Can you bleed power steering without a vacuum pump? - JeepForum.com
 1Likes
  • 1 Post By metalhead
post #1 of 6 Old 07-04-2020, 11:27 AM Thread Starter
metalhead
2011 WK
So I moved my power steering cooler so I can install the winch mount. I read you need a vacuum pump to bleed the system. Do you have to do it that way? I can't go anywhere to get one. The jeep is my only vehicle.
1994 YJ (no longer own
2000 Grand Cherokee WJ (no longer own)
2011 Grand Cherokee WK2
metalhead is offline
post #2 of 6 Old 07-04-2020, 12:03 PM
222Doc
222Doc's Avatar
well if you do they are a few that are not much tend to last the one job anyway at Harbor freight.
On a Jk 2012 i never did when i change the gear box to an after market PSC. As well flushed the pump out at the time. Right now im waiting on a pump my self as the stock is giving up at 38k. Not going stock as well PSC pump to go with that box. But i never had to use suction.
222Doc is offline
post #3 of 6 Old 07-04-2020, 03:30 PM
emacca
Fill the resovoir with fluid, cycle the steering wheel back and forth lock to lock, check fluid level,
Repeat a couple of times, then your done.
Check the fluid level over the next couple of days.
That it
emacca is offline
post #4 of 6 Old 07-04-2020, 05:04 PM Thread Starter
metalhead
2011 WK
That it
Thats what I ended up doing and it worked. I raised the front end up to make it easier. So far so good no noises and no leakes. Now I just have an a/c condenser to replace. Tip: Never try removing the old power steering cooler clips on the condenser with a knife.
emacca likes this.
post #5 of 6 Old 07-07-2020, 01:20 PM
Bilko
I know the clips are massively overpriced at $20 but I did tell you:-)
Actually the condensers are prone to failure so a new one is going to ensure you are good for a few years.
Buy new ones because removing the old ones means you will have to remove the condenser.
https://www.moparfactoryparts.com/oe...EaAvCFEALw_wcB
Can you post some photos of the final install
Bilko is offline
post #6 of 6 Old 07-07-2020, 05:52 PM Thread Starter
metalhead
2011 WK
I will be doing a post on installing the winch mount with some pictures and include all the troubles I had.
