Cold Air Intake Suggestions - JeepForum.com
 23Likes
post #1 of 29 Old 11-19-2019, 07:50 PM Thread Starter
elJeepo_00WJ
2011 WK
I know, not really any hp gains. Want to buy a CAI for the sound since the 5.7 is way too quiet. Anyways, as far as sound or dyno supported power gains go, which is the best to buy? Volant? K&N? Thanks
w6pea likes this.
why is my jeep always breaking???
elJeepo_00WJ is offline
post #2 of 29 Old 11-19-2019, 07:52 PM
Jaqdripper
2017 WK
I went Mopar for an OEM look. Very high quality, looks great and gives a nice sonic improvement combined with my Magnaflows.
w6pea likes this.
2017 Grand Cherokee Overland Granite Crystal, 5.7 Hemi, 4X4, Sound Group, Safety Group
Jaqdripper is offline
post #3 of 29 Old 11-19-2019, 08:03 PM Thread Starter
elJeepo_00WJ
2011 WK
Think i've already decided on corsa catback for exhaust, just need a CAI to pair up with it now.
w6pea likes this.
post #4 of 29 Old 11-19-2019, 09:35 PM
ZJDevilDog
I've got the volant Intake and it sounds fantastic. Additionally, there are several dyno tests on YouTube on the wk2 hemi showing the volant is one of the only intakes that increases power on the hemi.
Sent from my Pixel using Tapatalk
w6pea likes this.
ZJDevilDog is offline
post #5 of 29 Old 11-19-2019, 09:55 PM Thread Starter
elJeepo_00WJ
2011 WK
Did you get the traditional style or the box/enclosed version?
w6pea likes this.
post #6 of 29 Old 11-19-2019, 10:45 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Volant makes probably the best dry filter but one can spin a lot of tales with a dyno. Its so easy to fool the naive, I used to demonstrate that now and then in a previous life .
You are going to get zero gain unless you also tune, and then the CAI contribution is in the noise. Depending on the model year, tuning can be difficult/expensive.
A less effective filter, like the K&N heavily marketed, will allow more noise to escape, but then you will likely be dealing with dirty throttle bodies and valve/ring wear down the line.
The Volant CAI with dry filter is a good filter.
w6pea likes this.
I was born with nuttin' and I still have most of it.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #7 of 29 Old 11-20-2019, 06:43 AM
ZJDevilDog
I've got the enclosed filter.
post #8 of 29 Old 11-20-2019, 07:57 AM Thread Starter
elJeepo_00WJ
2011 WK
Volant makes probably the best dry filter but one can spin a lot of tales with a dyno. Its so easy to fool the naive, I used to demonstrate that now and then in a previous life <img src="https://www.jeepforum.com/ubb/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" /> .
Plan is Corsa cat back and tune eventually. Hearing lots of good things regarding the Volant intakes
mudbear and w6pea like this.
post #9 of 29 Old 11-20-2019, 01:45 PM
Bilko
Whats cold about these filters? They seem to pull the air from inside the engine bay, the factory one pulls air from the outside under the hood lip, isn't that going to be cooler?
Bilko is offline
post #10 of 29 Old 11-20-2019, 02:40 PM
ColdCase
ColdCase's Avatar
2011 WK
CAI is a hold over term that relates to a free flow intake. The advantage of these so called CAIs is they do away with the intake resonator. But, as you guess, the OEM intake brings in cold air, and is tuned for torque and mid range power at the expense of a little off the top end, its very good. If you always drive more than 4000 rpm, however, a aftermarket CAI may provide noticeably better power, if you always drive less than 2000 rpm, your performance may be hurt. It averages out to not make much performance difference for most folks. Style and sound are subjective.
w6pea and 19GCTrailhawk like this.
ColdCase is offline
post #11 of 29 Old 11-20-2019, 03:05 PM
w6pea
Grumpy Old Fart Marine
w6pea's Avatar
2019 WK
I used to drive a 95 Ford F-250 with a 460cid 7.5L 240 HP and I made the mistake of putting a K&N Filter in it, I also put one in my wife's 92 B150 Ram Van with a 318cid 5.2 L (318 cid) V8 147 HP. I believed their advertising more HP more Gas Mileage,it's BS! (that's my thoughts) Had more problems than they were worth. I took the K&N Filter off my Ford P/U and it seemed to have twice the power it had without the oil bath filter. So when we took it to our mechanic (my wife Van) he said to get rid of it. So stay away from the K&N Filters. If Chrysler Corp thought they were goo they would still be using them.
