Auto-on comfort - JeepForum.com
post #1 of 31 Old 01-20-2016, 11:49 AM Thread Starter
HSTNJEEP
2015 WK
Auto-on comfort
In settings, it says heated steering wheel and heated seats will come on (either remote start only or all starts) when you select this option.
My rear defrost also comes on.
Normal?
HSTNJEEP
2015 WK2 Limited 4x4, 3.6, Granite Crystal Metallic
2013 WK2 Laredo, 3.6, Mineral Gray
HSTNJEEP is offline
post #2 of 31 Old 01-20-2016, 12:15 PM
FLHXSE3
2014 WK
Normal?
Mine does too.
FLHXSE3 is offline
post #3 of 31 Old 01-20-2016, 12:26 PM
lurtonk
2015 WK
...and your outside heated mirrors.
lurtonk is offline
post #4 of 31 Old 01-20-2016, 06:42 PM
MattXJ
2014 WK
Yes, if it's below a certain temperature outside. That's not a feature of Auto-comfort. Even with Auto-comfort off, the rear defroster will come on with auto-start. It's hard coded into the HVAC microcode. My 2014 never had this until after they applied the latest HVAC flash.
I actually quite dislike it, and find it very annoying that there's no settings option to disable it.
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline
post #5 of 31 Old 01-20-2016, 06:46 PM
Blackshirts
2012 WK
why is it annoying?
Blackshirts is offline
post #6 of 31 Old 01-20-2016, 06:50 PM
lqueral
2014 WK
comfort
Yeah, I just turn off the rear defroster if I get in car and see the light for it on. I'd rather have it on and not need it than it be off and I need it. No major biggie.
lqueral is offline
post #7 of 31 Old 01-20-2016, 06:53 PM
MattXJ
2014 WK
Way up here in Canada it's cold most of the winter. Really cold. Not that sorta cold, damp cold stuff. So every time it snows on the Jeep, it tends to be dry deep snow. If I auto-start to warm the Jeep up the rear defrost comes on and actually melts a thin layer of that snow where it's touching the glass and turns to ice where it contacts the snow sitting on it. That makes scraping the rear glass clean nearly impossible, constantly leaves trails of slush/ice, whereas cold snow on cold glass brushes off cleanly and easily and tends to stay perfectly clean while driving.
It kinda makes this multi-layer sandwich of glass->water->ice->snow and it all sticks together like glue. Even if you do get it clean, because the glass has been warmed, when you're driving down the hwy the swirling snow catches on the warm glass and sticks and turns to ice again, making the rear wiper useless.
It's like they never tested the feature in a true cold environment, or with a car covered in a snowfall. Up here, that's like 3-4 times a week when I come out to go home from work. At least give me an option to disable it.
MattXJ is offline
post #8 of 31 Old 01-20-2016, 07:39 PM
FLHXSE3
2014 WK
Disable it 'permanently'? Disco it at the rear window.
FLHXSE3 is offline
post #9 of 31 Old 01-20-2016, 07:40 PM
MattXJ
2014 WK
Haha, no, just the fact that it turns on automatically when I use auto-start.
MattXJ is offline
post #10 of 31 Old 01-20-2016, 08:37 PM Thread Starter
HSTNJEEP
2015 WK
My rear defrost only comes on some of the time I auto start. That is what confuses me. Today at lunch it did, along with the seats and steering wheel. This afternoon, wheel a seats came on, but rear defrost did not. Is that because it is not part of the auto on (just seats and wheel)? It has its own criteria for when it comes on?
We are actually having some cold weather here in alabama this week. Not used to the auto on being activated very often during day time hours.
HSTNJEEP
HSTNJEEP is offline
post #11 of 31 Old 01-20-2016, 08:40 PM
MattXJ
2014 WK
Precisely.
MattXJ is offline
post #12 of 31 Old 01-20-2016, 09:49 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I think the defrosters are independent of the heated seat, steering wheel comfort settings. There are temperature thresholds where the HVAC will either heat up the Jeep or cool it down and another for defroster activation. In 2011-2013 one can also turn on and off the side mirror and rear window heaters.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #13 of 31 Old 01-25-2016, 08:37 AM
Miami_Son
2015 WK
Is there some magic to getting this to work? I had it on with remote start and it doesn't work. I set it to all starts and still not working. Does the outside temp have to be below a certain point for this to work and if so what is it can it it be changed? It was in the 40-50s this weekend and I would like for it to have been working as it should.
Miami_Son is offline
post #14 of 31 Old 01-25-2016, 09:01 AM
lurtonk
2015 WK
Mine seldom comes on if the temperature is above 40.
lurtonk is offline
post #15 of 31 Old 01-25-2016, 11:33 AM
Miami_Son
2015 WK
Got this from the Jeep CD
Auto-On Comfort — If Equipped
After pressing the “Auto-On Comfort” button on the touchscreen the following settings will be available:
Auto-On Driver Heated/Ventilated Seat & Steering Wheel With Vehicle Start — If Equipped
When this feature is selected the driver's heated seat will automatically turn on when temperatures are below 40° F (4.4° C). When temperatures are above 80° F (26.7° C) the driver vented seat will turn on. To make your selection, press the “Auto-On Driver Heated/Ventilated Seat & Steering Wheel With Vehicle Start” button on the touchscreen, then select either “Off,” “Remote Start” or “All Starts” until a check-mark appears next to setting, showing that setting has been selected. Press the back arrow/Done button on the touchscreen to return to the previous menu.
40° F is pretty damn cold. Why would they set it this low and give us no way to change it? Even at 50° F it is chilly enough to warrant having the heated seats and steering wheel come on. And where is it getting this temp reading from, the outside sensor? For a vehicle parked outdoors in 41-55 degree weather it could easily be colder inside the vehicle than the outside temp sensor says it is. I've owned nothing but Chrysler and Jeep vehicles for the past 40 years, but I am constantly being reminded just how stupid their engineers are.
