AC Low Pressure Port - JeepForum.com
post #1 of 5 Old 07-14-2020, 08:56 PM Thread Starter
Rot_stupid
Rot_stupid's Avatar
Is the 2016 Grand Cherokee supposed to have a larger than normal low pressure AC valve? I tried to refill the R134 in the wife's Jeep and I found what should be the low pressure valve but the fill adapter doesnt fit on it. It's not my adapter because I used it to recharge my TJ.
Rot_stupid is offline
post #2 of 5 Old 07-19-2020, 12:03 PM
DRKRED12
Check with ColdCase on this one. I am sure he could point you in the right direction.
DRKRED12 is offline
post #3 of 5 Old 07-19-2020, 12:40 PM
GPSBob
2015 WK
The port is a different size, because it uses different refrigerant - R-1234yf vs. R-134. I just ran into the same issue on my 2015 (you should check on your 2016 to make sure it uses the 1234yf and not something newer still - there will be a decal somewhere in the engine compartment)
So, you'll need a different adapter to connect to the Low Pressure port, and you'll need a can of the right refrigerant. It's pretty spendy - I paid something like $44 for an 8 oz. can at Advance Auto.
GPSBob is offline
post #4 of 5 Old 07-19-2020, 01:31 PM
JackB1
2014 WK
So in what year did they begin using R-1234yf refrigerant?
JackB1 is offline
post #5 of 5 Old 07-19-2020, 05:31 PM
ceb1
ceb1's Avatar
I think they started in 2014 - probably 2015 MY.
ceb1 is offline
