Hellwig 7732 Rear Sway Bar: GAME CHANGER - JeepForum.com
 6Likes
post #1 of 19 Old 04-24-2021, 06:27 PM Thread Starter
RobF
2017 WK
Hey, all.
Just installed the Hellwig sway bar and all I can say is that each and every one of you should immediately drop $250 on one and install it. The change to the feel and handling is radical. In addition to cornering totally flat, the Jeep feels better balanced all around, is less sensitive to weight shift when changing directions, and surprisingly, the road chatter I always experienced when driving over roughly paved streets is 100% gone. I have modified a half dozen vehicles in my life, and the Hellwig is near the top of the mods I have done in terms of bang for the buck. Did the install in my driveway with nothing more than a ratchet, an 18mm socket, a 5/16th socket and a rubber mallet. Took about an hour.
So happy with the results.
Cheers,
Rob
yzf125 and 19GCTrailhawk like this.
2017 Jeep Grand Cherokee Overland 4x4. 5.7 Hemi, Granite Crystal, Safety Group, Harmon-Kardon, Nav
RobF is offline
post #2 of 19 Old 04-24-2021, 06:57 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The only thing that seems to hold folks up, once in awhile, is the link bolts spinning in the link end joint.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 19 Old 04-24-2021, 07:13 PM Thread Starter
RobF
2017 WK
I'm thinking proper torque spec averts that.
RobF is offline
post #4 of 19 Old 04-24-2021, 09:54 PM
ColdCase
ColdCase's Avatar
2011 WK
I meant when pulling off the OEM bar, when unloosening the links, the shaft will often spin in the link with the nut.... will set you back a little time pulling it apart and its best to replace the links at that point, if you weren't planning on it anyway.
BTW, did you replace the links and if so, what size did you use.
RobF likes this.
ColdCase is offline
post #5 of 19 Old 04-24-2021, 10:57 PM Thread Starter
RobF
2017 WK
Ah, gotcha. I used an open ended wrench to hold the nut and a ratchet with a 5/16ths on the shaft. No problem getting it apart. I considered replacing the stock links with Bwoodys, but I couldn't justify the price compared to the improvement they offer. The Bwoodys are 2/3rds the price of the sway bar! Kept my stock links on as they were in good shape.
RobF is offline
post #6 of 19 Old 04-25-2021, 05:28 AM
Kman09JGC
Kman09JGC's Avatar
2016 WK
Iíve had my hellwig bar on for awhile. You right on the money great improvement in handling. I put the front SRT bar on as well. Front bar helped as well but not as much as the rear Hellwig. Try the moog problem solver endlinks the are a bit thicker than the stock endlinks.
Sent from my iPhone using Tapatalk
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline
post #7 of 19 Old 04-25-2021, 12:26 PM Thread Starter
RobF
2017 WK
Originally Posted by Kman09JGC View Post
I’ve had my hellwig bar on for awhile. You right on the money great improvement in handling. I put the front SRT bar on as well. Front bar helped as well but not as much as the rear Hellwig. Try the moog problem solver endlinks the are a bit thicker than the stock endlinks.
Did you do the front bar install yourself? If so, how much of a PITA is it? Looks to be more complex than the rear.
RobF is offline
post #8 of 19 Old 04-27-2021, 05:56 PM
RedTrex
2014 WK
Okay I'm in.... just ordered one, see what it does to the diesel pig.
RobF and yzf125 like this.
2003 Libby 2x4 (Gone)
2004 Libby 4x4 (Gone)
2013 Wrangler JKU (Gone)
2014 WK2 Ecodiesel (485 tq)
RedTrex is offline
post #9 of 19 Old 04-27-2021, 08:58 PM Thread Starter
RobF
2017 WK
It will blow your mind that a metal rod can so radically change your car's handling. Be prepared to be shocked. I was.
RobF is offline
post #10 of 19 Old 04-29-2021, 05:14 PM
RedTrex
2014 WK
I autocross for a hobby so takes a lot to shock me, but given that a few of you have praised the upgrade.....
RedTrex is offline
post #11 of 19 Old 04-30-2021, 03:28 AM
Kman09JGC
Kman09JGC's Avatar
2016 WK
I had a buddy put all my stuff on who is an experienced mechanic. It didnít take hime long at all. Me it probably would have taken longer. Lol
Black WK Club #107
post #12 of 19 Old 04-30-2021, 03:30 AM
Kman09JGC
Kman09JGC's Avatar
2016 WK
It definitely changed the handling but I also have the Dobinson struts in the front and 5100 bilsteins in the back. Excellent ride and handling now compared to stock.
Black WK Club #107
post #13 of 19 Old 04-30-2021, 01:30 PM
tampamark
2015 WK
Agreed, extremely simple upgrade and rewarding results.
2000 TJ Sahara (sold)
2015 Grand Cherokee Summit - 6 cylinder Gas
tampamark is offline
post #14 of 19 Old 04-30-2021, 02:01 PM
yzf125
yzf125's Avatar
2018 WK
This is an interesting thread, I have a 2018 with 13K and it seems to wonder and not feel stable on windy days on the main roads. Is this something that would help that ?
yzf125 is offline
post #15 of 19 Old 04-30-2021, 08:04 PM Thread Starter
RobF
2017 WK
Yes it addresses all sorts of rear end instability nicely
RobF is offline
