Map Update and Uconnect 17.43.01 update - JeepForum.com
post #1 of 8 Old 07-08-2019, 07:46 PM Thread Starter
OldManBo
2015 WK
Thumbs down Map Update and Uconnect 17.43.01 update
I got an email offer for a discounted map update from Uconnect about a month ago and decided to take advantage of it. When I went to purchase it I learned that I needed a Uconnect software update which was over one year old. I had never received an OTA notice for the update and hadn't been watching for updates. I went to the update download site and downloaded the zipped update file folder. When I clicked on the installation instruction button I got a .pdf that appeared blank with a message that it may require a different reader. Thinking it may be a browser issue I tried opening the file in Adobe Reader and got an error message. I then tried a different browser and again got an error message. So, I had no instructions but decided to proceed as I had in the past. I unzipped the update file and moved the unzipped files in their folder to a freshly formatted 4 Gig zip drive. Then I went to my car and tried an install. All I got was a message that the files were not recognized. I have tried downloading several times and repeating the procedure in variations that might correct the issue but I keep getting the unrecognized file message. I haven't called Uconnect, yet, and thought I'd see if anyone here could help me.
OldManBo is offline
post #2 of 8 Old 07-08-2019, 09:04 PM
PlainoldCheroke
1995 XJ Cherokee
Sorry to read this. I thought Uconnect did updates directly from satelite to the car. Did not know you had to download files to a flash drive and try to install. I got the same email about a $99 update ( instead of $199) and I know maps are out of date, but they work. Sorry, not much help but will look into this procedure, too for a 2011
1995 Cherokee 4.0 with no power options.;
2011 GC Overland Hemi
PlainoldCheroke is offline
post #3 of 8 Old 07-14-2019, 10:48 AM
Tweezer19
2017 WK
The software update should be contained in a zip file. When you unzip the file, there should be a single 1.43GB file named "swdl.upd" that you place in the root of the USB drive. Do not create a folder otherwise system will not find it. HTH
Current: 2017 WK2 6.4L SRT
Previous: 2017 WK2 5.7L Summit, 2014 WK2 3.0 EcoDiesel Overland
Tweezer19 is offline
post #4 of 8 Old 07-14-2019, 04:29 PM
Fast55
Fast55's Avatar
2017 WK
^ This. Copy that to the root of a flash drive that is at least 4GB and freshly formatted. It should update from that drive.
2017 Trailhawk
Active Safety - Luxury group - Blind spot detection
Hemi
Rock Rails
Fast55 is offline
post #5 of 8 Old 07-18-2019, 10:33 AM
hoffinon
2014 WK
I'm on a 2014 with version 17.11.07, I have similar issues.
Is there a way to manually download and install this update? (Uconnect's website says that I have the latest version)
2014 Grand Cherokee Overland 3.6L V6
hoffinon is offline
post #6 of 8 Old 07-18-2019, 05:53 PM Thread Starter
OldManBo
2015 WK
I'm finally back. When I downloaded the update and unzipped it I got a folder with two files in it. One file was swdl.iso at 347.638 megs and swdl.upd at 1,392.724 megs. I got the uconnect instructions via a private message and email from a fellow member, thanks. In the trouble shooting guide with the instructions it states "Ensure that the only file on the usb flash drive is swdl.iso."
I will be trying flash drives with each having one of the files to see if either work. Will report back later.
Thanks for all the help.
OldManBo is offline
post #7 of 8 Old 07-18-2019, 09:52 PM
jacko15
2014 WK
You need both files on the thumb drive, unzipped, and separate.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #8 of 8 Old 07-19-2019, 07:08 PM Thread Starter
OldManBo
2015 WK
Success. Not sure what all I've learned but am sure patience is one of the clues.
I first tried putting both files on a freshly formatted usb thumb drive that was formatted in NTFS. I followed the directions and inserted the USB drive, waited about 30 seconds and nothing happened. Assuming it wasn't working I removed the drive. A message came up on the screen saying: Failed to copy installer.iso. Then I repeated the above with just the .upd file loaded and this time the message was: Installer data section in hash and hash don't match. With only the .iso file the unit switched to media and did nothing and left no messages.
I went back and reformatted the drive and transferred the zipped .upd file from my computer to the usb drive with the intent of unzipping it on the thumb drive. I found it was unzipped during the copy so I took the drive to the car and tried it. At first it appeared the same as before, ie. nothing happenning. I waited a little longer, about 45 seconds, and the update screen appeared. From there all worked as described in the instructions.
I suspect all I needed was to wait longer but maybe the second method of unzipping was what was needed. At least it appears that only the .upd file is needed. I did find that a few things worked different that shown in the directions once the the update started but it did not interfere with completing the installation. The directions were for a 14 and the differences may be with the changes that u-connect made in 15s.
OldManBo is offline
