Front mud flaps: to install or not? - JeepForum.com
 2Likes
  • 1 Post By andyo5
  • 1 Post By 6t9chgr
post #1 of 9 Old 08-21-2018, 03:37 PM Thread Starter
andyo5
2018 WK
I just received a pair of Mopar mudflaps for my Limited. I opened the package to read the enclosed instructions and saw a cautionary statement advising that these parts are not intended for offroad use. I suppose the thinking is that they hang too lo and might be impacted by rocks, etc. I certainly wouldn't want that to happen, since they could conceivably be ripped off if that happened. I could visualize driving over a rock and having the rock strike the flap as the tire has passed over it. Now I thinking maybe I should just leave well enough alone and try to return the flaps.
Your thoughts?
Thanks.
oldmac1 likes this.
andyo5 is offline
post #2 of 9 Old 08-21-2018, 05:08 PM
6t9chgr
6t9chgr's Avatar
2017 WK
No brainer .....if you plan to off road driving over boulders dont put them on.
Normal street driving put 'em on! I have them front & rear cause I like to keep mine clean & dont plan on off roading over boulders
SirEagle likes this.
6t9chgr is offline
post #3 of 9 Old 08-21-2018, 06:28 PM
Daves2018GC4x4
Daves2018GC4x4's Avatar
2018 WK
Agree with 6t9chgr. I have put the molded MOPAR splash guards on a number of my FCA vehicles in the past. They fit well and look great. Very good for on-road use but would clearly be vulnerable to damage with any serious off road use. If you still want the protection, I think there are flexible rubber after market guards that would withstand off road abuse. Maybe you can find something like this but for a GC? https://www.quadratec.com/products/12541_0002.htm
2017 BMW 330i, 2.0L Turbo
2018 GC 4x4 Ltd, 5.7L
2019 Corvette Stingray, 6.2L
Daves2018GC4x4 is offline
post #4 of 9 Old 08-22-2018, 06:13 AM
dtrkyman
2013 WK
I had the molded guards from the factory , cracked Borge the fronts quickly crawling through rocks, bought a new after market set from amazon and have broke them yet. Too much salt and gravel driving to not have them.
Sent from my iPhone using Tapatalk
dtrkyman is offline
post #5 of 9 Old 08-22-2018, 02:38 PM Thread Starter
andyo5
2018 WK
Decision made. Will not install.
My vendor has agreed to take them back and issue a refund.
Thanks to all who replied. It really helped.
andyo5 is offline
post #6 of 9 Old 08-23-2018, 04:36 AM
GregK340
2017 WK
Now this has me thinking about Mopar mud flaps.
For a 2017 Trailhawk, would I get ones for a Summit, or ones that apparently fit everything else? Thanks.
GregK340 is offline
post #7 of 9 Old 08-23-2018, 04:49 AM
bpsmicro
2017 WK
I put the Mopar ones (front & rear) on my 2017. Driving over a curb (because, Jeep) cracked a front one.
I'd like to find a set that's made of *soft* rubber that can take moderate flexing (say, a full 90 degree bend below freezing). The "stock" ones are moderately hard plastic, and take zero abuse. Bonus points if being slightly wider than the wheel well too (the stock ones still don't catch enough spray). But they can't look like 18-wheeler flaps either.
2017 Grand Cherokee Overland, 5.7l Hemi, all the techy stuff.
bpsmicro is offline
post #8 of 9 Old 08-23-2018, 09:00 AM Thread Starter
andyo5
2018 WK
Yeah. That's the sort of thing I envisioned when I decided to send them back.
andyo5 is offline
post #9 of 9 Old 08-23-2018, 09:54 AM
ravenworks
ravenworks's Avatar
The problem of ripping them off happens when you back up and they get sucked into the wheel.
Simple fix is to tie them up when wheeling.
Take a look a a few dump trucks,a good owner operator knows to put an eye bolt at the bottom so they can hook their flaps up while dumping broken concrete or into an asphalt paver.
Simple fix to keep the tier from ripping them off.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
