Airing down? - JeepForum.com
 2Likes
  • 2 Post By Fast55
post #1 of 6 Old 12-27-2019, 07:39 AM Thread Starter
dtrkyman
2013 WK
Airing down?
I searched around a bit a bit and did not find anything specific.
I have a 13 v6 with Sahara takeoffs, 255/70/18 Bridgestone dueler A/T, second set and they have been great.
Since itís just an A/T tire and not E rated what would you think a safe pressure would be to run off road in a mix of rock and sand?
I thought I could run upper 20s on rough roads where I may still get up to some higher speeds and down to 20 on trails?
Seems like pure sand you need to be down to 15 or less but not likely to be in any dunes.
Sent from my iPhone using Tapatalk
dtrkyman is offline
post #2 of 6 Old 12-27-2019, 07:59 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Remember that the WK2 likes to tripod, which puts much more load on the tires touching the ground. You are not going to want to air down as much as you would other vehicles, if your trail takes you over uneven ground or rocks.
Never Argue With An idiot. They'll Lower You To Their Level And Then Beat You With Experience!
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 6 Old 12-27-2019, 08:27 AM
Fast55
Fast55's Avatar
2017 WK
Until you get into really soft stuff like sand, there isn't much advantage to airing down other than the softer ride. For dune running, I put all 4 at 15 PSIG. At that pressure I couldn't get stuck in the sand if I tried. I've never lost a bead at that pressure.
mudbear and Homer1 like this.
2017 Trailhawk
Active Safety, Luxury group, Blind spot detection
Hemi
Rock Rails, Chief Products
Fast55 is offline
post #4 of 6 Old 12-27-2019, 09:03 AM Thread Starter
dtrkyman
2013 WK
Know all about the tripod! Makes sense , once I get my compressor I will play around some.
What pressure does the sensor light trip at? I am gonna run 25lbs and see how it rides, definitely will enjoy the softer ride!
dtrkyman is offline
post #5 of 6 Old 12-27-2019, 10:35 AM
Blackshirts
2012 WK
Air down to 12. Jeep floats over loose sand and dunes. I have air deflator valves set at 12. Work great!
Blackshirts is offline
post #6 of 6 Old 12-27-2019, 01:44 PM Thread Starter
dtrkyman
2013 WK
Yeah seems sand isnít much issue going low, mostly concerned with rocky terrain!
dtrkyman is offline
