Gc hemi running hot - JeepForum.com
post #1 of 3 Old 08-25-2019, 12:37 PM Thread Starter
woodsy18
Gc hemi running hot
Went for a quick run to the boat ramp to test out my jet skis after a supercharger failure. On the way back my jeep was running hot and had a burning smell to it. Coolant temps were 236 in town while moving and oil was about the same. The trans was at 167 only. Theses seem high especially being 70 degrees today with no humility. No ac or heat on. Windows were down. 12 gc overland hemi. I've towed the same load when it's over 100 out with normal 210 temps. Thermostat has been changed 4 months ago due to it stuck open
Sent from my SM-G973U using Tapatalk
woodsy18 is offline
post #2 of 3 Old 08-25-2019, 05:58 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Coolant level (check radiator level)?
Was the radiator fan spinning? At that temp is should be spinning near full speed.
Water pump failure ?
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 08-25-2019, 08:40 PM Thread Starter
woodsy18
Coolant level normal in both rad and tank. The fan did kick on for a few seconds here and there. Nothing constant. Water pump failure could be happening. With no load I've been at normal 200 temps
woodsy18 is offline
