Cabin low frequency resonance - JeepForum.com
post #1 of 18 Old 06-12-2021, 03:45 PM Thread Starter
shackleford
shackleford's Avatar
I just bought a 2017 Summit V8 4x4. I noticed that when the AC is on, there's cyclical low frequency rumbling in the cabin. When the AC is off, I hear the same pattern but it's much less intense. It seems like the AC is amplifying the engine natural pattern.
Also, I hear a low frequency rumble when going over bumps. I drive in Auto mode with eco turned off.
shackleford is offline
post #2 of 18 Old 06-12-2021, 06:03 PM Thread Starter
shackleford
The second issue is probably more important. I've read online that the noise went away for some people with replacement of the rear shocks. Should I also replace the rear struts and strut mounts? The vehicle has 61K miles. I literally just purchased a Mopar Added Care+ warranty for 5 years, 75K miles. I think that this would be covered if a dealer found issues there.
post #3 of 18 Old 06-12-2021, 07:06 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The rear suspension doesn't have struts, its a typical coil spring with a separate shock. But in your case it will have an air bag instead of metal spring. Replacing the shock mounts may help.
You may have bad motor mounts, or a bad belt tension pulley, however. Did what you read apply to the air suspension.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 18 Old 06-12-2021, 09:18 PM Thread Starter
shackleford
Ah, yes. The Summit has four airbags, correct? I didn't think about the motor mounts. In what I read, people just mentioned the rear shocks. I may just have a dealership check these parts out.
post #5 of 18 Old 06-12-2021, 09:41 PM
ColdCase
ColdCase's Avatar
2011 WK
The fronts are struts with air bags instead of steel springs.
ColdCase is offline
post #6 of 18 Old 06-13-2021, 06:01 AM
danelo
2012 WK
How about tires? They all make noise dependent on where the tread level is at. The AC being on probably just changes the perception of the noise since it also makes a good amount of noise depending on what fan speed it is on.
danelo is offline
post #7 of 18 Old 06-13-2021, 11:37 AM Thread Starter
shackleford
Good point. I'll check the tread today. Yeah, the situation with the AC is fairly minor. I make take it to a dealership to have them check the few items that people have suggested above.
post #8 of 18 Old 06-13-2021, 11:39 AM Thread Starter
shackleford
So, there are two front and two rear struts with air bags instead of steel springs? Are there also "standard" shocks?
post #9 of 18 Old 06-13-2021, 12:13 PM
BubbaATL
2018 WK
Just a thought ... I occasionally get a very noticeable LF drone at very low speed over uneven pavement. I've had a vague notion that it might be related to some sort of feedback glitch in the active noise cancellation function. Come to think of it, I hadn't noticed it for a long time, and then it happened again last week, and this thread reminded me of it.
2018 Limited 3.6L with pretty much everything ("almost a Trailhawk")
BubbaATL is online now
post #10 of 18 Old 06-13-2021, 05:22 PM
19GCTrailhawk
19GCTrailhawk's Avatar
2019 WK
Summarizing what ColdCase mentioned which can get a little confusing, the front has struts with a self contained airbag. The rear has shock absorbers and a separate airbag.
2019 Grand Cherokee Trailhawk 5.7
Grand Cherokee Owner since 1994
19GCTrailhawk is offline
post #11 of 18 Old 06-13-2021, 06:05 PM Thread Starter
shackleford
Got it. Thanks for the clarification.
post #12 of 18 Old 06-13-2021, 06:09 PM Thread Starter
shackleford
That possibility occurred to me as well. I wish there was a way to turn it off, but I think I'd have to just disconnect something.
post #13 of 18 Old 06-14-2021, 08:57 AM
WK2Overland4X4
Fuse pull would be the easiest. Not sure which one, look for the one for the amp. But that will kill everything sound related.
2012 Overland 4X4 Mineral Gray/New Saddle, HEMI , 24p (ACC,BSM, FCW)
WK2Overland4X4 is online now
post #14 of 18 Old 07-02-2021, 06:42 PM Thread Starter
shackleford
So I took it to the dealer to look at the rear suspension and something else. The technician said that he's heard this complaint before, usually from people who haven't had this vehicle/the airbags, and that it's normal and due to how the airbags operate.
post #15 of 18 Old 07-02-2021, 07:22 PM Thread Starter
shackleford
I wonder if the Jeep has something similar to what's described in post #13.
https://www.clubarmada.com/threads/c...57/#post-99448
But you may get the boom! Underneath in the back, in the rocker panels/fenders behind the tires you will find little grates. inside the grates are baffles made out of what feels like inner tube material. These vents are to release air pressure that causes the boom (cabin outflow vents). Like having the door open on a turbo prop on the ground with the engines running. If they get gooped up and can't flow enough air, then you get the pressure on the ears. If they flow freely and the back is not full of stuff, then you don't have to open the rear speed brake windows to relieve the pressure...
