bilstein 5100 out of stock - JeepForum.com
post #1 of 14 Old 07-25-2021, 06:20 AM Thread Starter
jake22si
2014 WK
My 2014 is in need of replacement shocks and i am having trouble finding 5100's in stock for the rear. I don't have the load leveling shocks. anyone got any leads?
jake22si is offline
post #2 of 14 Old 07-25-2021, 07:03 AM
amg82
amg82's Avatar
2012 WK
Have you tried any local shops in your area?
Sent from my SM-G981U using Tapatalk
amg82 is offline
post #3 of 14 Old 07-25-2021, 10:46 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
If forum sponsor Kolak can't find them, then you may have to wait for the next batch.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 14 Old 07-25-2021, 10:49 AM
Raptor
I've always found this Authorized Bilstein online dealer to have the best pricing w/free shipping;
https://www.ajusa.com/
They appear to have the 5100 series in stock ready to go for your 2014 Grand Cherokee although I didn't try to place an order? 10% off Bilstein Coupon is available today!
https://www.ajusa.com/performance-pa...sid=URMK231tuP
https://www.ajusa.com/checkout/cart/
Raptor is offline
post #5 of 14 Old 07-26-2021, 03:13 AM
Kolak
Vendor
Kolak's Avatar
They're out of stock at Bilstein and all the major wholesalers and retailers. Another Covid supply-chain disruption. They're saying October until there will be more
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #6 of 14 Old 07-28-2021, 05:08 PM Thread Starter
jake22si
2014 WK
thanks for the replies
jake22si is offline
post #7 of 14 Old 08-14-2021, 06:56 AM Thread Starter
jake22si
2014 WK
of course they are back in stock now, I ordered 4600 and already installed them in the rear. Quick question, is the 1.75 setting on the 5100 for the front the leveling setting?
jake22si is offline
post #8 of 14 Old 08-14-2021, 11:27 AM
Bilko
Yes, the fronts can provide up to 1.75". The 5100 rear option provides up to an inch of lift. Personally, I think the WK2 looks weird with only a front lift, can you e-bay or return the rear 4600s?
Bilko is offline
post #9 of 14 Old 08-15-2021, 02:50 AM
Kolak
Vendor
Kolak's Avatar
The rear 5100 series aren't adjustable to lift the Jeep. They're a standard type, non-coilover shock. They're 16.02" collapsed and 22.54" extended.
The 4600 series is 16.02" collapsed and 22.32" extended - a negligible difference.
I see no reason you can't keep the 4600 series in the rear and use the 5100 series up front.
or
Kolak is offline
post #10 of 14 Old 08-15-2021, 10:55 AM Thread Starter
jake22si
2014 WK
Right, I don’t want to lift the rear, I want to use the 5100 at a higher setting in the front to create a more level look, was just wondering which setting everyone has been using
jake22si is offline
post #11 of 14 Old 08-19-2021, 10:48 AM Thread Starter
jake22si
2014 WK
So I installed the front struts myself, but now have a clunking going over bumps. I was told by the tire shop that my sway bar bushings needed to be replaced, this was before I did the shocks. I notice on the old struts it looks like a bushing under the nut but I couldn’t get them off, did I miss a part?
jake22si is offline
post #12 of 14 Old 08-19-2021, 10:51 AM Thread Starter
jake22si
2014 WK
Used the scary spring compressor
11EB55CA-9AF4-4DCD-B1A2-19F9DACE48C5_1629391775498.jpg   ABDB0786-CDBA-4A53-9EEE-7E0BFEABD5E0_1629391795797.jpg   image_1629391837771.jpg
jake22si is offline
post #13 of 14 Old 08-28-2021, 10:25 AM Thread Starter
jake22si
2014 WK
BWOODY sway bar end links cured the issue
jake22si is offline
post #14 of 14 Old 08-28-2021, 06:22 PM
dtrkyman
2013 WK
I had a clunk recently…passenger upper strut mount…next noise was end links.
Sent from my iPhone using Tapatalk
dtrkyman is offline
