Battery Failure - What happens if it's while driving? - JeepForum.com
 3Likes
  • 1 Post By WK2Overland4X4
  • 2 Post By scottydog
post #1 of 13 Old 06-26-2020, 08:39 AM Thread Starter
javsst
2014 WK
All,
I'm planning on replacing the original battery in my 2014 GC Limited as a
precaution as I figure 6 years is pretty good on an OE battery.
But that got me thinking. AGM batteries, as others have noted, can fail without warning. Even non-AGM ones like the one I had fail on my 99 300M years ago didn't provide any indication it was going to fail and it was 5 years old.
What exactly happens if the battery fails while on the road, in particular while driving?
Seems to me at the very least the electronic assist steering is going to get quite interesting to handle.
What about the shifter?
Thanks!
Steve
2014 Jeep Grand Cherokee Limited
javsst is offline
post #2 of 13 Old 06-26-2020, 08:55 AM
WK2Overland4X4
2012 WK
Originally Posted by javsst View Post
All,
I guess define "fail" first, but by assuming you mean, gets old, no longer useful failure like almost every battery.
Nothing at all will happen. When driving everything (ideally) in the the car is powered by the alternator/charging circuit.
You can (not a great idea, but you can) start a car, remove the battery, and go on your way.
But if you mean a catastrophic failure, like it shorts out internally, or something, then it could be different, but probably not.
The first sign of a bad battery is trouble cranking over. Being stranded is probably 99% of the result of battery failures. The rest could be something else.
^ all my opinions, not actual numbers!
WK2Overland4X4 is offline
post #3 of 13 Old 06-26-2020, 09:01 AM Thread Starter
javsst
2014 WK
Good point.
I guess my thought was what happens if the battery does suffer total failure and shorts out, causing an engine stall while driving and no electrical power
going to the various drivetrain components.
Thanks!
Steve
javsst is offline
post #4 of 13 Old 06-26-2020, 09:16 AM
jay-h
Everything stalls. Engine stops. I've never seen a battery fail that way, but once I had a terminal pop off while driving. I don't know about electric steering, but I would assume that you could still steer the vehicle just as with conventional power steering when a belt fails.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 13 Old 06-26-2020, 10:39 AM
WK2Overland4X4
2012 WK
Good point.
Thanks!
Steve
If the battery actually shorted out, you wouldn't want it driving anyway. There would probably be a fire and massive smoke and fumes, especially since it is under the passenger seat you couldn't be in the car for more than a few seconds.
But that is the nice thing about where they are, they don't get anywhere near the rapid temperature changes and hold up much better.
I used to say any battery over 3 years old was suspect for reliability. Now I would change that to 6 years, then replace when convenient, or any sign of problems. Heck, my 1967 El Camino has been acting up for a couple years when it sits and doesn't get a hour drive under it for a while, then I realized its battery is 10 years old... And it is still in there doing its job!
SouthDakota likes this.
post #6 of 13 Old 06-26-2020, 11:00 AM
JackB1
2014 WK
Couple good points above. A battery is like a bucket with X number of charges. When the bucket is empty the battery dies. Point here is that battery life partly depends on how many times it starts the car. Fewer times you take a start from that bucket the longer it will last. Your El Camino is a good example of that as it sits a lot. That being said one of the worst things for a battery is to let it run down completely. Really shortens life. I also have a 2014 and am also thinking it is about time but I am stretching it because I am on the low end of vehicle use and have subjected the battery to less starts. For peace of mind I carry a Lithium Ion starter pack in the spare tire bay. Cost me $69. Occasionally I also hook up a smart charger and bring the battery to full charge which AGMs prefer. Places like Advance Auto will also do a load test for free to see how the battery is aging.
JackB1 is offline
post #7 of 13 Old 06-26-2020, 02:05 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Depends if you have ESS or not and which of the ESS batteries short.
An AGM is unlikely to explode as it usually just shorts between a couple plates, and vents through the vent hose. The voltage will drop until the short burns away and the battery becomes an open circuit. The old liquid filled lead acid batteries were different as debris could settle in the bottom and could short a number of cells, and enough gas can be released to pop the case. This usually doesn't happen unless you short the battery externally, saw that happen once.
If the fusible link doesn't blow and its drawing more current than the generator can produce, the shorted battery loads down the battery bus. You could see a Christmas tree light type display on the dash. Low enough and everything stops, including the engine. If the fusible link blows, you will probably get charge or battery warnings but things should keep running. It won't start, however.
