Gas tank hole - JeepForum.com
post #1 of 8 Old 03-17-2019, 10:01 AM Thread Starter
Slumpilufigus
Gas tank hole
Probably in if the dumbest things I have done. I had a piece of rebar stick through my gas tank and out aboutna dime sized hole. I put jbweld steel stick putty on it and that sealed it for a while. I recently noticed a small drip and took off the putty to try again and get the area as clean as possible. My question is, how can I get all of the gas out and what other options do I have. I do t really want to replace the tank as it is a PITA.
Sent from my ONEPLUS A6013 using Tapatalk
Slumpilufigus is offline
post #2 of 8 Old 03-17-2019, 01:29 PM
BigTizzie
BigTizzie's Avatar
2011 WK
What year & model?
Tank for mine is $715 bucks. Yikes.
What type of plastic is it?
BigTizzie is offline
post #3 of 8 Old 03-17-2019, 03:34 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There is a one way valve in the filler. The shop manual says to disconnect the fuel line fitting in the engine compartment, run a hose to an appropriate container, and use a scan tool to run the fuel pump until the tank is empty. Depending on year, there is probably a way to keep the fuel pump running without a scan tool. If you can't get the pump working, you remove the tank and drain it through the pump module opening (remove the pump).
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 8 Old 03-18-2019, 09:21 AM
tampamark
2015 WK
Well, you already have a hole, all you do is stick a hose in the hole and use it drain the tank by siphon gravity. I would get a plastic that's of the same type material as the tank, HDPE most likely, then epoxy it right over the hole so that the plastic seals in the gas, epoxy isn't the only thing holding the gas.
I have been known to gettho fix in the old days, I would take a plastic gas can, cut the material out, epoxy it over the area and then also add a couple layers of fiberglass will over the whole thing to reinforce.
2000 TJ Sahara (sold)
2015 Grand Cherokee Summit - 6 cylinder Gas
tampamark is offline
post #5 of 8 Old 03-18-2019, 10:46 AM Thread Starter
Slumpilufigus
Thanks for the help. I ended up pulling off the plug I originally had and letting it drain on flat ground , then I drove up on my driveway and some ramps to get the residual gas as far away as possible from the hole. The only issue is, there is always a little bit that make its way to the hole. I don't know how to keep it dry while I put the putty on. BTW, it is a 2012 Jeep Grand Cherokee laredo.
post #6 of 8 Old 03-18-2019, 11:25 AM
ColdCase
ColdCase's Avatar
2011 WK
FYI, these are saddle type plastic tanks with two pickups and a hose between them. It saddles over the drive shaft. One side may drain out the hole but the other may still have gallons.
So you may want to park on a side hill (or jack one side up) to raise the hole side higher so what little fuel is in that side will drain away. Let it dry out for awhile. This is where smoking can be dangerous to your health....
We used to use those screw on rubber plugs to temporarily plug holes, the kind that expands as you tighten them down. You'd need to clean up the hole first, however.
ColdCase is offline
post #7 of 8 Old 03-18-2019, 11:58 AM
tampamark
2015 WK
Definitely need to clean up the surface. You don't need to drain the tank unless you are removing it, since you are just patching I would jack it up in whatever direction is needed for extra slope and have the gas away from the hole.
Does a 2012 have a gas cap (mine is capless in '15), if so open it to let fumes escape and doesn't push on your patch while it dries. If capless get out the funnel and put it in like you are filling from a can for same purpose.
post #8 of 8 Old 03-18-2019, 01:09 PM
BigTizzie
BigTizzie's Avatar
2011 WK
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
'74 CJ-6 Gas Tank Fuel Filler/Vent Hoses w/non-stock Setup Agar426 Jeep CJ Forum 2 09-16-2018 05:55 PM
gas tank leak Kristian_Burns TJ Wrangler Technical Forum 3 06-13-2018 09:21 PM
20 gallon factory poly fuel tank StoneTower Jeep CJ Forum 16 05-16-2018 04:52 PM
Distance between axle & gas tank on TJ vs LJ vinsanity TJ Wrangler Technical Forum 31 04-12-2018 12:24 PM
