Maintenance and Repair Thread Index - JeepForum.com
 12Likes
post #1 of 18 Old 10-31-2015, 10:49 PM Thread Starter
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Hello all. This can be an extremely helpful thread for for all the DIY JEEPERS. When you do a repair or perform challenging maintenance - PLEASE share your how to, tip, instructions, and an idea of how easy or hard the job was. Pictures are always a great help.
techauthority.com offers one and three day access to Jeep service information, including wiring diagrams. Three days for ~$35.
https://www.techauthority.com/en-us/...ts/TAUSER03DAY
They are now offering wiring diagrams on a USB stick for $90-$120 depending on year, along with the FSM.
A DTC decoder can be found here:
https://www.dtcdecode.com/Jeep
If you are not sure about part numbers, try posting a thread in the Mopar Online Parts (supporting vendor) subforum and Benny should get you the part number you need.
Last Update 22 August 2021
Headlight Adjustment
Headlight and Foglight Alignment
Early Model Light bulbs
Y2011 radiator replace
Blend Door Gears
OEM vs Aftermarket Windshield
Suspension Torque Specifications
Diesel Oil Change Tips
Door Lock Actuator
Diff Fluid Change
HID Bulb Replace 2011-2013
Brakes and part numbers
Spark Plugs 3.6 Gas
Radio Firmware Updates
TIPM and Fuel Pump Problems, Haunted Vehicles
TIPM Teardown and Details (a JK but the WK2 is similar)
Front Hub/Wheel Bearing Replacement
Groaning/Noise - Front Crossmember Bolts
V6 Thermostat
Windshield Washer Pump
Brake Pads
Preventing Rusty Axle Nuts
Scan Gage for Air Suspension
Air Suspension Fill and Info
More Air Suspension Repair Info
5.7 V8 Dipsticks
5.7 V8 Thermostat
Flipper Window Latch Switch Replace
Wire Breaks at Door Jamb
Front CV axle replace
Diesel O2 Sensor Remove and Clean
Suspension Noise/Bounce Could Be Motor Mounts
Diesel Cylinder Identification
Checking 545RFE transmission fluid level. NAG is similar but uses different charts
3.6 motor mount replace
Potential Source of Drive Shaft Flexible Disk Coupler
Key FOB Repair
Front Sway Bar Bushings
Door Popping When Opening
3.6 Starter
Front Wiper Hoses
LED License Lamp Replacement
Headlight Bulb Replace: 2018
AC Condenser/Trans Cooler Replace, Quicker way, Early Models
Battery Fitment, Beware of Part Book Errors
iPhone Connection Issues solved by Reset
V6 oil change tips.
Rodents cause no starts and other unusual symptoms.
Early Model Key Programming
Pulsing on Turns and Vibration - Drive Shaft
Growl- Hum - Wheel Bearing
2018 Headlight Bulbs and Headlight Tool
8 Speed Flare and Rough Shift
Headlamp Leveling Motor
QTII Transfer Case Clicks, Stuck in Low, Service 4WD
Connector Reference
__________________________________________________ __________________________________________
mudbear, jim-80 and BigTizzie like this.
ColdCase is offline
post #2 of 18 Old 08-30-2017, 01:57 AM
finrisk
2005 WK
Where can one obtain a service manual, stating what needs to be done at every service, as well as what quantity of spares (filters, oil, etc.) are needed for a WKII Overland with the 3.0 CRD VM Motori engine?
2005 Jeep Grand Cherokee 5.7 Hemi Ltd
2012 Jeep Grand Cherokee 3.0 CRD Overland
finrisk is offline
post #3 of 18 Old 08-30-2017, 07:34 AM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
The owners manual has a section on what needs to be done and some of the fluid capacity. I think the maintenance schedule can also be downloaded from Jeep.com , in the owners section.
There is an owners guide, which is a summary, and a DVD with the owners manual that is usually delivered with the Jeep. The hard copy of the owners manual usually needs to be ordered from Jeep.com, but I'm not sure how that differs from country to country.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 18 Old 08-30-2017, 08:30 AM
finrisk
2005 WK
Thanx ColdCase. Much appreciated.
finrisk is offline
post #5 of 18 Old 10-09-2018, 09:37 AM
BigTizzie
BigTizzie's Avatar
2011 WK
Talking
I know this is an important one for sure.
