Battery keeps going dead - JeepForum.com
 2Likes
  • 1 Post By Nejeep
  • 1 Post By T888
post #1 of 10 Old 09-02-2019, 11:30 AM Thread Starter
T888
Question Battery keeps going dead
I have a 2016 Grand Cherokee 75th anniversary edition 3.6 upgrade (with stop/start) with an electrical problem. Battery completely dead, would not start with portable power pack, or with jumpers cables from another vehicle. I bought and installed new battery, ran fine for 1 day, then completely dead/drained. Towed to dealer, they replaced both batteries, alternator , and power control module and ran fine for 3 days. Completely dead again, towed back to dealer, they found a 1 mil amp drain on battery while sitting, normal draw and no evidence of excessive draw. They charged it up, let it sit on lot for 3 days, starting it everyday with no problem, I picked it up and it went for 2 days, and dead again. I attempted to start with battery pack, and also jump with other vehicle and it would not start. Towed back to dealer.
Waiting on it now. Does this seem familiar to anyone?
T888 is offline
post #2 of 10 Old 09-02-2019, 11:42 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It the battery dead at its terminals, or does the Jeep just not turn over? There is a IOD fuse and current/voltage sensor in the battery cable/connector that can go bad/intermittent.
Otherwise, perhaps a loose ground or other electrical connection that, as you drive around, bumps loose over time. Perhaps a pushed pin somewhere.
I was born to party, but I am forced to work
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 10 Old 09-02-2019, 03:00 PM
Nejeep
2019 WK
Starting normally at the dealer but not at home means something must be different. Was it garaged or outside, locked or unlocked, remote started or push button?
Where do you keep your key fobs when parked at home? If it is within a few feet (5-10) of the Jeep, the control modules may not go to sleep and will drain the battery.
The no start with a jumper pack/cables is also strange. Is it totally dead (no clicks & no dash lights), just a no-crank or crank but no-start condition?
howardusa likes this.
19 Limited 4x4 3.6 White/Tan new daily driver
06 Laredo for 11 years
97 Laredo for 14 years
Nejeep is offline
post #4 of 10 Old 09-03-2019, 12:48 PM
howardusa
Interesting. Didn't know that. Thanks for the information. It's never happened to me but I will be more cautious as to where I place the key fob. I would have never thought of that in a million years if my battery kept going dead.
HT
howardusa is offline
post #5 of 10 Old 09-03-2019, 02:46 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Please keep us updated on your dealer’s findings, T888. If we can be of any additional assistance, we’d be happy to help. We’re just a PM away.
Mark
Jeep Social Care Specialist
JeepCares is online now
post #6 of 10 Old 09-07-2019, 11:57 PM Thread Starter
T888
Thanks for the help on this, the dealer thought that it was a key fob issue as well, it went dead one time at work and the key fob was not there. When it was dead, there was nothing, no power. It has been repaired, took the dealer days to diagnose the problem, it was a defect in a fuse box under the hood that would energize the ac compressor clutch intermittently, even when the jeep was off/parked. The constant power supply to the clutch would completely drain the battery.
Mustangmike66 likes this.
T888 is offline
post #7 of 10 Old 09-08-2019, 12:20 AM
ColdCase
ColdCase's Avatar
2011 WK
Thanks for the follow up. A new failure mode for me
ColdCase is offline
post #8 of 10 Old 09-08-2019, 12:54 AM
96GrandJeepers
T888 ~ Thank you for posting a possible solution to a (hopefully) very unusual problem.
2018 Grand Cherokee Limited
2018 Cherokee Latitude Plus
1996 Grand Cherokee Limited ~ Sold 12/2018
96GrandJeepers is offline
post #9 of 10 Old 09-09-2019, 03:14 PM
MarkSRT8
2015 WK
I leave the FOB in a cup holder overnight in my garage and when on vacation and never had a problem with the battery draining.
MarkSRT8 is offline
post #10 of 10 Old 09-09-2019, 05:17 PM
Bilko
What's your address
Bilko is offline
