Date code on AGM Battery “Mfg for Chrysler” - JeepForum.com
post #1 of 3 Old 06-25-2019, 12:15 AM Thread Starter
cdthiel
Junior Member
cdthiel's Avatar
2014 WK
I have a 2014 Grand Cherokee Overland that I purchased Sept 2018. The battery is an AGM, and it looks new (it's under the passenger seat). That said, I can't find an obvious date code.
AGMs are sealed, and being under the passenger seat it doesn't get dirty. There is one item on the side, a square scan code (see attached), and underneath the code is written
001906
0000768327.
I'm thinking the 001906 might mean Jan 19, 2016, but I'd like some confirmation.
Any help would be appreciated. If this is the original OEM battery, I'm due for a new one. If it's really 2016, I can wait - and these AGMs are expensive.
I’ve researched this quite a bit, and can’t find any other info on the battery, etched, stamped, by the battery post, etc.
Charlie
254DA957-F3DD-4A97-ADCA-BA78BF64CA5B_1561442890033.jpg   84F7AEA0-4AF0-4213-B9BC-9F0CE41E6A3A_1561443308930.jpg
cdthiel is offline
post #2 of 3 Old 06-25-2019, 04:13 AM
ytqm
2014 WK
You may be able to scan that QR code and see what comes up. I would believe that is the original battery. I have a 2014 With its original battery also. I wouldnt replace until you have signs its going to fail. I am in the NorthEast and even last year at 0 degree temps, there was no indication the battery is not 100%
ytqm is offline
post #3 of 3 Old 06-25-2019, 07:16 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The trouble is that many/most AGM batteries fail without any warning, or little warning (an hour or two perhaps) so they typically fail at the worst possible time. Battery testers are hit/miss... mostly miss. Not a dependable indication of pending doom. The recommendations seem to be to replace them as part of maintenance. Recommendations vary between every 5-7 years depending on source.
If you don't mind the chance of being stranded, some folks with 2011s still have the original battery. Some of those are 9 years old by now.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