If your flashlight doesn't work, the battery is probably bad.
It's a Varta V500HT battery. Expensive too!
https://www.amazon.com/Chrysler-Dodg...R10K7GJ9E1G6D8
BigTizzie is offline
post #6 of 18 Old 11-07-2018, 10:47 AM
BigTizzie
BigTizzie's Avatar
2011 WK
I replaced that battery in my flashlight and it still doesn't work.
Not sure what the problem is, 3V at the battery. Ug.
Anyway, another one for you people who want to change the FP relay (external one after recall)
Mine is working great! I put electrical tape around the base to keep moisture out.
https://www.oreillyauto.com/detail/b...y/rl44/5565109
post #7 of 18 Old 12-15-2018, 03:28 AM
brian-mcBride
Hi Guyz,
from where i can get service manual of this brand. i need it as on URGENT basis. please help to get n will be highly appreciated.
Thanks in advance.
brian-mcBride is offline
post #8 of 18 Old 12-15-2018, 08:26 AM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
Post 1 has a link to tech authority where you can get immediate access to service information and/or order service information on a USB stick. You need a windose computer, or VM, with exploder. More information is available on line than in the USB. There are no PDFs or paper service manuals besides those provided by aftermarket outfits like Haynes.
ColdCase is offline
post #9 of 18 Old 09-20-2019, 10:46 PM
Northcreek
Northcreek's Avatar
2016 WK
Doing the 40K mile maintenance on my 2016 Summit and the ELSD (rear axle) seemed a tad low. So I got a quart of the $45 special gear oil from FCA and was surprised that it took almost the full quart before it ran out of the fill plug. Anybody else have this happen? There are no leaks or problems, so it looks like this may have been low from the start. I am the third owner and the previous owners had dealer service.
Northcreek is offline
post #10 of 18 Old 09-23-2019, 01:38 PM
Northcreek
Northcreek's Avatar
2016 WK
I have found the answer which I will post to perhaps help others. The ELSD rear differential has two plugs which appear to be fill plugs. The proper one to use is the pass side 8mm hex and not the rear facing 10mm hex plug. I removed the side fill plug and retrieved most of the expensive lube that I added. So in reality I was only low about 6-8 ounces. The Amsoil site says it holds 2.7 pts.
Also on close inspection that rear plug is stamped "Do not open" , wish I would have seen that earlier.
yzf125 and jim-80 like this.
post #11 of 18 Old 12-12-2019, 06:46 AM
BigTizzie
BigTizzie's Avatar
2011 WK
Wink
Found this page last night at work...
https://cardiagn.com/2011-2013-jeep-...iring-diagram/
Pretty awesome.
mudbear and cdplayer like this.
post #12 of 18 Old 07-17-2020, 03:01 PM
justtina1982
I am looking for a powered side mirror (passenger) for my 2019 Jeep Grand Cherokee Trailhawk. The body of the side mirror does not match the color of the jeep. Could someone please advise on the exact part number? Thank you.
Sent from my iPhone using Tapatalk Pro
justtina1982 is offline
post #13 of 18 Old 11-22-2020, 11:51 AM
stevevogel
Horn not working
I suspect it is a rodent problem. The horn fuse is good but I can't find anything on a horn relay, are they not used anymore? Also, does the wiring for the horn go down the right or left front fenders?
Thanks,
Steve
stevevogel is offline
post #14 of 18 Old 11-22-2020, 06:08 PM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
You must have a late model with one horn fuse. Early models had two, one for each horn. There is a horn relay, but its on the TIPM circuit board. You may need to pull apart the TIPM to get at it. I don't see a DTC for the horn, so to troubleshoot you'll have to pull off the horn connectors and/or probe the TIPM connector. One horn wire should be connected to ground, the other should have 0 volts unless the horn switch is pressed. You may have to pull off the grill to get at the horns.
You should be able to get circuit diagrams applicable to your model year and cable routing at techauthority.com, for a subscription fee. I have early model stuff handy, but the horns were wired different then.
ColdCase is offline
post #15 of 18 Old 11-23-2020, 08:57 AM
stevevogel
Horn fuse
I believe I have 2 horns ... think I have seen them ... but have only seen one reference to a fuse. Maybe it is because I stopped looking when I found one but was expecting to find a relay. I will look further. It is a 2018 model year Grand Cherokee.
Thanks for the reference to techauthority.com
