Headlights randomly shutting off - JeepForum.com
post #1 of 5 Old 05-03-2021, 07:53 PM Thread Starter
BC904
BC904's Avatar
While driving my 2014 Jeep GC Summit at night, the headlights will intermittently shut off. It seems to be getting more frequent as of late. I have attempted to diagnose it by turning the switch from “auto” to the “headlights” setting. But both positions cause the problem. I have a couple of busy weeks coming up and will be unable to make it to a dealership before then. I thought I would throw this out to the group to see if any of you have any ideas or have even heard of this. BTW, I have the lifetime maxcare warranty. TIA.
Greg
2003 Jeep GC Overland (H.O. 4.7)
2014 Jeep GC Summit (Hemi)
BC904 is offline
post #2 of 5 Old 05-03-2021, 09:51 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The Summit has HIDs. When the ballast or bulbs get marginal, the bulbs can lose their arc and shut off. Turning the lights off then back one kicks them into a high voltage startup that gets the arc going again. You could look for what looks like burned connections or overheated ballasts. Often a bulb change will fix it for awhile. Are they the original bulbs? I think there is a thread around here someplace. If no one jumps in here by the time I get back I'll try to look for it.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 5 Old 05-04-2021, 10:25 AM Thread Starter
BC904
BC904's Avatar
Yes, they are the original bulbs. Is the ballast you talk about part of the bulb assembly, or a separate part located elsewhere?
Greg
BC904 is offline
post #4 of 5 Old 05-04-2021, 11:38 AM
ColdCase
ColdCase's Avatar
2011 WK
On early models there was a ballast under both headlight assemblies, dunno about the 2014. You may find TIPM codes if you have a OBD scanner that can read body modules. Given both seem to be going out, I'd check wire harness power and grounds for a bad connections. I'm not sure if the 2014 has a circuit breaker built into the TIPM that will trip and automatically reset when it detects an over-current or short. There is a lighting description around here somewhere, I'll have to check it to refresh my memory.
post #5 of 5 Old 05-05-2021, 08:54 AM Thread Starter
BC904
BC904's Avatar
Thanks for the info.
Greg
BC904 is offline
