adding back up camera on 2015 altitude - JeepForum.com
post #1 of 24 Old 02-11-2015, 08:57 AM Thread Starter
15Altitude
Just picked up a new 2015 altitude last week after driving a limited as a loaner for 2 weeks.. The wife fell in love with the back up camera on the limited and now i have a new project for the altitude.. Dealerships around here want a little more than 1k dollars to install which i believe i can do for a lot cheaper. Ive searched and know whats involved..
My main question is has anyone used the kit from http://www.emeraldintegrations.com/c...ra-system.html ? The difference i see is the camera itself. Instead of replacing and painting the entire panel, looks like i can drill a hole and thread this one in.. Any input would be appreciated..
15Altitude is offline
post #2 of 24 Old 02-11-2015, 09:16 AM
asorr1
Also interested in this as my new Laredo will not have the back-up cam and I would like it since I added the bigger radio.
2020 Jeep Grand Cherokee Trailhawk with Lux Package in Granite.
asorr1 is offline
post #3 of 24 Old 02-11-2015, 01:16 PM Thread Starter
15Altitude
Ive contacted the company to email me a copy of the instructions.. Aside from taking the interior panels apart , it looks pretty straight forward.. Looks like ill be the guinea pig for his one. Its much better than having to buy the entire rear panel and repaint it.
post #4 of 24 Old 02-14-2015, 10:03 AM Thread Starter
15Altitude
Just incase anyone is following this, I got the parts in next day.. Should be doing the install in the next few weeks
edit: I tried uploading a picture of the kit but I keep getting an error message...
post #5 of 24 Old 02-14-2015, 10:07 AM Thread Starter
15Altitude
Kit
post #6 of 24 Old 02-14-2015, 10:46 AM
TAvette
This thread might be of some use
http://www.**********.org/f155/2014-...led-82261.html
"jeep garage" in place of * (no space)
TAvette is offline
post #7 of 24 Old 02-15-2015, 08:39 AM
BlckWK2
2014 WK
Just to let you know the panel can be swapped with your current one. It's held onto the rear brow with some tabs. Once popped off you can snap in your panel, no drilling, fully integrated, OEM rear brow backup camera with your panel cover and no repaint. However, it does look like you saved a little money going aftermarket. Let us know how the install goes! If you run into any issues just post them back up here. Many people have experience with either doing the install themselves or having the dealership do the install. Both methods of installation have led to some questions (steering wheel controls not working, backup camera flickers, etc..) but the community helped with solving many of the after install issues.
Good luck!
BlckWK2 is offline
post #8 of 24 Old 02-15-2015, 11:22 AM
Robs15Altitude
Just picked up a 2015 Altitude as well with no backup camera. I've seen a couple solutions like the one from CRUX that doesn't require the dealer to activate the camera option but this is cheaper (parts anyhow). Keep us posted on your outcome. Other then popping some trim panels, mounting the camera and running the cable it doesn't look to bad. The radio comes out really easy from other posts I've read. Thanks for posting your findings...
Robs15Altitude is offline
post #9 of 24 Old 03-11-2015, 06:52 AM Thread Starter
15Altitude
So far so good.. took the better part of 2 days but was also taking my time.. Have It all hooked up besides the switched power near the radio.. Have to figure out what i can tap into.. Thinking about splicing into the cigarette lighter port.. Attached is how i have it wired.. Plan on going to the dealer this weekend..
post #10 of 24 Old 03-11-2015, 06:57 AM Thread Starter
15Altitude
Looks like its not centered but it is.. I measured about 5 times.. Ill get a better one in the sun
post #11 of 24 Old 03-11-2015, 02:47 PM
DavidsCyclops
DavidsCyclops's Avatar
2014 WK
Looks like you have to have the dealer program it also to make it turn on and work in reverse?
DavidsCyclops is offline
post #12 of 24 Old 03-12-2015, 07:24 AM Thread Starter
15Altitude
Yes i still have to have the dealer program it.. I plan on doing that this friday.. The moment of truth..
post #13 of 24 Old 03-12-2015, 08:44 AM
DavidsCyclops
2014 WK
can they also program front bumper cameras?
post #14 of 24 Old 03-13-2015, 06:27 AM Thread Starter
15Altitude
I believe so but sounds like you better option is the lock pick.. Look it up..
post #15 of 24 Old 03-13-2015, 08:56 AM
DavidsCyclops
2014 WK
I was almost ready to get the lockpick. read over 1000 posts on it in another forum.
But I was curious about doing it so it worked like stock
