5.7 oil pan removal - JeepForum.com
 1Likes
  • 1 Post By stumpy383
post #1 of 10 Old 09-04-2019, 08:56 PM Thread Starter
stumpy383
stumpy383's Avatar
5.7 oil pan removal
Can you drop the oil pan on a 2011 GC 5.7 hemi with out pulling the motor?
stumpy383 is offline
post #2 of 10 Old 09-04-2019, 09:09 PM Thread Starter
stumpy383
stumpy383's Avatar
It's rear wheel drive.
post #3 of 10 Old 09-04-2019, 10:11 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The shop manual has you supporting the engine and dropping the engine cradle out from underneath to access the oil pan. So technically the engine is not pulled... but its a lotta work as the suspension needs to be pulled apart, and numerous other details, to remove the cradle. For RWD, you just skip the remove the half shafts steps.
There may be a couple threads on the subject, but I don't recall off hand anyone doing it on a RWD and reporting here.
May I ask why you want to drop the pan?
Never Argue With An idiot. They'll Lower You To Their Level And Then Beat You With Experience!
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 10 Old 09-05-2019, 09:38 AM Thread Starter
stumpy383
stumpy383's Avatar
Developed a light rod knock andI need to replace all the bearings. I did it on my race trucks so I hope to be able to do it for the CG.
post #5 of 10 Old 09-05-2019, 05:45 PM Thread Starter
stumpy383
stumpy383's Avatar
Well after looking at the job I decided to go ahead and have a reman installed./ Found one for 3k with a one year warranty. Biggest thing is this is the first time in 50 years of twisting wrenches I couldn't do the job myself.
BigTizzie likes this.
post #6 of 10 Old 09-09-2019, 06:11 PM
Abeyance
"Couldn't", or just decided it wasn't worth the time and banged up knuckles? I'd think that after 50 years of wrenching you're entitled to decide to pay someone to do the work while you go do something a bit more fun (even if you could still do the job if you really wanted to).
Abeyance is offline
post #7 of 10 Old 12-07-2019, 06:32 PM
Simmer124
2011 WK
any idea what the labor would be to drop the pan? Mine is leaking on the front and side bolts
2011 Jeep Grand Cherokee Overland SUMMIT
5.7 HEMI / Saddle Brown Leather / Every Option
Simmer124 is offline
post #8 of 10 Old 12-14-2019, 10:55 PM
09JeepCommander
2015 WK
Did you try tightening the bolts? I've seen somewhere that some did that to stop a leak on their oil pan.
2015 GC Laredo
"I've got an appetite for destruction, and I scrape the plate."
09JeepCommander is offline
post #9 of 10 Old 12-15-2019, 10:04 AM
Simmer124
2011 WK
Im going to do your suggestion. I received a quote of $1600
post #10 of 10 Old 01-31-2020, 03:37 PM
09JeepCommander
2015 WK
How did this turn out?
2015 GC Laredo