As for a CAI system I'm at a loss but I am looking to o OEM from Mopar.
"Without Trucks and Truck Driver's America Stops!"
"There's too much Blood in my Caffeine System"
ďIíve never trusted a man who put's cream or sugar in his coffee.
Just like I never really trusted a man who put's Coca-Cola in his bourbon.Ē
"Semper Fi" "Once A Marine Always A Marine"
w6pea is offline
post #12 of 29 Old 11-21-2019, 01:55 AM
rebiobike77
I spent about 20 years modifying/racing cars, from 1000whp evos to 1500rwhp trucks, i CAI can help this engines for the simple reason to remove all the resonators on the oem intake pipe. Each on those traps make a lot of turbulence inside the throttle body. Getting a one direction flow is something to try(im talking about small numbers, real power well is a different story) . At least thats what i saw all this years on the hemi engines. For me AFE power has nice products and there is a dry filter intake with closed air box. Im waiting mine for my 3.6. I just installed the replacement filter and the difference is noticeable in mpg. Power is not.
Enviado desde mi ALP-L09 mediante Tapatalk
rebiobike77 is offline
post #13 of 29 Old 11-21-2019, 03:40 AM
Kman09JGC
Kman09JGC's Avatar
2016 WK
I have this for my 16 75th 3.6 but itís an Xmas present lol so I have to wait. Reviews are excellent for this product. Canít wait to put it on.
Sent from my iPhone using Tapatalk
mudbear likes this.
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline
post #14 of 29 Old 11-21-2019, 06:47 AM Thread Starter
elJeepo_00WJ
2011 WK
After all the great things I heard about Volant combined with their current $60 rebate I ordered one with the powercore filter. I'll let ya'll know how it works out
Kolak likes this.
post #15 of 29 Old 11-21-2019, 08:22 AM
ColdCase
ColdCase's Avatar
2011 WK
Yes, lets establish some real world expectations. (I have 50+ years experience but who's counting)…
Over the years, the performance capability has been talked about here by smarter people than me. Its easy to make make the common mistake of mixing apples with oranges and coming up with a grapefruit Years of racing cars and modified engines doesn't translate well to a WK2... unless you have tons of money and are into highly modifying it (and willing to deal with a non street legal vehicle). Not saying its not fun. Those ads are misleading marketing BS. I don’t buy K&N because you can’t trust their marketing. Once in awhile a marketer will get into the forum and try to sell some product
You can certainly do things like pulling out seats to save weight, and chase a few HP in a narrow rpm range by throwing wild cams in, headers. Throwing the RIPP supercharger on provides measurable performance gains, and is a hoot.
These WK2s have narrower exhaust manifolds and milder cam profiles than other Hemi MOPARS, along with the adaptive ECU. The V6s exhaust manifold is in the head itself. Unlike 20 years ago, the factory has done a good job tuning intake/exhaust flow, they had to spend the development money to meet EPA restrictions. The WK2 Hemi can benefit from just a little more aggressive cam profile, however.
You may initially notice some performance difference after installing a CAI, but the ECU will adapt it out over a hundred miles or so. As mentioned, the WK2 has a highly efficient intake from the factory with tuned resonators to improve low and mid range drivability. It is not constrained by airflow restrictions as you may think and CAI manufactures want you to think.
Early model WK2 did not have a locked down ECU, so it was a bit easier to squeeze some performance out by tuning. Newer ECUs are locked down, so you spend more money to replace it with a tuned one. So, in the end, spending money on a CAI for WK2 performance is throwing money into the wind. I saw maybe a 1 HP gain at high 5000s rpms, but a drop of 2 at the lower rpms typically used on the street, in a quick test. The torque hit is more dramatic, and torque is important for the street. These small numbers are in the noise, however. There are production variances, so if you happen to have a WK2 that does not run well, a CAI could help a bit. Now on the interweb you will find other vehicles that for one reason or another seem to be noticeably improved. Of course, if its on the interweb, it must be right
Sage advice by old timers here is that the most effective method to improve street performance and driver satisfaction is to shift manually, use a more appropriate rpm/gear ratio for your diving style. Takes a little effort, but its cheap and legal. By far most of a tuners's improvement to driver satifaction is the modification to shift points.
Nothing wrong with buying a CAI for sound or style or driving satisfaction, but that should be your WK2 expectation. The sound influences your butt dyno, and one typically drives in a better rpm range. It doesn’t hurt performance much, but that depends on your driving style.
ColdCase is offline
