B222A - Vehicle Line Mismatch? - JeepForum.com
 2Likes
  • 1 Post By ColdCase
post #1 of 10 Old 09-05-2020, 05:33 PM Thread Starter
kga1978
kga1978's Avatar
2017 WK
Hi folks,
I just used JScan to change the tire size on my 2017 Trailhawk from 265/60/18 to 265/65/18. After going through the whole process my Park Assist wouldn't turn on and I got a "ParkAssist Unavailable" error in the instrument cluster. After scanning the car for errors I get a B222A - Vehicle Line Mismatch specifically under the park assist module.
Any thought on how I might fix this? I didn't do anything to the park assist module when I went through the process - just changing tire size...
Thanks
kga1978 is offline
post #2 of 10 Old 09-05-2020, 06:24 PM
ceb1
ceb1's Avatar
Originally Posted by kga1978 View Post
Hi folks,
Thanks
Did you change it back?
ceb1 is offline
post #3 of 10 Old 09-05-2020, 09:28 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It may not be the module, playing with tire sizes can sometime cause all kinds of unexpected faults. The PCM tells other modules what the vehicle line is and this DTC is probably indicating that some parameter isn't something park assist is expecting. Under normal conditions one would replace the park assist module.
It may just be a coincidence, especially if you change it back and you still get the error.
jtec likes this.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 10 Old 09-06-2020, 02:00 PM Thread Starter
kga1978
kga1978's Avatar
2017 WK
I couldn't change back to stock tire size with JScan since the exact OEM tire size wasn't one of the options . I managed to roll back to stock using AlfaOBD instead, which allowed me to clear the B222A error and get parking assist back, no problem.
It's really weird because the B222A code is directly linked to changing the tire size - as soon as I go in and change the stock 2371mm circumference to something else (I was aiming for 2453mm, but anything will do) using either JScan or AlfaOBD, the Parking Assist module throws the B222A code and turns itself off - no way to get it back, without changing the tire size back to stock.
Kinda peculiar...
kga1978 is offline
post #5 of 10 Old 09-06-2020, 03:02 PM
jtec
jtec's Avatar
2014 JK Wrangler
KISS - Them puters be smart.
jtec is offline
post #6 of 10 Old 09-06-2020, 03:20 PM
ColdCase
ColdCase's Avatar
2011 WK
If I recall correctly, there are a couple parameters that need to be changed, if you were not already aware of it. Someone posted the details around here somewhere. It was easier to do pre 2015.
ColdCase is offline
post #7 of 10 Old 09-06-2020, 06:07 PM Thread Starter
kga1978
kga1978's Avatar
2017 WK
Yeah, I need to clear codes and initialize ABS too to get it to work, but the code unfortunately still sticks. Very strange.
I have contacted the developers of the apps, so we'll see if they have a solution. Interestingly, it occurs as soon as I select a size => 30" - anything below and it's fine, but as soon as I go over it throws the code. Stock for the car is ~ 29.7".
kga1978 is offline
post #8 of 10 Old 09-06-2020, 06:18 PM
ColdCase
ColdCase's Avatar
2011 WK
Unlike other vehicles with multiple possible tire sizes, the WK2 has only one OEM diameter tire, so even the dealer scan tools can't do much as a change tire menu isn't even provided. I think some here have been successful adjusting for 32s, but that may also be earlier model WK2s.
kga1978 likes this.
ColdCase is offline
post #9 of 10 Old 05-04-2021, 04:20 PM
82Renegade
82Renegade's Avatar
1982 CJ7
I just did the same thing... good times. I was able to clear the ABS but not the B222A. Were you able to figure out a solution?
Thanks!
82Renegade is offline
post #10 of 10 Old 05-04-2021, 05:00 PM
Fast55
Fast55's Avatar
2017 WK
The solution is, live with the error especially for 2015+ WK2's. Even 275/65's are only about 5% off.
2017 Trailhawk
Active Safety, Luxury group, Blind spot detection
Hemi
Rock Rails, Chief Products
Fast55 is offline
