Flashing engine light? - JeepForum.com
post #1 of 9 Old 10-07-2021, 12:00 PM Thread Starter
dtrkyman
2013 WK
Zero symptoms prior, turned off jeep for 10 minutes or so was running driving normal…get back in power comes on but will not even turn over, engine light flashing.
Any ideas?
Sent from my iPhone using Tapatalk
dtrkyman is offline
post #2 of 9 Old 10-07-2021, 02:23 PM
jtec
jtec's Avatar
2014 JK Wrangler
flashing VEL is an attention geter - Cat damage is likely, often an fuel inj or ign issue.
Are the other warning light flashing at start attempt ABS, SRS?
jtec is offline
post #3 of 9 Old 10-07-2021, 02:40 PM Thread Starter
dtrkyman
2013 WK
Seems like the starter…tried it and it squealed like a pig…tried again started up and sounded like stater was still engaged.
Couple whacks it stopped .
Engine light off everything else normal.
dtrkyman is offline
post #4 of 9 Old 10-09-2021, 01:32 PM Thread Starter
dtrkyman
2013 WK
No go after starter replacement…just clicks once and nothing happens. Same as before. Electrical issue somewhere?
dtrkyman is offline
post #5 of 9 Old 10-09-2021, 02:07 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Are you hearing the starter solenoid click or the starter relay (TIMP). Does the engine turn freely? How good is the battery, are its cables tight? Is the battery and engine ground connection OK?
Did you get the DTC codes read, any in the history?
There have been reports that the switch that detects neutral or park can be defective and inhibit starting. I dnn't think you would here the starter solenoid or relay click, however.
Starter Relay Operation
In a no crank condition the Starter Relay can be missing power at pin 85, feed at pin 30, controlled ground at pin 86 or output at pin 87. Further explanation of how a relay operates is listed below.
•Pin 85 receives power from the TIPM once the parameters for the Ignition Switch position and status, and all inhibit monitors (i.e. clutch switch, RPM, etc.) are satisfied.
•Pin 30 is a constant B+ feed.
•Pin 86 is a controlled ground by a module (i.e. PCM or BCM). Once power is sent from the TIPM to the pin 85 of the relay it passes through a coil and leaves the relay through pin 86 to control module.
•Pin 87 is an output circuit to the Starter solenoid. Once the circuit on pin 86 is grounded by the control module, the coil winding in the relay magnetically pulls the internal switch closed. When the internal switch is closed the power at pin 30 is sent to pin 87 of the relay.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #6 of 9 Old 10-09-2021, 02:34 PM Thread Starter
dtrkyman
2013 WK
I think I hear the solenoid click? Engine turns freely, got it to fire once every thing is normal once running.
No codes, engine light off once it runs, gonna test battery and check grounds.
Was in mud prior to issue but then again I’m often in mud!
dtrkyman is offline
post #7 of 9 Old 10-15-2021, 07:01 PM Thread Starter
dtrkyman
2013 WK
The new starter was bad, another new starter everything working.
dtrkyman is offline
post #8 of 9 Old 10-15-2021, 10:14 PM
ColdCase
ColdCase's Avatar
2011 WK
I hate it when replacement parts are bad. Thanks for the update.
post #9 of 9 Old 10-21-2021, 10:15 AM Thread Starter
dtrkyman
2013 WK
Yeah talk about the part not to get a bad one, what a cluster to replace that starter, glad it wasn't me working on it! We did some other checks prior to replacing again with no help.
Put in a new battery which didn't help that issue but being the original battery was still in the vehicle I just replaced anyway.
dtrkyman is offline
