Brake disc wonít come off - JeepForum.com
 8Likes
  • 1 Post By colinzj
  • 3 Post By ColdCase
  • 2 Post By BigTizzie
  • 2 Post By ColdCase
post #1 of 8 Old 09-18-2021, 01:56 PM Thread Starter
Chris432626
Wk Brake disc wonít come off
Hi,
New owner of a 2011 wk2 grand Cherokee.
Iím trying to get the rear discs off but the parking brakes are preventing them coming off.
Is there any adjuster I can use? I cannot see any rear access hole as suggested by generic websites.
Chris432626 is offline
post #2 of 8 Old 09-18-2021, 02:36 PM
athflying
athflying's Avatar
2011 WK
Did you remove the O ring?
Sent from my Pixel 4 XL using Tapatalk
2011 Grand Cherokee Overland, RWD
athflying is offline
post #3 of 8 Old 09-18-2021, 02:44 PM Thread Starter
Chris432626
Yep.
Can get the disc loose but it wonít come off the rest of the way without taking the parking brake with it.
post #4 of 8 Old 09-18-2021, 04:53 PM
colinzj
2006 WK
There should definitely be adjuster openings on the back, but Chrysler's fetish for hidden rubber brake parts means there may be access plugs hiding them from you.
If the hub's a clock, take a look around 1:30 or 10:30.
Here's the first YouTube video I could search up to give you a better idea of the location:
Chris432626 likes this.
2014 WK2 Laredo 4x4 3.6L
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L
colinzj is offline
post #5 of 8 Old 09-18-2021, 06:32 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I think there is a post somewhere in the brake sticky thread that mentions that you usually have to disconnect the parking LH and RH parking brake cable (2 and 5) from the equalizer (1).
The star wheel access plug is #1 in the second image below.
Screen Shot 2021-09-18 at 8.33.51 PM.jpg   Screen Shot 2021-09-18 at 8.33.19 PM.jpg
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #6 of 8 Old 09-19-2021, 04:56 AM Thread Starter
Chris432626
Well, I found the access point, it was near the top. Saying itís an access point is a bit of a stretch in my opinion as you cannot see what youíre doing!
After some fiddling I still couldnít get the disc off so Iím admitting defeat and calling a mechanic to show me.
Thanks.
post #7 of 8 Old 09-19-2021, 08:38 AM
BigTizzie
BigTizzie's Avatar
2011 WK
This is why you don't let your discs get too rusty or get ceramic coated rear discs. Especially for people up north!
Auto adjust rear parking brakes expand and get behind the rusted area and stuck.
I'd like to go through my rear parking brake cables, etc. Before it becomes a real problem.
The rear brake equalizer rusts out too causing the rear parking brakes to not work. AMHIK
Chris432626 and diverscale like this.
BigTizzie is offline
post #8 of 8 Old 09-19-2021, 09:00 AM
ColdCase
ColdCase's Avatar
2011 WK
He will likely disconnect the parking brake cable at the equalizer which will fully release the parking brake shoes, assuming they are not full of rust and crud. It is rare that I can get this type of rotor off with the cable connected. If it doesn't come right off, a gentle use of a big hammer may loosen things up enough.
Typically parking brakes are not engaged while the vehicle is moving, so there should be little wear and no wear ridges, although there could be some rust. Now if you are using the brake for drifting... thats a different story...
ColdCase is offline
