Full-Size Spare + Five Tire Rotation - JeepForum.com
 2Likes
post #1 of 20 Old 06-21-2021, 08:25 PM Thread Starter
Quadra_Drive
Junior Member
Quadra_Drive's Avatar
2017 WK
I'm soliciting opinions from the group. I have a 2017 Jeep Grand Cherokee Trailhawk. Tires are Bridgestone Dueler A/T Revo 3. Stock size: 265 60 R18.
I know from experience that the spare tire in the Trailhawk is OK, not a doughnut but not full-size either. I use this WK2 to explore the forest roads in the Seattle area. If I were using this WK2 strictly for the street, I know (from experience) that if I get a flat, the spare tire is 'good enough' to get around on the street until I can get a replacement.
My question: given the off-road use of this vehicle, does it make sense to get a re-furbished wheel and a 5th tire, and go to a 5-tire rotation. I understand it's not the cheapest way to go, but I'm tempted to get a 5th tire in the rotation in case I get a flat tire. Or to extend the life of the 4 A/T tires I have. Time to make a decision soon.
Thoughts: overkill, overthinking, Old School?
Thanks
Quadra Drive
Quadra_Drive is offline
post #2 of 20 Old 06-21-2021, 09:32 PM
Gray203m
2008 WK
For me it would depend on the trails. Bad enough that I'm expecting to take out a tire? Ya I would have a full size and rotate it in. Maybe even two.
Just rough trails? Your regular spare is probably fine.
I don't see a lot of trails these days, but I carry a full size spare (not rotated in), with a plug kit and a 12v air compressor. I've used the plug kit and compressor exponentially more than I've used a spare tire
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #3 of 20 Old 06-21-2021, 09:44 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
If you care, tires wider than 10 inches (255) will raise the cargo floor. A matching road wheel and tire will raise the floor about inch.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 20 Old 06-22-2021, 06:17 AM
WK2Overland4X4
Another consideration is TPMS, and rotating the 5th wheel. That is usually the deal breaker now, but it is still possible, just 1 more thing to deal with.
2012 Overland 4X4 Mineral Gray/New Saddle, HEMI , 24p (ACC,BSM, FCW)
WK2Overland4X4 is offline
post #5 of 20 Old 06-22-2021, 06:29 AM
222Doc
222Doc's Avatar
My spar is a 35 but i run 37s. Its mainly off road and nothing but hard trails....works fine. Even when i was at the 50th run of Fordyce with the Sierra trek. They have rules, spar must be with in 2" of tires on it.
Off road you should have a tire repair kit, air supply.......
222Doc is offline
post #6 of 20 Old 06-22-2021, 08:01 AM Thread Starter
Quadra_Drive
Junior Member
2017 WK
R: Full-Size Spare + Five Tire Rotation
I appreciate this. When I bought this Trailhawk, it had 49,000 miles and Falken Wildpeak AT3's. The Falken's were showing wear, and it was time to think about replacing them. Then, driving down and arterial in the Seattle area, my driver's side rear tire took a big steel shard in the sidewall and went completely flat within 1/2 mile. The tire couldn't be repaired. The spare worked OK, until I could get a new set of tires.
As I think about it, my experience of getting a flat tire on the street tilts the question more toward a five tire rotation. If someone were mid-way through a tire wear cycle (~ 15,000 - 25,000 miles) and had 5 tires in the rotation and got flat (street or trail), then they could continue on with 4 tires and the factory spare.
post #7 of 20 Old 06-22-2021, 08:04 AM Thread Starter
Quadra_Drive
Junior Member
2017 WK
Re: Full-Size Spare + Five Tire Rotation
This is a consideration I hadn't thought of, thanks.
post #8 of 20 Old 06-22-2021, 08:07 AM Thread Starter
Quadra_Drive
Junior Member
2017 WK
In this case, if the 5th tires is in the vehicle, the dash will always show a TPMS error light, correct?
post #9 of 20 Old 06-22-2021, 09:38 AM
OldPaint
OldPaint's Avatar
OldPaint
I have a matching full size spare and wheel that I would love to put in rotation. Discount Tire insists that I cannot put a TPMS in the spare without confusing the system. Sure would be nice if the display would show air pressure at the 4 corners and the spare!
OldPaint is offline
post #10 of 20 Old 06-22-2021, 10:33 AM
ColdCase
ColdCase's Avatar
2011 WK
There are some vehicles that can get confused. Under normal conditions, to save battery life, the WK2 OEM TPMS sensors do not transmit unless they are rotating greater than 15mph, and then only once a minute or so. A stationary spare is not going to be transmitting anything, the monitor is not going to know its there, so there should be no confusion. And the Jeep system should adapt within a few miles of throwing the spare on, but it may be a bit confused while adapting. There are very few here that still attempt a five tire rotation, so the experience database is slim.
Note that there are some export markets were a sensor in the spare is required, but for those vehicles with compact or a narrower full size spare, the spare won't be equiped with a sensor..
The TPM sensor can be forced to transmit if using a special tool such as a TPM-RKE Analyzer. The vehicle must be stationary for more then 20 minutes in order to initiate the learning sequence, or triggered by the test set.
Not many independent shop techs are familiar with the Jeep TPMS. The Jeep monitor doesn't probe sensors, it just receives whatever signals they are sending. The premium system will correlate sensor to tire by differences in signal level. The base system just alerts when one of the sensors reports low pressure, it has no way of knowing which sensor is reporting.
ColdCase is offline
post #11 of 20 Old 06-22-2021, 10:59 AM
Bilko
Thanks
Quadra Drive
Which drive system does the Trailhawk use, is it full-time AWD/4WD? In my experience, the tire wear on WK2s with the basic, full-time AWD system is very even so I would question the value of tire rotations unless you are running more aggressive offroad tires. Sometimes these tires can get noisy if you don't rotate them. I am running the same tires as you and after about 20,000 miles the wear is even.
The decision point for me would be, where do you offroad? If you plan to head to more challenging, remote areas I would get a full-size spare. If its only a spare, you don't need a fancy wheel or TPM.
Bilko is offline
post #12 of 20 Old 06-22-2021, 07:29 PM Thread Starter
Quadra_Drive
Junior Member
2017 WK
Bilko: Yes, these are some good thoughts. This Trailhawk (all of them, pretty sure) has the Quadra Drive AWD system. Hadn't thought about tires wearing evenly, I have it in my mind that tires should be rotated. Whether they need it or not.
post #13 of 20 Old 07-18-2021, 08:20 PM Thread Starter
Quadra_Drive
Junior Member
2017 WK
Confirmed. Overthinking prevailed over logic and I bought a 5th wheel and Bridgestone Dueler Revo 3 with the intent of going to a 5 tire rotation.
When putting the a full size 5th tire in the spare tire rear well, it is oversized by about 1/2 inch.
What I noticed is the factory 'near sized spare' is very space efficient the way it incorporates the jack and a couple of storage bins.
post #14 of 20 Old 07-19-2021, 09:35 AM
Bilko
Is this extra 1/2inch in diameter or width/height? If it's height, have you tried removing the styrofoam donut that sits under the spare wheel? This can make enough difference to allow the trunk floor to fit flush.
Bilko is offline
post #15 of 20 Old 07-19-2021, 09:36 PM Thread Starter
Quadra_Drive
Junior Member
2017 WK
The issue is the height. The diameter of the tire is OK and it fits into the well.
About the styrofoam doughnut, I'm not sure. I'll take another look.
Thanks
