Electronic Throttle control (ETC) and Cruse Control connection? - JeepForum.com
 1Likes
  • 1 Post By JeepCares
post #1 of 13 Old 06-14-2019, 10:55 AM Thread Starter
Timotb
Timotb's Avatar
2012 WK
Hi....
I think I have the WK2 (2012 Grand Cherokee, Larado E model with 6 gas cylinders.
Noticing increasing frequency of having the Electronic Throttle control (ETC) light come on, accompanied with a significant power loss for about 2 seconds and the cruise control working intermittently. Both NOT happening as the same time.
Any diagnosis thoughts?
Thanks
Timotb is offline
post #2 of 13 Old 06-14-2019, 11:26 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Have the fault codes read and report back.
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 13 Old 06-15-2019, 03:19 PM Thread Starter
Timotb
Timotb's Avatar
2012 WK
No fault codes found with OBDII. No check engine light. Was reading other threads about the Electronic Throttle control....suggesting it could be a battery issue. This battery is at least 4 years old but showing no other signs of failure.
Timotb is offline
post #4 of 13 Old 06-15-2019, 05:16 PM
jtec
jtec's Avatar
2014 JK Wrangler
pI suspect the scanner you used may not be reading ALL codes, low end readers are lacking.
You can have codes and the CEL remain off, always use a scanner to chek ALL modules for codes.
If the elec throttle light was or is on there is a code.
jtec is offline
post #5 of 13 Old 06-15-2019, 08:23 PM
ColdCase
ColdCase's Avatar
2011 WK
Yeah, what he said. Most OBD scanners just read check engine type codes, not other modules.
Electrical problems, alternator, battery, wiring, grounds cand cause this as well as a dozen other things. So you could throw parts at it if you want. I’d suspect the alternator first, or its grounds, but thats far from a high confidence suggestion.
ColdCase is offline
post #6 of 13 Old 07-16-2019, 01:13 PM Thread Starter
Timotb
Timotb's Avatar
2012 WK
Who reads these deep codes when no engine light is present....besides the dealer? OR....what kind of OBDII scanner is required. Had to tow it to the dealer last night because engine will not start. Still possibly related to E-Throttle body controller IMO.
Timotb is offline
post #7 of 13 Old 07-16-2019, 02:24 PM
ColdCase
ColdCase's Avatar
2011 WK
A shop would, but probably not for free. Some do as part of a promotion.
There are several pro model scanners, with chrysler interface options, (e.g. autoengenuity) but folks here like alfaOBD or appcar, which are apps than run on a PC or phone that use a ODB interface purchased separately.
ColdCase is offline
post #8 of 13 Old 07-16-2019, 02:52 PM
RKLIMAS
2018 WK
There is a $12 brake switch at the end of the brake pedal under the dashboard. This will fail and cause the ETC to act up. I took my 2012 JGC into a dealer several times. They replaced the ETC and other stuff. Still got the ETC warning light. The dealer never found the bad brake switch which was causing the problem. I ordered one online and changed it my self. No problems after that.
RKLIMAS is offline
post #9 of 13 Old 07-16-2019, 04:09 PM
ColdCase
ColdCase's Avatar
2011 WK
Yeah the brake switch is one of the more common causes of this. But thats a guess.
ColdCase is offline
post #10 of 13 Old 07-17-2019, 03:05 PM Thread Starter
Timotb
Timotb's Avatar
2012 WK
Problem was a FUEL PUMP RELAY. Jeep issued recall R09 on this issue and it was performed previously.
Timotb is offline
post #11 of 13 Old 12-03-2019, 12:52 PM
eibyer
The ETC light came on my dash briefly yesterday... which is why I ended up in this thread. I'll have the code scanned at the dealer to see what's up.
eibyer is offline
post #12 of 13 Old 12-03-2019, 07:48 PM Thread Starter
Timotb
Timotb's Avatar
2012 WK
Check the fuel pump relay then check the brake light switch on the brake peddle. My light came on after service for the relay. Removed the switch (see youtube) and reinstalled it. Likely a contact issue on the switch. No problem since.
Timotb is offline
post #13 of 13 Old 12-05-2019, 08:40 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi eibyer,
Please keep us updated on your dealer visit. If additional assistance is needed, please send us a PM and we can connect you with a Case Specialist.
Alex
JeepCares
w6pea likes this.
JeepCares is online now