If you have ESS, the results are different depending on which battery is shorted. The batteries are isolated and a short in the main battery will likely only affect starting, the ESS battery will power everything else. A short in the ESS battery will just give you a ESS not available warning.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #8 of 13 Old 06-26-2020, 02:22 PM
ColdCase
ColdCase's Avatar
2011 WK
Over time, AGM has consistent performance until the drop off cliff at end of life. Regular lead acid has a shallow slope that starts when you fill them with acid and gets a little steeper over time. So load tests determine the health of a regular lead acid battery pretty well, but it is tricky on an AGM. By the time an AGM battery shows any sign of a drop in performance, it is living on borrowed time.
ColdCase is offline
post #9 of 13 Old 06-27-2020, 06:03 AM
scottydog
2017 WK
I think the vast majority of battery failures will be no starts. I did have a Mercedes where the windows started going up and down like the car was haunted. I thought it was funny, my wife was not amused. Most newer cars are very sensitive to voltage drops.
Given the headache and expense of getting stranded somewhere with a dead car I replace car batteries a bit early before they go south. IMO Its just not worth the few dollars saved trying to squeeze out an extra year or two from a battery.
SouthDakota and danelo like this.
2017 JGC Limited V6
prev 2004 JGC Laredo, 2009 JGC Laredo
scottydog is offline
post #10 of 13 Old 06-27-2020, 03:21 PM
SouthDakota
SouthDakota's Avatar
2018 WK
+1. I do it at 5 years, but same philosophy. When I tested my wife's 5.5 year old 2014 Jeep GC battery, it showed low, but still about 50+ CCAs above minimum. Ran fine, no issues; replaced it anyway with an O'Reilys high end AGM (at the time, they were produced by Deka/East Penn, but not anymore, they recently changed that).
Probably would have worked fine through one more winter until we traded it in March of this year, but I didn't want to chance the wife getting stuck somewhere in the winter with an iffy battery.
-Jason
2018 Jeep Grand Cherokee Trailhawk 4x4
5.7L Hemi V8, Luxury & Active Safety Groups, Rock Rails
2014 Ram 1500 Laramie Longhorn CC 4x4
5.7L Hemi V8, Protection & Convenience Groups, 3.92 Gears, Anti-Spin Rear End, RamBox System
SouthDakota is offline
post #11 of 13 Old 07-15-2020, 04:58 AM
mcgeepj2
mcgeepj2's Avatar
2017 WK
Originally Posted by ColdCase View Post
If you have ESS... The batteries are isolated... the ESS battery will power everything else.
I need help understanding the relationship, if there is one, between the big and little batteries. As mentioned in other threads, the little battery (ESS) can be completely disconnected with no affect on any other function of the Jeep. True? The little battery doesn't run anything after you turn the vehicle off for those few seconds? Isn't there a single vent tube that connects to both batteries? What do we need to do with the part that connects to the little battery?
I'm getting a red Battery light and the yellow ESS light. Monitoring the battery voltage gauge (screen) when this happens the voltage is down at 13.1 or below. Turning off the Jeep and back on turns lights are off and the battery voltage is back up - for awhile.
I'm thinking this is all related to that little battery and want to disconnect it and see how the Jeep does then.
Thoughts?
2017 Grand Cherokee
1994 Wrangler SE
Previous 83' CJ-7, 77' J-10, 75' CJ-5
Stationed in Korea
mcgeepj2 is offline
post #12 of 13 Old 07-15-2020, 06:41 AM
ColdCase
ColdCase's Avatar
2011 WK
Somewhere around here is a thread with a battery/charging discussion. But it is normal for late model voltage to vary due to the way things are regulated, to save you 0.1 mpg. If no one jumps in here by the time I get back I'll take a look.
A battery light should throw a code, if you can read it then it may help to narrow down the possibilities.
ColdCase is offline
post #13 of 13 Old 07-15-2020, 03:10 PM
2014RedHemiGC
2014RedHemiGC's Avatar
2014 WK
This recent discussion might help - https://www.jeepforum.com/forum/f309...45/index7.html
2014 Deep Cherry Red GC 4X4 V8 QDII
2012 Crystal Red Cadillac CTS-V Coupe
2011 Crystal Red Chevy Corvette Z06/Z07
2014RedHemiGC is offline
