DIY Oil/Filter Change - JeepForum.com
 11Likes
post #1 of 26 Old 05-30-2020, 11:14 AM Thread Starter
bicster
2016 WK
My 2016 GC HA is out of warranty now and needs an oil change, so I'm wondering if this is something I can do myself.
I have zero experience with auto-mechanics but am technically minded and a capable DIYer so I feel like this is within my grasp.
Is there anything tricky or any gotchas with the 2016 WK2 in regards to oil changes? And will I need a jack, or do you think I'll be able to do it if I raise the car up to ORII?
Thanks in advance!
bicster is offline
post #2 of 26 Old 05-30-2020, 03:51 PM
emacca
If you have a 3.6l it couldnít be easier
Get underneath remove drain plug and drain into a 7 litre container, while that is happening remove oil filter, in engine bay, fit new filter, get under car refit drain plug.
Now fill motor with appropriate grade oil, check dipstick. Run motor check oil level and check for leaks, done.
Make a note in your maintainance log book, have beer
GCTrekkn likes this.
emacca is offline
post #3 of 26 Old 05-30-2020, 03:59 PM Thread Starter
bicster
2016 WK
Awesome, yes I have the 3.6.
Do I need any special tools? And do I need a jack if I raise the suspension up?
And what about tightening the drain plug, do I need a torque wrench or anything like that to ensure itís tightened appropriately?
bicster is offline
post #4 of 26 Old 05-30-2020, 06:05 PM
Gypsy1
2020 WK
Be careful when you tighten the oil filter cap..do not over tighten it as it can cause damage to the filter housing and eventual leaking
BigTizzie and GCTrekkn like this.
Gypsy1 is offline
post #5 of 26 Old 05-30-2020, 06:08 PM
Gray203m
2008 WK
Torque wrench is nice but not necessary. Drain plug is 20ft-lbs, oil filter housing is 18 ft-lbs. The oil filter comes with a new o-ring for the housing. Make sure you lube it with fresh oil before installing it
tomit likes this.
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #6 of 26 Old 05-30-2020, 06:12 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Most just use ORAII level, but put jack stands or equivalent under for safety. If one of those airbags springs a leak while you are under, there will be less drama.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #7 of 26 Old 05-30-2020, 07:47 PM
BigTizzie
BigTizzie's Avatar
2011 WK
Thumbs up
Yeah, don't over tighten the filter cover. 25 nM.
I put a Fumoto drain valve on a month ago and it's a nice thing to have!
Was going to Rock Auto and order some more Eco Smart filters too. Just used my last one.
BigTizzie is offline
post #8 of 26 Old 05-31-2020, 02:10 AM
Roadijeff
Roadijeff's Avatar
Don't forget to rotate the tires. I do a tire rotation whenever I change the oil, which is every 5,000 miles.
Roadijeff is offline
post #9 of 26 Old 05-31-2020, 05:31 AM
Nejeep
2019 WK
The oil filter cap takes a 24mm or 15/16" socket to loosen. The same size wrench might also work if you have one.
There are several Youtube videos on changing oil on a Jeep 3.6 engine. Those might be helpful if you have not done it before.
bicster and GCTrekkn like this.
19 Limited 4x4 3.6 White/Tan new daily driver
06 Laredo for 11 years
97 Laredo for 14 years
Nejeep is offline
post #10 of 26 Old 05-31-2020, 09:50 AM
GregK340
2017 WK
Definitely get a fumoto drain valve. It will replace your drain plug, with a finger operated valve. It will make your NEXT oil change much cleaner, and more enjoyable.
GregK340 is offline
post #11 of 26 Old 05-31-2020, 02:40 PM
JackB1
2014 WK
Regarding the Fumoto valve. I notice they are sold with 3 nipple sizes. Standard, short and long. What would be the applications for these?
JackB1 is offline
post #12 of 26 Old 05-31-2020, 09:12 PM Thread Starter
bicster
2016 WK
Thanks for the advice guys, Iíll definitely check YouTube out and investigate those oil plug caps.
Next question, any recommendations on filter?
I remember hearing/reading something somewhere about OEM oil filters being the ones to go for. Is that the case, or should I be looking at a particular brand, or are these things a much of a muchness?
bicster is offline
post #13 of 26 Old 06-01-2020, 07:41 AM
BigTizzie
BigTizzie's Avatar
2011 WK
You don't need them.
I got mine with none at all. Better ground clearance.
post #14 of 26 Old 06-01-2020, 07:42 AM
BigTizzie
BigTizzie's Avatar
2011 WK
I used Ecosmart synthetic OF's from Rock Auto last time. They are made for 5000 miles or more between oil changes. Now RA doesn't sell them anymore.
post #15 of 26 Old 06-01-2020, 07:49 AM
9496ZJs
2016 WK
Fumoto drain plugs are convenient, but they are also more likely to get broken off by sticks/stones/snow/sand if you plan to go off road without a bash plate. Not a problem for normal driving though.
99SK04GTX likes this.
9496ZJs is offline
