let us know how it turns out!
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #7 of 13 Old 07-28-2020, 02:03 PM Thread Starter
metalhead
2011 WK
I ran it through the hatch. It does not get pinched at all. My antenna even came today. If I mounted it on the driver side I could have gone through the grommet thats up near the top of the opening. I wanted it on the passenger side since I will mounting the cobra 75 wx st under the seat.
1994 YJ (Gone)
post #8 of 13 Old 07-29-2020, 07:51 AM
WK2Overland4X4
2012 WK
Just a tip, antennas use the vehicle as the "ground plane" so the best range on that would actually be ahead and to the left, with the rear being the least, but with all the reflections, it would be limited any direction. Does anyone use SWR meters to tune antennas anymore?
I used to have a wave on the drivers rear of my 1981 Dodge Van, and it didn't work near as well as a 1/8 wave magnet mount on the roof.
WK2Overland4X4 is offline
post #9 of 13 Old 07-29-2020, 02:37 PM Thread Starter
metalhead
2011 WK
The cb is only for offroading and in an emergency when there is no cell reception. I am not looking to reach Hawaii with this. Even though I install police radios for a living I did not want to drill holes in the roof because I just spent a grand to get it repainted. I believe my setup will work just fine for what I need it for. Is it really worth spending 30 or 40 bucks for a meter that will only be used once and thrown in a drawer for years? I know plenty of people that use cb's regularly and have not had them tuned. They do just fine.
1994 YJ (Gone)
post #10 of 13 Old 07-30-2020, 06:12 AM
WK2Overland4X4
2012 WK
No, I get it, just curious. I used to do all the tricks, I had a wave (18'+) mounted on my chimney at home, and I would run the CB on 16-17 volts in my bedroom, got a whole extra watt out of it!
It was the 1980 version of txt messaging your school buddies.
post #11 of 13 Old 07-30-2020, 04:29 PM Thread Starter
metalhead
2011 WK
Thats funny I did the same thing. I had an 8 foot tall antenna on my roof with a cobra cb out of my dads car. Had a radio shack converter so I could plug it in the house. 2 of my friends both had antennas on their roofs as well. Several times got caught staying up to late on a school night talking. I miss the 80's
WK2Overland4X4 likes this.
1994 YJ (Gone)
post #12 of 13 Old 07-31-2020, 07:09 AM
WK2Overland4X4
2012 WK
Yep, mine was a Craig, still have the Radio Shack 12 v bench supply. And found the pot to adjust output voltage.
I still recall my callsign back when you had to get a FCC license for CB.
Back to the OP, how stiff is that antenna? Does it whip around and want to whack the Jeep?
On my van with the wave, I had the gutter rail clip, and racquetball on it to keep it from slapping the side.
post #13 of 13 Old 07-31-2020, 02:14 PM Thread Starter
metalhead
2011 WK
I really haven't noticed while driving. I did flick it around when I put it on and it didn't flop around enough to hit the jeep.
1994 YJ (Gone)
